Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer freezing over refrigerator not cold
Mod GSH22SGRBSS Sn AG256045
  • jdhoward1 Feb 03, 2009
    The temperature control is digital
  • GE Master
  • 4,654 Answers
The refrigerator is not defrosting. The elements, defrost cycle or wiring to the elements are defective. Is you refrigerator digital controled or manual switches for temperature?
Let me know so I will be able to help you. JT
Posted on Feb 03, 2009
  • 2 more comments
  • John Tripp
    John Tripp Feb 04, 2009
    OK just came home and see your request all over the web!
    I did see circuit boards and the model number one place. I have not been able to point you directly to the answer.So this may take some time but we will find the answer. I believe a circuit board issue that controls time of defrost or a sensor that sends the signal from evaporator to the board is bad.
    What temp setting are you asking and what does the digital readout say?
    Below is a link to appliance service and they show pictures of parts and offer a GURU answer in 48 hours on the 800 number.
    They only offer me the answer on-line or you. I called and tried to talk to them directly.
    https://www.repairclinic.com/Appliance-P...
    I want you to get the answer as soon as possible.. JT
    Let me know, relay copy and paste our chat to them or we both along with the web. My apologies for being slow but I have worked and had no sleep.
  • John Tripp
  • John Tripp
    What year model JD?
  • John Tripp
    Save this link the blog is rolling..
    http://kitchen.manualsonline.com/ex/thre...
Food freezing in refrigerator
There has to be a balance between the freezer and the refrigerator because the refrigerator gets its cooling from the freezer, if you set the freezer to cold, the other side freezes,
Feb 17, 2014 | Kenmore Refrigerators
GSS25SGMBKBS WON'T FREEZE PROPERLY
need service manual mod DE561 power suppy pn# 1601 1502 or SP-235b
Jul 06, 2012 | GE GSS25SGMBS Side by Side Refrigerator
Ice buildup Model 795-78402-802 Kenmore SN:
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 29, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
MY freezer stoped freezing. MOD. 253.24452104
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 21, 2011 | Kenmore Freezers
My Frigidaire Mod. # FRS6R5ESB0 P/N 218888702 side by side the freezer is cold close to freeze but not freezing, what can I doo, I already clean the coil condenser and the entire back compartment. Thank...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Dec 25, 2010 | Frigidaire FRS3R5EMB Side by Side...
Whirlpool Mod ET18LKXHWo o Fridge not freezing,
Your defrost timer located inside the control panel is bad OR the defrost thermostat located on a freezer coil is bad.
Get down low and look up at the bottom of the control panel.
You will see a small round hole. Onside the hole is the defrost timer advance knob.
Use a flat blade screwdriver and SLOWLY turh the slotted knod clockwise until the refrigerator clicks off.
Wait a few minutes then open the freezer door and listen for a sizzling sound from the freezer compartment.
If you do hear a sizzling sound that would be the defrost heater melting ice.
If you do not hear a sizzling sound,unplug the refrigerator and remove the rear freezer panel to expose the cooling coil.
Clipped to the coil will be the defrost thermostat. It will need replacing.
If you do hear the sizzling sound the defrost timer will need replacing.
Jul 20, 2010 | Whirlpool Refrigerators
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Bottom freezer "on" but not freezing and not making ice
Refrigerator running but not that cold, freezer running also but not freezing at all. Also not making Ice
May 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer freezes, refrigerator is 55 degrees
All refrigerators also have a return air vent. You need to make sure this is not blocked by frost, the units own foam insulation or even by product placement. You should find it behind the crispers in the bulkhead between the freshfood and freezer compartments. You also want to verify the supply duct behind the damper is not blocked.
May 03, 2009 | Refrigerators
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
138 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
