Question about Pride Mobility Products Casual CL30KD Lift Chair Chestnut
Pride Lift Chair
I read an solution you typed about a lift chair making a clicking noise under the chair but doesn't move. You mentioned to "short out the center wire" on the controller. Is that the same as "jumping out the center wire". I'm not sure what you meant. I have the same problem with our chair.
Thanks
  • 118 Answers
Yes, jump, short, somehow bypass the switch and see if the chair moves. In 4 of 5 cases, I have had to replace the switch. Its the only part I carry with for "spares". Its an easy fix, and a lot cheaper than replacingt the whole hand control.
Posted on Feb 03, 2009
The speed lights keep flashing. It still moves.
The speed light flashing usually indicate that the chair is in "Limp Mode" This could be either the motor is getting too hot or the chair has a lift on the seat. If the chair runs fine for a while and then this condition appears, you may have a bad motor or a brake dragging causing the motor to get hot. the controller will allow less power to the motors to help it cool down and still keep you mobile. If you have a lift on the chair that raises up the chair, you will have to lower the chair down to gain the full power back. If neither one of these solutions are the problem, then you will need a Tech to come out and look at the problem. you may have a more serious problem that a tech can troubleshoot.
May 11, 2015 | Pride Jazzy 1103 Ultra Standard Power...
Hi i have a pride jazzy jet 3 and i need to lift my chair using a hoist to put in the back of my car but can't find any bracket on the chair to lift it can help me please.
Contact the manufacturer of the lift for the brackets. Depending on what type of lift it is, you will either order the bracket from them or from a Pride Mobility Dealer or the lift dealer
Apr 05, 2014 | Pride Mobility Products New Pride Mobility...
Pride lift chair. Goes up, but will not down
There are only three wires for this. either the wire is broke, or the switch.
Oct 15, 2013 | Pride Mobility Products Casual CL30KD Lift...
Lift chair does not work
Contact dealer first. If no dealer, then contact "Pride Service Center." Should be listed on your receipt.
Jan 12, 2013 | Pride Gl 358L Electric Lift Chair Riser...
Clicking noise when moving
This noise can vary depending where its coming from .If its coming from the front of the chair it could be your front wheels may have bad bearings that make the click each time you move .Or if its coming From the back it could be you break engaging and dis engaging. I would proably look at the casters first .
Good luck .
Jan 13, 2011 | Pride Go Chair Travel Power Chair
Can I or how can if possible return the Pride Lift Chair to normal seating position manually.Thank you.btrapp@sasktel.net
The easiest way to do this is to tip the chair forward so that the top of the chair and the arms are on the floor. The weight of the chair will be off the lift frame in this position. Look at the motor and you will see it connected to the frame with 2 hitch pins.
It is easiest to remove the top hitch pin which will now be on the bottom because the chair is upside down. Pull the clip (looks like half of a paper clip) from the pin that goes through the square chair frame and motor round tube. Pull out the pin by lifting the bottom of the motor slightly(now at the top because the chair is upside down)with your left hand and pulling the pin out with your right hand. Find the two nylon washers that have fallen out when you do this.
Swing the motor tube out of the way toward the front of the chair. Hold on to the pin, clip, and 2 nylon washers for re-assembly. Hope this helps.
Dec 26, 2010 | Pride Mobility Products Casual CL30KD Lift...
What would cause my lift chair to move extremely slowly and stop altogether?
I am going to say the motor or the control switch have gone bad. Most of these chairs are made without relays to control the motor. A switch will wear out due to the current goin across the contacts if a relay is not used. Check the switch in the control. If this is helpful, please leave feedback. Thanks,SnugglePants
Nov 03, 2009 | Pride Mobility Products Casual CL30KD Lift...
Pride jet3 makes noise when engaging forward motion
Sounds like your motors are gong out. You`ll need to get to a reputable dealer for further diagnosis.
Mar 28, 2009 | Pride Mobility Products New Pride Mobility...
Chair will not go up or down
The clicking is the mechanical part of the switch, but the electrical part may still be bad. In all the chairs I have serviced, it has always been the switch. The switch itself goes for about $25 plus labor to change it, and the whole control unit retails for about $100. the best test is to take the controller apart and short out the center wire to either side and check the chair for movement.
Jan 22, 2009 | Pride Mobility Products Casual CL30KD Lift...
Pride Mobility Products Casual CL30KD Lift Chair Chestnut  Logo
851 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
