Question about ViewSonic PJ350 Multimedia Projector
ViewSonic PJ350 will not display AVI clip in powerpoint presentat
I have an AVI clip (7meg, 21 sec, 320x240pixels, bitrate 88kbps, 8 bit audio, 15 fps, data rate 330 kbps) that I am attempting to run within a slide in a Powerpoint presentation. Whenever I run this slide, my projected screen turns black. Projector will not render the video. I even tried an s-video cable from the laptop to the projector with the same result.
I did run the video through Media Player, and it showed up on the top half of the projected screen but was "squashed". How can I show this video in a powerpoint slideshow presentation?
bapplay
  • 40 Answers
SOURCE: Shrinking Screen Display
It can be a problem with teh bulb...you may want to make sure that the fan is not shutting down when you power off the projector becsue that may shorten the life of the bulb,...the fan should remain on for a while to continue cooling off the bulb....it probably won't hurt to have use another fan pointing to the projector while in use...
Posted on Apr 30, 2007
Gurudristi
  • 98 Answers
SOURCE: dvd player to projector
Yes please.
You can connect it either thru the RCA Composite output(yellow) of your DVD or thru the S-Video or even thru the component out(YPbPR) connections. In the component out you would require three RCA cables and would give you the best possible picture.
Find a link below , which gives a review of the Viewsonic PJ 501.
http://reviews.cnet.com/home-theater-projectors/viewsonic-pj501/4505-7858_7-20722971.html
Hope this clarfies.
Please do rate this solution and thanks for using FixYa!
Posted on Mar 05, 2009
  • 6 Answers
SOURCE: Viewsonic Projector PJ506D not working
proable solution the cooling fan is giving problems. the whistling sound most likely is fan rubbing on a wire??? The unit gets over heated and turns off for protection. Good luck
Posted on Aug 19, 2009
  • 75 Answers
SOURCE: Can't get my Viewsonic projector to project an
Hold the FN+CRT/LCD or (it could be an icon/image of a screen) simultanesouly and then keep press the CRT/LCD key it should eventually get around to displaying an image on just the projector or projector and laptop screen
Posted on Jun 09, 2010
  • 8909 Answers
SOURCE: My viewsonic projector shows overheat
Are the air filters clean? It may have a faulty temperature sensor or indeed the temperature sensor may be disconnected.
Posted on Feb 12, 2011
Hi im trying to watch a show on my xbox and it keeps coming up with status code 69-c00d36be???
There are many correct answers to this question. Here's one...
I suggest you use mencoder or ffmpeg. Neither are really well documented, so you need to tinker.
A simpler, more expensive answer is to use TMPG Enc 4.0 Express. I purchased and use it daily.
-- from the xbox web site:
**1. What exactly does the Xbox 360 support for AVI?
Xbox 360 supports the following for AVI:
· File Extensions: .avi, .divx
· Containers: AVI
· Video Profiles: MPEG-4 Part 2, Simple & Advanced Simple Profile
· Video Bitrate: 5 Mbps with resolutions of 1280 x 720 at 30fps. See question number 11 for more information.
· Audio Profiles: Dolby® Digital 2 channel and 5.1 channel, MP3
· Audio Max Bitrate: No restrictions. See question number 11 for more information
2. What exactly does the Xbox 360 support for H.264?
Xbox 360 supports the following for H.264:
· File Extensions: .mp4, .m4v, mp4v, .mov
· Containers: MPEG-4, QuickTime
· Video Profiles: Baseline, main, and high (up to Level 4.1) profiles.
· Video Bitrate: 10 Mbps with resolutions of 1920 x 1080 at 30fps. See question number 11 for more information.
· Audio Profiles: 2 channel AAC low complexity (LC)
· Audio Max Bitrate: No restrictions. See question number 11 for more information.
