Question about Toshiba 46HM95 46" HDTV
Just replaced lamp and still wont turn on
My lamp popped a hole in the filliment so i bought a replacement bulb, the original s/n was 23311083 and the replacement is 23311083a, every where i looked said they are the same bulb, what other parts could have been damaged when the lamp broke, or could this be the wrong bulb
  • Anonymous Mar 06, 2009
    installed a nem lamp no pic or sound
You made sure to close the access door when you got done, right? It won't come on if the door is left open.
Posted on Feb 06, 2009
Bulb popped after replacement
100% Original lamp for XV12000
USD150
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Sep 06, 2013 | Sharp BQC-XVZ100005 Projector Lamp for...
MY TAIL LIGHTS AND POWER WINDOWS BLOW A FUSE,AS AS SOON AS I TURN IGNITION ON.What could it be?
replace the tail lamps... one is dead shorting (filliment broken and grounding to the body of the bulb).
Mar 27, 2013 | Cars & Trucks
How to reset the lamp operation time on a hitachi lp700?
1,Turn the projector on,press the Menu botton
2,Press the Left ,Right,Up or Down to find the "lamp usage" and the reset option.
3,select "Lamp replacement counter Reset ?"
4,select "Yes"
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Jul 31, 2012 | Hitachi LP700 Replacement Lamp
200 Toyota Echo, tail lights do not work 7.5A fuse blows just replaced both head light assemblies flashers work dir work brake lights work
pull the tail lamps and replace them.
Sounds like there is a broken filliment floating around in the bulb and shorting to ground blowing the fuse.
May 03, 2011 | 2003 Toyota ECHO
Lamp doesnt look blown but lamp light flashing n tv wont turn on
Check the Lamp Fan if it is defective Lamp will try to light but will shut off, And the Ballast board is what turns Lamp on, For Part number o to Encompass parts distrubtion and type in your model they should list the ballast board and PN Then go to Ebay Look under Electronics type in PN, I got mine for $65.00
Lamp for $85.00
Jun 27, 2010 | Panasonic PT-45LC12 45" Rear Projection...
Why is my toshiba 46h84 picture getting darker than before? Its becoming harder to see darker scenes in movies
It sounds like your lamp is getting close to the end of its lifespan.The lamp is what gives your screen its brightness.With time they start losing this brightness.If you were to wait to replace it till it goes out completely you would have a black screen.You can purchase a quality lamp at discount-merchant.com
Apr 16, 2010 | Toshiba 46H84 46" Rear Projection...
2004 malibu low beam headllights dont work but high beam do
first check fuses and relays that give low beam lamp power if all checks out ok check bulbs youshould be able to see the filliment inside the bulb if its broken replace the bulb. if bulb check ok get a test light and check for power at the wires going to the bulbs if you have ppwer with the light switch on replace bulbs. if no power to the wires going to the bulbs replace light switch.
Jan 22, 2010 | 2004 Chevrolet TrailBlazer
Drl and high beams dont work
Check the bulbs -- the daytime running lamps use the highbeams on the resistor -- There are two filliments per bulb one high; one low. If both high beam filliments are out nothing will work....replace bulbs if this is the case.
Aug 02, 2009 | 1999 Pontiac Sunfire
Low Beam Ligths on 2004 Chevrolet Trail Blazer not Working
Check fuses & bulbs first, The headlight bulbs may be twin filiment type in which case the lower filliment may be blown & the upper filliment or highbeam will still work in this case replace your bulbs. But these models are renowned for having negative earthing problems. Follow the negative (-) or black lead from the battery to the point it is bolted to the vehicle. make sure there is good metal on metal contact with the negative lead & the vehicle. Then check the negative that comes out of the lowbeam headlight socket insure clean metal on metal contact. If you still cant find a fault, contact a chevy technician.
Jul 13, 2009 | 2004 Chevrolet TrailBlazer
Toshiba 46HM95 46" HDTV Logo
95 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
