Question about Sony Grand WEGA KF-50WE620 Television
Sony KF-50WE620 - 5 Flashes
I purchased a new lamp for my Sony and the TV powers up but not the lamp. It flashes green for about 30 seconds then turns red with a series of 5 flashes. If I hit the power switch a second time it changes to 4 flashes.
Any assistance would be appreciated.
  • 1 more comment
  • mafmd019993 Feb 02, 2009
    I recently purchased the TV for very little and was told that the lamp was no good and it was taken out. I have a Philips OEM lamp.
  • ed0369 Feb 28, 2009
    I purchased a new lamp but need to know where to locate the old one
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    May I know why you replace Lamp? what were symptoms of TV that you decided to replace lamp?
    Genius:
  • Sony Master
  • 1,039 Answers
5 flashes indicates ballast malfunction. 4 flashes indicates fan not working. I would replace the big fan in the back because it is a common failure for this model. But befor this check to see if the lamp door is warped from overheating. If it is the wiring on the balast good be burnt and the light engine could be damaged.
Posted on Apr 26, 2009
I have a Sony kf-50we620, It started having problems this week. Sometimes, not always, I turn it on, the green light flashes and the TV will eventually start but it takes over 2 minutes to start. I will...
Its symptoms of weak lamp that need to be replaced.
How old is this TV and did you replaced its lamp recently?
lamp replacement is easy and would be written in user manual. Please buy Sony original lamp for TV safety.
Thanks.
Jan 15, 2010 | Sony Grand WEGA KF-50WE620 Television
New lamp turns on flashes 7 times
Just a thought...you *might* have a bad ballast in addition to that defective power supply.That flashing could be the ballast trying to ignite the lamp. A lamp is just like an enclosed welder's arc. The ballast generates a high-voltage spark to initially start the lamp, then low voltage with high current keeps it burning. If you look into the lens and see "lightning" flashes but no lamp ignition, that's what's happening. The ballast could've been damaged by the defective supply. Also, try a known-good lamp...just to rule out a defective new one--in the shop, we kept all old working lamps as testers.
Aug 30, 2009 | Sony XL-2100U Projector Lamp for...
Red and green light flashes then lamp light comes on
If its Sony KF-42SX300 TV then replace lamp in TV,
Lamp replacement procedure is written in instruction manual.
Please buy Sony original lamp for TV safety and avoid aftermarket/ cheaper lamp.
Jul 25, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
5 blinks code shows problem with Lamp Drive circuit (ballast supply) and / or Lamp itself.
How old is this TV and have you replaced lamp before?
May 31, 2009 | Sony Grand WEGA KF-50WE620 Television
No picture, no sound, power button blinks 47 times, then lamp flashes 134 times, then shuts off
It is symptom of weak Lamp in your TV, replace Lamp with following part number..
A1606034B LAMP BLOCK XL-2100U
It is available in Sony Accessories for $200
Always buy Sony Original Lamp for your Sony TV and avoid aftermarket/ cheap lamps.
Apr 22, 2009 | Televison & Video
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Dead sony
The $1200 was for the lcd engine not the lamp. You should change the lamp. The buzz is the power supply trying to light the lamp.
Apr 25, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sony KF-WE50
my front panel sound is not working.......?
how i can do this.?
Jan 05, 2008 | Sony Grand WEGA KF-50WE620 Television
Televison & Video Logo
337 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
