Question about Daltile Bathroom Accessories Resin Soap Dish Ceramic Tile & Stone
Installing a resin shower soap dish,
I have a resin soap dish made by "Fired Earth Ceramics". It has a perfectly flat back side. It's going to be mounted on Green Board. Will Liquid Nails be a satisfactory adhesive or would you recommend something better. The surrounding tile is being installed with mastic, but the mastic can says specifically not to use it to install fixtures.
    Problem Solver:
  • 19 Answers
Liquid nails will do the job but you can also use clear silicone provided both surfaces are dry.
Posted on Feb 03, 2009
  • 2,694 Answers
You can use the grout that your gonna grout the walls with,put a glob of it on the back of soap dish and push it and move it around and remove the grout that pushes out,you can knock a hole in the center of the wall so when you push the soap dish in the grout will go into the hole and harden forming a ball bigger than the hole and when it hardens it's like a molly holding the soap dish on the wall really good,you should always use cement board instead of green board
Posted on Dec 15, 2009
How to replace soap dish on kohler mastershower slidebar. can't seem to take it apart.
Dear Sirs,
You have to deassamble the part then you can take of the shop dish
Oct 10, 2013 | KOHLER MasterShower Three-Way Brushed...
Bathroom tile
If I need to replace a broken recessed soap dish in the shower then I would definitely contact with a professional as they can fix this problem very easily.
Jul 16, 2013 | Home
We had corner soap dishes installed in our newly remodeled shower stall. But the water does not drain off just sits. The soap dish does have a small dip in the outside rim. The contractor says it is...
I have the same problem with my stone corner soap dish. It used to drain ok but recently water just sits on the dish and mold grows. Unless we get a good solution, I plan to drill holes into the dish to let it drain.
Feb 12, 2011 | Daltile Bathroom Accessories Resin Soap...
Caulk coming off in Corian stall shower
If you have the option of not using the shower for a while, I would put a dehumidifier in the shower to **** the mositure out from below. If cost is no object, you can go ahead and pull the base. The key to the caulk is to completely remove the old caulk, clean carefully and use a silicon based caulk. Be sure to let it dry properly (see caulk cure times on tube).
Dec 30, 2009 | Daltile Bathroom Accessories Resin Soap...
Can I put the crock pot (pot part only) in the oven at 400 degrees?
Short answer NO! it will crack Most are low fired ceramics putting in ovens will cause them to crack open
Aug 31, 2009 | Hamilton Beach 33158 Double Dish 5-Quart
Cannot find 2 tile soap dish-back wall that measure 4"hx8"wide.
contact Daltile to see if they have a replacement. If they do you will have to have contractor purchase for you as Daltile does not sell to general public
May 31, 2009 | Daltile Bathroom Accessories Resin Soap...
Cutting resin tile
You need a tile saw that uses water to prevent sparking. Home Depot, Lowes..........<$100
Apr 24, 2009 | Daltile Bathroom Accessories Resin Soap...
Cloudy Dishes
Salt? i know you said you have soft water but probably not enough, the salt replenishes the resin beads so you get a rinse with pure water on the final rinse.
Jan 16, 2009 | GE 24 in. GSD2120C Built-in Dishwasher
Daltile Bathroom Accessories Resin Soap Dish Ceramic Tile & Stone Logo
969 people viewed this question
Top Daltile Home Experts
Mike
Sal De
woodzowl307
Are you a Daltile Home Expert? Answer questions, earn points and help others
