Question about HP Pavilion dv1000 Notebook
Opens for a short period of time only and then turns off again.
Can use it for only 10 sometimes 15-20 minutes only. If it turns off the light on the function keys is still lighting but the monitor is already black and the computer is not working anymore. I have to press and hold the power until all the lights turns off. But sometimes it turns off completely. The blue light in front which looks like a lightning will also turns off after a while.
If i use it for only a short time and shut down the computer the blue light (lightning icon in front) turns off even the computer is still plugged in the outlet. It was like the battery wasn't charging anymore or the battery is already full.
Thank you very much in advance.
Jolli
The problem is already solved. I bought a new battery and changed it.
Posted on Feb 03, 2009
Have a Remington space heater, runs for approx. 10 min. then shuts off, then if unplugged or switch turned off, then it will start again for short period of time
There may be an overheating sensor that is causing shutdown after 10 minutes. After a cooling off period, it is ready to heat for another 10 minutes.
Dec 04, 2016 | Heating & Cooling
Interior lights stay on wile i'm driving my 2005 lincoln navigator
Only one bad door switch should do that
The 20 min time out is the GEM or Body Module,
which is normal only because you have a bad switch,
otherwise it goes to sleep when either front door opens
Put radio on & open a door,the radio should go off
& kill the time delay if no issues exist
Feb 05, 2013 | 2005 Lincoln Navigator Luxury
Have had no major problems until now - New Years Day. Tried to start auto. When turning key in ignition, all lights on dashboard clicked on and off repeatedly. However, motor would not turn over. ...
Hi
Sounds like the battery is failing or you have a bad earth from the battery to the car body, the black wire. I would check them first before going any further.
Regards
Dan
p.s try and disconnect the battery for 10 minutes then reconnect this sometimes works, resets the cars computer.
Jan 01, 2011 | 2007 Ford Fusion I4 SEL Sedan
Whirlpool front load washer LHW0050PQ often will not start
Unplug the washer for 10 min. This will reboot the circiut board. Select one cycle. Selecting too many cyles in a short period or pushing too many buttons in a short period can overwelm the little brain in the board.
Apr 30, 2009 | Whirlpool LHW0050PQ Front Load Washer
Maytag neptune error? message
Unplug for 10 min to reboot the curcuit board. This will reset the system. Sometimes selecting numerous cycles or pushing buttons a lot in a short period of time can overwelm the little brain in the curcuit. This action will clear the memory of any unwanted comands in the curcuit.
Apr 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Car starts then dies
Your antitheft system is shutting it down. You need to reprogram it. First hook up a battery charger. Then turn the key on. The security light should blink on and off. Leave the key on for 10 minutes. At the end of ten minutes, the security light will stop blinking. When it does turn the key off for five seconds. Then turn the key on. Repeat the 10minutes. Turn the key off then on. Repeat the 10 minutes a third time. At the end of the 3rd ten minute period , start the truck. It should be reprogrammed and continue to run.
Mar 10, 2009 | 2002 Chevrolet Silverado
HP Pavilion dv1000 Notebook Logo
103 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
