Question about Dell Dimension 2400 PC Desktop
How do i replace the d drive on a dell dimension dsktop
It won't open even with the pin solution, thanks
  • Dell Master
  • 2,404 Answers
Turn off the computer completely before doing anything.
on the back of the computer there is a black latch. Pull down on the latch and pull the side cover toward you and it will come off. Next this will expose a few plastic clips on the side near the front of the computer, pull slightly on the clips and this will take the front bezel off.
Now there will be two screws holding in you D drive. Unscrew these screws and then the drive will come on in the front of the computer so you have an empty bay.
Take the old screws off of the old D drive and put them in the same position on your new D Drive.
Next on the back of your drive is going to be a jumper that is covering pins, make sure your new drive jumper matches the position that your old drive jumper is in. It has to match up otherwise your computer won't recognize the drive properly.
Now go ahead and put the new drive into the bay and make sure you hook up the power connector and the ribbon cable to the back of the drive, they can only go on one way. Also be sure to put the screws back on as well so your drive stays in place.
Now turn on the computer and let it go into windows. It should auto-detect it. If for some reason windows doesn't detect it. Reboot the computer, go into the BIOS by pressing F2 and reset defaults, save changes, reboot and then windows should detect it then.
Posted on Feb 02, 2009
  • 65 Answers
The drive in the dell system is pretty standard
you can buy a new drive from sites like newegg.com or microcenter.com and replaced it with little to no problem
remove the side panel and remove the 2 screws that hold the drive in place. some dell system actually have a quick release tray for the drives. will be green in color and makes it really easy to remove the drive from the pc. disconnect the ribbon cable and power cable and reseat on the new drive.
its quite simple and shouldnt take more than a few minutes to complete this. good luck!
Dell dimension 5150 wont boot past post. I've tried afew things but nothing works. can you help? thanks
If it won't go past POST then there is a hardware error. Try removing the hard drive and RAM. The mother board should complain at power on giving messages. If it does, try fitting the RAM module by module, then the hard drive.
Apr 17, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I want to replace CD drive on Dell Dimension 8200. My options are serial ATA, parallel ATA & ATAPI. Which one do I need?
This computer has 2 IDE connectors. These are parallel ATA connectors.
See: Dell Dimension 8200 Specs
If you get a drive, look for IDE on the package. IDE, PATA and ATAPI are near synonomous. They use a 40 pin flat ribbon cable to connect.
Thanks for using Fixya.
Nov 25, 2009 | Dell Dimension 8200 PC Desktop
Del inspriron 8100... It was working but a bad fan.. opened it up (ok I know all the comments)... but now I dont even have power to the mother board..... last hope..
reseat the 120v cable for the processor and as well as the 40 pin ATX cable still if u dont see the light lit on the motherboard, u have to replace the motherboard. but before that remove the hard drive & optical drive , memory and the pci card and check once again, if no go, replace the motherboard
Oct 18, 2009 | Dell Dimension 4300 Power Supply- FREE...
The doors on my cd things won't open
There's a little pin hole somewhere on the front of the drive. Find something thin and push it in quite hard, this manually releases the drive mechanism and opens the drive.
Jul 03, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell D drive works but won't open w/o using a pin
Most likely, the little rubber belt inside is slipping or has broken.
Your best bet is to replace the drive. You can purchase a good replacement for around $30 and up.
Until then, bend one leg of a paper clip straight and push it in the little hole on the front of the drive, usually located underneath the drive door and near the button. This hole was put there to allow you to open the drive in this kind of situation.
Feb 08, 2009 | Dell Dimension 2400 PC Desktop
Trying to install hard drive on Dell Dimension 8200.
Sounds like the drive from the 4700 is a SATA drive which uses a different connector than the 40-pin IDE. I couldn't confirm it, but the 8200 may not have SATA connectors for this type of drive. Although the 4700 appears to have both SATA and IDE.
Dec 07, 2008 | Dell Dimension 8200 PC Desktop
Hard Drive Question
That is your easest option. Plug the HP drive into the open connection of the dell hd ribbon cable. U may have to pay attention to the pin selects on the hd's.
May 21, 2008 | Computers & Internet
Dell Dimension 9100 PC Desktop problem
I'm not sure where the floppy drive comes in, but if you have usb connectors on your mobo then you can connect the 5 pin connector to half of the usb pins.  Try that and see what happens.
Oct 25, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Replacing a cd rom drive
put a little jumper lieka blue or green or white cap on soem pins on rear on CS and slide it in. bolt down. put ide cable red or blue edge closest to power socket. carefull with pins pushing it in should look even if looked at from lower angle against cdrom
heres the dell steps manual http://support.dell.com/support/edocs/systems/dim2350/replace.htm#1101572
Oct 17, 2007 | Computers & Internet
Dell Dimension 2400 PC Desktop Logo
Alun Cox