3. What exactly does the Xbox 360 support for MPEG-4 Part 2?
Xbox 360 supports the following for MPEG-4:
· File Extensions: .mp4, .m4v, .mp4v, .mov
· Video Profiles: Simple & **Advanced Simple Profile
4. What exactly does the Xbox 360 support for WMV (VC-1)?
Xbox 360 supports the following for WMV:
· File Extensions: .wmv
· Container: asf
· Video Profiles: WMV7 (WMV1), WMV8 (WMV2), WMV9 (WMV3), VC-1 (WVC1 or WMVA) in simple, main, and advanced up to Level 3
· Video Bitrate: 15 Mbps with resolutions of 1920 x 1080 at 30fps. See question number 11 for more information.
· Audio Profiles: WMA7/8, WMA 9 Pro (stereo and 5.1), WMA lossless
5. Can I mix and match the video and audio codecs outside of those defined in questions 1 through 4 above?
No you cannot. We only support each audio and video codec in the explicit containers defined in questions 1 through 4.
6. How can I determine if a video file that I am trying to play conforms to the specifications as laid out in questions 1 through 4?
You can use a 3rd party tool to analyze your video files to determine what audio and video codec is used. A popular 3rd party tool to analyze video files can be found athttp://www.headbands.com/gspot/.
7. How do I create WMV, AVI, H.264 and MPEG-4 content? What encoders does Xbox 360 support?
You can create this content on one of many 3rd-party applications. Xbox 360 supports many popular encoders. Specifically for encoding to WMV you can use Microsoft Expression Encoder or Windows Media Encoder.
**8. What specific features of Mpeg-4 Advanced Simple Profile does the Xbox 360 support?
The Xbox 360 supports Bidirectional Frames (BVOPs), Interlaced Frames, Quarter Pixel Motion Compensation, Global Motion Compensation, and MPEG Quantization.
9. What are the different ways to play video content on Xbox 360?
You can play video from a USB 2.0 FAT32 removable drive, optical media, and by streaming from the Zune software, Windows Media Player 11, or Windows Home Server.
10. What are the different video codecs that are supported in all the different ways to play video content on the Xbox 360?
See table below for more information:
on.
Jun 30, 2011 | Video Game Consoles & Games
Tip
How to burn avi video to dvd
What's avi?
AVI stands for Audio Video Interleave. It is a special case of the RIFF (Resource Interchange File Format). AVI is defined by Microsoft. AVI is the most common format for audio/video data on the PC. AVI is an example of a de facto (by fact) standard.
what's dvd burner ?
A DVD burner is a device used to encode or "burn" information onto a blank DVD. A DVD is a form of storage media 12 cm (4.72 inches) or 8 cm (3.15 inches) across that can typically hold 4.7 gigabytes (GB) of information, enough to hold a three-hour movie at high quality, or ten TV episodes, or about 75 hours of .mp3 files, or roughly 15 hours of video in the lower-grade .avi format. The DVD is thought of as the successor to the conventional CD (compact disk). Common formats include DVD-R and DVD-RW, a rewritable version of the DVD.
step by step guide on how to burn avi video to dvd
Download Video Converter, install and run it.
Step1. Click "Browse"to import your AVIs in the software. Or select and drop them in! Double click the file name to have an instant preview.
Step2. Click "Edit Profile" to adjust video effects, trim for a video clip and crop for a proper video dimension. Choose "DVD-Video Format( *.vob)", and set the output folder in "Browse".
Step 3: Settings of AVI to DVD Converter.
(1) Click drop-down button next to “Edit Profile” on the main interface to find the suitable quality for your output.
(2) Click “Edit Profile” to open the “Settings” interface to make detail settings for output audio and video, such as audio and video codec, quality, bit rate, video frame rate, video size, audio sample rate, etc.
Step4. Click “Convert” button in the bottom left to start the AVI to DVD Converter, and then burn your VOB files to a DVD or CD for easier carrying. Fast conversion speed!
on Jul 29, 2010 | Computers & Internet
Tip
Play videos on Xbox 360 and stream videos to Xbox 360
How to play videos on Xbox 360 and stream videos to Xbox 360 – including Blu-ray, DVD movies, and videos in various file formats
This tutorial intends to list out all the video formats supported by the Xbox 360, and explains all the available ways to play videos on Xbox 360 in HD quality or stream videos to Xbox 360. The videos include Blu-ray movies, standard DVD movies, and various other videos, such as ISO image file, Camera footages, MKV, MTS, VOB, M2TS, TS, TP, FLV files, etc.
