The washer introduces black/brown bits of something all throughout the clothes. it does this intermitently from wash day to wash day. the stuff is relatively thin amd pliable and sometimes shaped in 3-d configurations. how do i get rid of this??
    New Friend:
  • 33 Answers
Empty and wash out the filter. Take out the soap dispenser drawer and clean both this, and the housing thoroughly with a toothbrush. Run an empty cycle with Calgon (available from most supermarkets), then run a couple of empty boil washes. This should solve your problem. If not, check your water inlet pipes, and if there is not one already there, you can buy a filter which sits on the end to catch anything which may be coming through in your water supply. If this is the case, dont forget to rinse them occasionally.
Posted on Feb 06, 2009
Large dark brown spots appearing after washing
Normally a washer does not cause a staining problem, but If something inside the washer has rusted, it could. I would check your water tank. Drain water from the drain cock at the bottom of the tank, and see how dirty it is. If it is dirty, you need to drain the water until it is almost clear.
Aug 13, 2015 | Frigidaire ATF6000ES Front Load Washer
There is black stuff down under where u put the washing softener and it is getting through the washing!
Put a cup of malt vinegar through a whole wash cycle (without clothes in it). Cuts all the grease away from throughout the machine.
Mar 15, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Why is my washer leaving black stains on my clothes
It sounds like it might be leaving mold deposits. Try running a cycle with no clothes in it, hot, with a cup of bleach. If the stains are more brown than black, though, that would be rust in the pipes.
Oct 16, 2010 | Kenmore 44102 Front Load Washer
Hi. I have a Kenmore Elite top-loading washer and in every wash load there are flakes of brown stuff, not rust but more like leaves. There does not seem to be anything wrong with the outflow. Thanks!
Run a few washes of rags or towels with plenty of BLEACH & VINEGAR (two quarts of white) a couple of times to remove most bacterial debris from your machine. There is no part of the machine that "creates" brown flakes, so it is either in the water inflow (check the water) and the way to see what is coming into the machine is to do a "load" without any clothes! Just have the tub fill and look at what fills.....Sounds like something under the tubs upper lip that's coming-off and into your tub during the wash and agitation cycles.
Oct 08, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Black bits coming out with water.
Probably mould, wash with bleach and leave the door open when not using the washer.
Apr 17, 2010 | Washing Machines
Wrecking our clothes!!!
Check the water temperature - it may be filling with HOT only.
If this is the case - replace the dual inlet water fill valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Washing Machines
Brown Gunk
sound like mildue issue, there is a product out there called Affresh that will remove the mildue can get it at lowes item number is 163338 about 7 dollars
Apr 10, 2008 | Kenmore 44042 Front Load Washer
Hotpoint 761 washing machine, leaving metal particles in clothes
If you are itching, do you have an allergy?? to the powder you are using? if there is mold and you cant shift it, may be worth you talking to the manufacturer after seeing the doc. They will also recommend what powders for you to use with their machine.
Nov 23, 2007 | Hotpoint Aquarius WMA52 Front Load Washer
Washing Machines Logo
350 people viewed this question
Top Washing Machines Experts
