Question about Miele Novotronic T220 Electric Dryer
Miele T358C dryer. water not being pumped out of the sump??
Sump is under the condenser, this fills with water and then the machine goes to cold spin and the alarm lite goes on indicating the removeable pan is full...altho the machine has been plumbed to dump water out of the vent at the rear.. I bought it old second hand.
  • 29 Answers
TRY THIS:
TRY THIS:
In some cases cleaning the condenser out and drying the unit well will allow the unit to function again. Once a month you need to empty the condenser unit, it is normal for there to be some water in the tubes when you do this, you then have to flush the condenser by pouring water through it in either your sink or tub. Make sure that there is plenty of room around the drier for air circulation; and empty the water container often or reconfigure your pluming arangement to reduce the water left in the container. The circuitry of this unit it sensitive to high humidity and can cause the unit to not function properly. So with condensing dryers you have to work on keeping them clean. Let me know how it goes. Later :?) DRRXR
TIP OF THE DAY--
To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not running straight through) then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. Remember this tip on future driers and you will make the dryer blower motor last much longer.
Posted on Feb 08, 2009
Miele W1918 washing machine question:
Check the rotor again very carefully - something like a pin or piece of grit, a nylon tag or piece of wood that floats clear can be very hard to spot. Can you turn the water pump rotor manually with something like a long screwdriver, or is it stuck? Will need a replacement if seized as freeing it will only fail again. Some coins or 'Tazzos' - ie kids toys / counters can flip on edge and completely block a hose under the 'right' conditions.
Are you sure the drain tube is clear at its connection with the waste pipe / sink trap? Another possibility is a sock or pants stuck in the sump hose completely blocking it - or have you washed the dogs blanket or bathmat etc that has shed fibres blocking the sump.
Feb 03, 2018 | Miele Washing Machines
Machine fills with water and over flow alarm goes off before float is activated.
Check either the pressure chamber & sump hose or the impellor jug ( a small white disk fitted in line of inlet hose
Sep 29, 2015 | Bosch SHX68P05UC Dishwasher
Zanussi condenser dryers
It can be mechanical or electrical malfunction. I would check tank microswitch, float and lever.
Below is explained how the condensate drainage system works and that will facilitate fault detection.
The warm and cold air circuits cross inside the heat exchanger, which results in a thermal exchange which condenses the humidity contained in the warm air. The condensation which forms in the heat exchanger is collected in a sump, from which it falls by gravity into a tank. When the water in the tank reaches the max. level, the level of the water in the sump increases, which causes the float to move upwards, thus actioning a microswitch; The microswitch for dryers with electronic board sends a signal to the electronic circuit when the tank has been filled, switches off the appliance and lights a pilot lamp which indicates to the user that the tank is full. The microswitch with electromechanical control switches off the dryer (the timer motor is powered and ends its cycle) and lights a pilot lamp which indicates to the user that the tank is full.
Dado
Aug 10, 2014 | Zanussi Dryers
Aeg slimline dishwasher 64800. AL5 alarm, but fills up
This control procedure is in operation only during the cold wash and heating phases.
  • Once the pressure switch has closed in the "full" position, it must remain "full" until the subsequent drain phase; if the pressure switch signals "empty", the fill solenoid is activated for a period equivalent to the period of aperture of the pressure switch.
  • The maximum aperture time for the pressure switch (T) during the entire phase is 60 seconds; if this period is exceeded, an alarm condition is generated.
Alarm: AL5
Possible causes:
  1. Dishes upside down
  2. Central filter clogged
  3. Siphon effect created in drain hose
  4. Leakage in sump - pressure switch tube.
Dado
Mar 02, 2014 | AEG 18 in. Favorit 64800 Free-standing...
Hoshizaki Model KM500MAH
When first turned on, the sump should fill with water. If it does, water solenoid is good. If you have a full sump, and no water pump running, sometimes the "Ice/Off/Wash" switch is bad. Put switch in wash, if pump runs, it's good. Now put in Ice position, if sump fills and pump does not come on and compressor indicates it is in the freeze cycle, replace that switch first. Simplest place to start and lest costly to fix.
