Question about Canon NP 6551 Black and White Copier
Canon NP6050 E212 -lense problem
How can I fix this error.
    Sergeant:
  • 199 Answers
Change the small gear located (inside in lens drive assambly motor)
Posted on Feb 15, 2009
Error E212
vaya y baje el manual de instrucciones para ver errores:
www.servicemanuals.net o www.angefirecom or www.schematicx.com or www.2manuals.com or www.copierrepair.net or www. retrevo.com or www. eserviceinfo.com
Dios le bendiga
May 09, 2012 | Canon NP 6230 Copier
Code error E212, with 3 options: Command card Initial detector Moving device somethig like that
E212: problem with the optical section
  1. Home position sensor is defective
  2. Motor Lens move iis defective
  3. Control board is defective
Oct 16, 2010 | Canon NP 6551 Black and White Copier
I want to get some help about canon np6050 error
Hello jig,
I wish to help you quickly as you are down. I dont have immediate access to the older analog service manual and Canon no longer keeps it on their website.However, E005 has been a common error code for many products, if not all. It means that the cleaning web (which is an item that is "used/consumed "normally as the copier is used.) has run out.The copier should have been diplaying (in small letters on the dispay) "WEB LOW" for quite a while.It needs a new cleaning web.An untrained end user could change this but without instruction most people would not be able to. Its located in the fuser area onder a yellow cover. I bet you can do it !
Apr 09, 2010 | Canon NP 6050 Copier
E212 Error code
"E212" Lens problem (sensor, motor)lift document feeder and look inside. is the lens stuck? when turned on it goes back and forth to check where it is
Aug 11, 2008 | Canon NP 6545 Copier
Error code E212
sorry I have'it only in italian
Jul 11, 2008 | Canon NP 6035 Copier
Error 99 in canon 400D
You will get that error when using some lenses other than Canon. A lot of the older Sigma lenses have that issue. Do you get this error when using newer Canon EOS lenses?
Apr 01, 2008 | Canon Digital Rebel / EOS-300D Digital...
Canon NP6050 Error code E013
E013 refers to the waste toner receptical being full, but in this case the toner melts at the end of the worm screw assembly causing the cleaning unit to block up, activating the microswitch which tells the machine the waste toner bottle is full. The solution is to try to free up the worm screw assembly, failing that, replacement of the drum cleaning assembly.
Dec 07, 2007 | Canon NP 6050 Copier
CANNON NP6025
E212 is scanner home position error.remove the platen glass. Check the scanner and lense assembly.
Sep 01, 2007 | Gestetner DSc224 Copier
Problem with my copier
Mesin Saya 6035 Error 224 gimana atasinya
Jun 27, 2007 | Canon NP 6035 Copier
Canon NP 6551 Black and White Copier Logo
239 people viewed this question
old marine
old marine