Let's Get Started.
Part 1: The details of Xbox 360 supported file formats
1. AVI:
Containers: AVI
Audio Profiles: Dolby Digital 2 channel and 5.1 channel, MP3
2. H.264:
Video Bitrate: 10 Mbps with resolutions of 1920 x 1080 at 30fps. Audio Profiles: 2 channel AAC low complexity (LC)
3. MPEG-4:
Video Profiles: Simple & Advanced Simple Profile
4. WMV:
Container: asf
Notes: You can not mix and match the video and audio codec outside of the above defined lists randomly.
Part 2: Different ways to play videos on Xbox 360
With regard to playback videos from a USB storage device, please note that the Xbox 360 will support as big of a storage device as you can format using FAT32, and the maximum size of any single file on FAT32 is 4GB. Besides that, the maximum file size for an AVI, MPEG-4 Part 2, and H.264 file that can be played is 4 GB as well. To play a file greater than 4GB on Xbox 360, you can use Windows Media Player 11 and the Zune software to stream videos from your PC to Xbox 360 console, and notice that the file format must be WMV only. Why is it so special with a WMV file? That maybe WMV is a codec developed by Microsoft.
Well, that is to say, to some extent, we can consider WMV as the optimal format to play or stream to Xbox 360. When you are gonna watch a Blu-ray/DVD movie, or an MKV video, or some files else that are out of the range of Xbox 360 workable formats, what is your solution? We usually make use of Pavtube Blu-ray Video Converter Ultimate to do format conversion. Why do we choose it? Mainly because of its splendid output quality and its feature of an all-in-one application: a Blu-ray ripper, a DVD ripper, and a versatile video converter.
Part 3: How to convert Blu-ray/DVD and videos to WMV for play/stream on/to Xbox 360
We have mentioned in the above contents that the program we will use is Pavtube Blu-ray Video Converter Ultimate. Go to find a step-by-step instruction from the following part.
STEP 1: Load Blu-ray, DVD or other video files into this program
Click "Add Video" to import video files, and click "Load DVD" to import Blu-ray or DVD files.
STEP 2: Select subtitle and audio track
Click on the pull down menu after "Subtitle" and "Audio" respectively to select your needed subtitle and audio track as your choice. Your selection can be reviewed in the preview window to the right hand of the main interface.
STEP 3: Select WMV as output format for Xbox 360
Click on the drop-down list at the opposite side of "Format", and then choose "WMV3 (WMV9) (*.wmv)" as output format.
STEP 4: Do optimal settings for the output WMV files
Click on "Settings" button, and afterwards you can adjust audio and video parameters including video/audio codec, resolution, video/audio bit rate, frame rate, sample rate and audio channel on the popup window. To make it excellent for playback on Xbox 360, you can follow the optimal settings as below:
Video codec: wmv3 (the default one)
Resolution: 1920*1080
Bitrate: 150 kbps
Frame rate: 30 fps
Audio codec: wmav3 (the default one)
Sample rate: 48 khz
Bitrate: 320 kbps
Channels: 5.1 Channels
Do remember clicking "OK" button to confirm your settings.
STEP 5: Click "Convert" button to start BD/DVD ripping or video conversion
Once finished, click "Open" button at the bottom to get the output WMV files for Xbox 360, which now is prepared for playback or streaming.
Part 4: How to stream videos to Xbox 360
Well, as we have mentioned in Part 2, there are at least four ways to stream videos to Xbox 360, from Windows Media Center, Windows Home Server, Windows Media Player 11, and Zune Software. Actually, lots of online articles have detailed the setups and operating steps, just check the following links to find the one which is most suitable for you:
How to stream videos to Xbox 360 via Windows Media Center
How to stream videos to Xbox 360 via Windows Home Server
How to stream videos to Xbox 360 via Windows Media Player 11
How to stream videos to Xbox 360 via Zune Software
on Apr 06, 2010 | Audio Players & Recorders
It's me again! i hade a problem: I would like to make a slide show for a dvd with pictures,and that repeats itself.what program,and how should i use(i have windows xp)!and after i would like put the disc...