Oct 04, 2017 | Hoshizaki Freezers
Machine runs cold water but will not make ice, pump runs and everything else works.
Check the condenser coil to make sure it is cleaned out, also make sure the condenser fan is no dropping out. Next check to make sure the water fill valve is not seeping water past into the sump tray if so than it will not freeze, Water will get cold but not cold enough to freeze check water temp in sump tray with a thermometer to make sure it is getting down to 32 deg.
Oct 01, 2013 | Franklin Industries Franklin Chef FIM200...
Water collecting in the pan underneath the fridge.
it should do this but the water should evaporate from the heat from the condenser and compressor,when the machine goes into defrost a heater comes on and melts all the frost off of the coil,the water drains down into the pan where the water will evaporate,when was the last time you cleaned out the condenser coil?remove the front bottom kick panel and check the coil,if it's filled with dust it has to be cleaned out at least once a year especially if you have a cat or dog,then pull out the machine unplug it or shut off the control and remove the bottom back panel,the easiest way to do this is to vac up as much dust as you can with a shop vac,then set it for blow by putting the hose on the other end of the shop vac and blow the dust out of the coil,you can buy a condenser brush that will remove dust thats stuck inside the coil but the shop vac works great,through the condenser this is how the heat escapes out of the machine,also clean off the fan motor in the rear,also there are plastic water lines that come out of the water valve that could be cracked going to the ice maker and water dispenser or the valve itself could be cracked causing this problem or the pan could have a crack in it,very unusual for the pan to overflow,when you're done cleaning it plug it back in,make sure the fan is running fine and have someone fill a cup of water and check the plastic lines coming from the valve to see if it leaks,pull out the pan and check it for cracks,fill it up at the sink and check it,if everything looks good you can shut off the water valve that goes to the fridge for a few days and keep an eye on the pan,like i say it's unusual for the pan to overflow just from the defrost water,if the water is evaporating with the water shut off then you have a crack in one of the water lines going to the ice maker or dispenser
Aug 05, 2012 | Amana ASD2522WRS (251 cu ft) Side by Side...
417-44052400 Fills with water, washes, drains/spins then comes to a stop. If I did the diagnostics right it indicates E11? Anybody else have this problem?
e11 is a water problem filling to slow,you could have a problem with your cold water fill line,clogged sediment in the valve or something like that,when it goes into rinse the machine uses cold water so the clothes won't wrinkle and it sounds like it's filling to slow.
Nov 26, 2011 | Washing Machines
Dont know how to drain water out machine, I have no manual
By putting it on the "fast spin" program the water should drain out. if not you have a blockage so check the following
first keep it simple, ensure outlet hose is not blocked or kinked....but if not follow these steps
  • To sort this isolate from mains
  • take off back inspection panel.
  • tilt machine forward- get sum1 to hold it for u.
  • The sump is the black hose attached to drum.
  • place a basin under this and loosen jublie clamp using star head screw driver/ 8mm socket,
  • pull sump downwards and remove any blockage.
  • note the plastic ball is part of the sump assembley.
  • refitt the sump again and tighten clamp, pull down firmly on sump to ensure fitted correctly
if there was nothing in the sump it is sumthing jamming the pump, hairgrip, nail, etc.
tilt machine forward as above with a basin ensuring isolated from mains power
  • pump is attached to other end of sump hose, right side of machine as you look in the back.
  • using flat screwdriver lift plastic tag up and slide pump assembley to the left releasing it from base of machine
  • clip of plastic cover from top of pump
  • remove wires from pump
  • u should now be able to turn pump around so u can see 3 hex head screws
  • remove screws taking note of the position of pump
  • remove pump and clear blockage
  • reverse steps to reassemble
if this does not sort it poss a new pump needed
from,
hotpoint ace
Jan 05, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Miele Novotronic T220 Electric Dryer Logo
963 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
