Question about Avanti FF100 Top Freezer Refrigerator
Refrigerator frost free froze up
I have a avanit ff991w it is frost free and it froze up
Frig turns off unexpectedly and you have to manually turn switch all the way off and then back on and it starts running again, what could be the problem
Hi, it sounds like you have a thermostat / switch problem one or both could be the problem best get it looked at.
Apr 28, 2016 | Avanti FF991W Freestanding...
Frost build up in coils in my freezer it is supposed to be froze free
Frost free Refrigerators go into defrost cycle every 6-12 hours depending on model.
If frost become visible, on of the defrost system (Defrost timer,Defrost heater, Defrost thermostat) components has failed. The most common failure is the defrost time. If you can locate the time, try to advance it (rotating) into defrost and if you see water coming into the drain-pan within a couple of minutes, than the Heater and thermostat are OK and you need to replace the timer (relatively easy job). If no defrost occur , you better call a tech and avoid replacing unnecessary parts. Caution - Some defrost timer are incorporated into the Ice Maker mechanism are hard to test and must replace the entrie Ice Maker
Aug 18, 2014 | Amana ABB1927DE Bottom Freezer...
My Proline freezer has the warning on and won't get cold
if it is a frost free type it could be froze up.look for frost on the bottom back inside wall of the freezer,if you find frost there one of three things have failed,the defrost timer,the defrost heater or the defrost t-stat.if this is the case you will need to call your repair service to check it for you.too much electronics on all this stuff today i think.if on frost,check the cond. coil be hind the toe plate under the doors.this needs to be cleaned every 3 or 4 months.hope this helps.
Apr 16, 2014 | Refrigerators
Frost every thing
I assume you mean frost in the freezer only, not in the refrigerator compartment.
There are a lot of mechanical problems that might cause frost to build up. The unit has a defrost timer to defrost the freezer and it might be broken.however, more likely, the freezer door was left ajar letting a small amount of outside air in, which condensed and froze.
Check to see that freezer door is fully closing and is not being block in any way. Recheck after 6-8 hours and see if frost is gone. If it is still there, repost your question along with make and model of your unit. J
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Feb 10, 2011 | LG Refrigerators
Older (serial # erased) GE freezer top frost free Water pools in bottom of frig. cannot find drain.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Drain is under the coils and may be froze shut...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Sep 11, 2010 | GE J Series 18.2 cu. ft. Top Freezer...
Freezer froze,ice and frost,freezer door froze, warm in fridge
change thermostat sensors in fridge and freezer easy
Feb 04, 2010 | Refrigerators
Refrigerator won't stay cold but freezer works fine.
check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
Sep 24, 2009 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
I have a top-mount Frigidaire Gallery frost-free freezer, and everything in the freezer and the freezer interior is covered with ice crystals. Suggestions?
Sep 24, 2009 | Frigidaire FRT15B3A Top Freezer...
Avanti FF100 Top Freezer Refrigerator Logo
44 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