Versatile and easy PowerPoint Converter
This PowerPoint Converter is a great Microsoft PowerPoint presentation tool that can convert PowerPoint to video and audio file in almost any formats. All the original elements in PowerPoint can be perfectly retained in this PowerPoint to video conversion, including animation, sounds, movie clips, transitions, internal links, and so on. PowerPoint 2007 is supported.
PowerPoint Converter can convert PowerPoint file to AVI, 3GP, 3G2, MP4, WMV, MOV, FLV, VOB, MPG, MPEG1, MPEG2, DV video and MP3, AAC, M4A, WAV, WMA, AC3, MP2 audio files for you to upload PowerPoint to YouTube, watch PowerPoint on iPod, iPhone, Zune, PSP, Apple TV, Blackberry, Creative Zen, PS3, Xbox, and more MP4, MP3 players.
The PowerPoint to Flash Converter can help you convert PowerPoint slide in to Flash video. You can input ppt, pptx, pptm files and get FLV or SWF videos. Then you can upload these video to YouTube, your Blog, your Space, and other websites to share with others.
Now, with the powerful PowerPoint Flash Converter, your files documents can be shown on the Web not only as a standalone document in a separate window but also can be embedded in a web page and shown inside it altogether with other web page content.
Here, the PowerPoint to PDF Converter can help you create PDF file from documents including ppt, pptx, pptm. It is easy-to-use software which can translate different doucment formats to pdf in batches once with ease.
To convert PowerPoint to PDF is easier than ever with this powerful converter. And only several clicks are needed to finish all the conversions with high converting speed and super good output quality.
The original style of PowerPoint files can be perfectly retained, and both beginners and pro users will find this PowerPoint to PDFconverter tool quite easy to use.
PowerPoint to DVD Converter mentioned in this part is an excellent converter from PowerPoint to DVD tool, that can convert PowerPoint to DVD video and burn PowerPoint to DVD, with rich DVD settings, supporting all sorts of DVD discs. Then you can watch PowerPoint on any DVD player.
PowerPoint to DVD Converter can perfectly retain the original music, animation, movie clips, and slide transitions of the original PPT files. And it allows you to insert background music, or record voice as the narrations and instructions for the PPT files.
You can also use PowerPoint to DVD Tool to create delicate DVD menus. It is the best tool to create a DVD from PowerPoint for playback on home DVD players. PowerPoint 2007 is supported.
Moreover, this versatile PowerPoint to DVD Converter also helps convert PowerPoint to all popular video formats like AVI, MP4, FLV, MPEG, 3GP, MOV, WMV, MPEG1, MPEG2, MP3, AAC, etc. Then you can watch PowerPoint on iPod, iPhone, PSP, Apple TV, Zune, Creative Zen Player, Black Berry, etc.
PowerPoint to JPEG Converter can convert PowerPoint to JPEG image file and convert PowerPoint slide to JPG picture file. It is the best PowerPoint JPEG converter and PowerPoint JPG converter, which is both powerful and easy to use.
Microsoft PowerPoint 2007 are supported by this PowerPoint converter, it can convert .ppt, .pptx, and .pptm files to all popular image formats with fast speed and excellent image quality.
PowerPoint Slide Show Converter,
PowerPoint to SWF Converter,
PowerPoint to AVI Converter,
PowerPoint to MPEG Converter,
PowerPoint to WMV Converter,
PowerPoint to MP4 Converter,
PowerPoint to FLV Converter,
PowerPoint to iPAQ Converter,
PowerPoint to iPod Converter
Aug 11, 2010 | Computers & Internet
While applying clear coat over silicone base coat we get spots of dust mostly colored black or white.what to do.base silicone paint and top coat is PU
Open Total Video Converter.
