Question about Xerox Phaser 8400 Laser Printer
Our printer (8400) light keeps turning red saying it is out of paper when it isn't. Every time this happens you have to open and shut the drawer to get it to print. How do I fix this.
    President:
  • 2,072 Answers
That sounds like a false jam. Your feed roll probably needs replaced if I am reading this correct. If you can run some prints and then that comes up I would believe it to be a feedroll problem.
Posted on Feb 02, 2009
I had a paper jam , now i have a loud clicking noise left , red light screen says door open . ive checked all doors taken toner out and put back in removed paper drawer and replaced still nothing
THE LOAD CLICKING NOISE COULD BE THE CARRAGE JUMPING IN AND OUT, DUE TO THE CARRIAGE BEING JAMMED,SWITCH OFF POWER AND TRY MOVING CARRAGE ALONG SLIDE, REASON FOR THIS ANSWER IT HAPEND TO MY PRINTER AND I CLEARED IT BUY DOING AS ABOVE
GOOD LUCK
Sep 22, 2016 | Samsung ML-1910/SEE ML-1910 Mono A4 Laser...
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
Error Message 37,004.40:194943
Turn off the printer and open the printer back door. Use a spot light and give look inside properly. Make sure there no paper. Some time small part of the paper creates the problem. So you can do one thing after open the back door, top side etc make the printer upside down etc. So if anything inside that's will come out. After cleaning again connect it with PC and turn on. Now give a look. If you face same problem then Un-install the printer driver and software from the PC. Then restart the PC and Printer both. Now connect the Printer with PC via USB and install again the driver & software. Then try to print and let me know the result.
Aug 09, 2012 | Xerox Phaser 8400 Laser Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Phaser 8400 won't print.
pull out the paper drawer and look on the ceiling of the compartment. you will see a little orange rubber roller that should be clicked inplace. it feeds the paper up into the roller. also, the drawer itself contains two sensors. if you go to the xerox page you can download the pdf that lists all the parts and the errors and how to disassemble the whole thing. i have the same printer and got a print head error and a paper jam that required complete disassembly. feel free to email me for additional help.
katriscomputers@hotmail.com
Jun 19, 2009 | Xerox Phaser 8400 Laser Printer
Paper
then you have some buried deep inside..turn light off in office, close door, and use a flashlight or penlight..paper will glow from light..that will help a bit..then long tweezers to extract the fragments, eh?
http://tinyurl.com/6qcpgy
Aug 15, 2008 | Brother HL-2040 Laser Printer
Printer problem
Are you getting any fault codes?
There are several things I can think of off hand. But with a fault code I could narrow it down for you.
Thanks
Nov 29, 2007 | Xerox Phaser 8400 Laser Printer
Paper keeps jamming
My husband and I found that if you hold down the red lever to the left of the paper drawer, you can get the unit to print. Something about the paper roller not coming down to pull the paper into the machine is why it keeps jamming. Good luck
Jul 29, 2006 | Lexmark E232 Laser Printer
Xerox Phaser 8400 Laser Printer Logo
43 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
