Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Xerox Workcentre Pro16fx - H4 error code after power outtage
H4 error message after power outtage.
This happened about four years ago, and the repaiman showed me how to go into TECH Mode, but I have forgotten how to do this.
John
  • javalo Feb 03, 2009
    Great Fix, It worked pefect.
    John
    President:
  • 2,072 Answers
You shut the machine off then on, Press Clear, auto,clear , auto, then when the lights go out, program it as if you were running 14 copies. press start and that should reset it.
Thats the redish pink clear button and the auto exposure button, Clear, Auto , clear auto, and the display goes blank , enter 14 and start. Dont ask me why I repeated that LOL
Posted on Feb 02, 2009
  • Rick Kasper Feb 03, 2009
    Good. And your welcome.
Control panel shows "H4"
This is a solution from the Xerox Support website (www.support.xerox.com) Give it a try and hopefully it resolves your problem. Take care & good luck.
Solution: Perform a Fault Reset 14
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
1. Find the pink Clear button on the Control Panel of the WorkCentre.
2. Find the button below the word Auto.
3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto]
NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
5. Press the green [Start] button.
6. Press the pink [Clear] button two times.
7. The WorkCentre should now warm up and come to ready.
8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Mar 03, 2011 | Xerox WorkCentre XD100 All-In-One Laser...
How do i fix an H4 error message?
That code, H4 is a fuser temperature error. You can just replace the fuser 126N00181 yourself.
Whit Item, Inc.
Dec 08, 2010 | Xerox WorkCentre XD125F All-In-One Laser...
Error code 39,003,40;61256 on a xerox workcentre
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Dec 02, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Getting message H4
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
Jul 30, 2009 | Xerox WorkCentre XL2140df Laser Printer
Xerox Pro16fx - H4 Error Massage after power outtage
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=473,E=0000000001213816584,K=3906,Sxi=8,Case=obj(6116)
Feb 02, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox pro 215, error H4 please help
H4 is a fuser error....not getting up to temperature.
Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
If this doesn't bring it back to operations then the fuser lamp needs to be replaced.
Jan 17, 2009 | Xerox WorkCentre M20i All-In-One Laser...
H4 message call service
May 27, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox xd100
See this thread, someone with a similar problem to you:
http://www.fixyourownprinter.com/forums/laser/24105
I'll summarize the solution:
The "software" H4 problem is quite common that Xerox has a resolution on its website
Feb 08, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox printer xd100
H4 is a power failure code. To reset the error please press in the following order: CLR - AUTO - CLR - AUTO (this puts the unit in tech mode). Enter 14 (as if asking for 14 copies) Press "PRINT" Your unit should reset itself and start working.
Sep 24, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
210 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