2. Select New Task -> Import Files .
3. Select the Video file to be convert.
4. Select MJPEG Avi Video format.
5. Select Motion MJPEG Avi Normal Quality Profile.
6. Goto Settings.
7. In Audio Option Select Audio Codec to pcm_s16le.
8. In Audio Option Change Sampling Rate to 8000 frames/second.
9. In Audio Option Change Bit Rate to 128 Kbits/s.
10. In Audio Option Select Volume level 255.
11. In Video Option Select Video Codec to mjpeg.
12. In Video Option Change Frame Rate to 15 frames/second.
13. In Video Option Change Bit Rate to 128 Kbits/s.
14. In Video Resize Option Change Video Size to 128 x 104
15. Then Save & Apply the Settings.
16. Now Convert the file.
download and enjoy
Jan 12, 2010 | Samsung Cell Phones
Tip
Standalone DVD player with DivX why does the VBR encoded Audio lag the Video
DivX or XVid encoded MP4 Video codec or AVI will almost always have either the Dolby Digital AC3 Codec or the MP3 encoded audio codec see the following links; Fraunhofer MP3 Decoder or LAME MP3 Encoder
This fixed audio lag can sometimes be caused by VBR audio encoded files and starts part way through the playback as opposed to CBR audio some standalone DVD players will exhibit sound lag in this case. It is a good idea to re-encode the VBR to CBR audio this usually solves the problem.
I suggest that you convert/encode all your DivX AVI files into CBR audio to avoid any such errors; all commercial DVD Video Audio is encoded in CBR (constant bitrate) which also reduces the audio filesize unless its encoded in LCPM which will give a much larger audio component.
Check the audio bitrate type open the AVI in GSpot the example below shows an AC3 audio already in CBR so can be left alone and should work fine.
MANUAL CONVERSION PROCESS
This audio MP3 conversion process it a bit of a long way around I know, but it does work!
  • Open video in VirtualDubMod or VirtualDubMP3 (if there is an index error this can sometimes fix it for you.
  • Ignore the error warning that the video contains VBR audio.
  • Extract audio as MP3 ("demux" in VirutaldubMod or save as WAV, then rename to MP3 in VirtualdubMP3).
  • Convert audio to WAV with CDex
  • Open original video in VirtualDub,choose "direct stream copy" for video and "WAV audio" with "Full audio processing" with CBR MP3 compression (and interleaving with appropriate delay if out of sync) for audio.
SEMI-AUTOMATED CONVERSION PROCESS
You could also use several other easier methods including AVIDemux which uses VirtualDubMod or scan in the DVD-Video using TMPEnc v4.0 Xpress and applying a time lead OR lag however this does not solve a progressive lag *** but can be used to re-author a fixed audio lag error in milliseconds you can use either Windows Media Player Classic or KVM Player in real-time to find this lag or lead error and then adjust accordingly
If you can't work AVIDemux then AVIrecomp will be your best solution this is a bit more user friendly
NOTE> always keep a Backup copy of the AVI before you make any drastic changes as you could make the file unplayable the above process will only work on FIXED AUDIO LAG AVI files.
Progressive Audio Lag (starts in synch and runs fast or slow throughout the AVI is almost impossible to remove with re-encoding the AVI using the above methods.
*** Feel free to comment if you know of a foolproof way other than performing a full re-encode from the MPG2 or DVD VOB file.
on Feb 08, 2010 | Philips DivX DVD Player
I need a codec to convert a AVI. video to a format that will play on a sony ericsson w995
The Sony Ericsson model you mentioned uses MP4 video format. The same format used by iPhones
You can do this using iTunes (icky and big) or VLC Player
1 Download VLC
2. Go to the streaming/exporting wizard.
3. Choose transcode/Save to file.
4. Choose your input stream.
5. Put the video codec on “MPEG-4 Video” and choose your bitrate (I recommend 512)
6. Put the audio codec on “MPEG-4 Audio” and choose your bitrate (I recommend 128)
7. Put the encapsulation format on MPEG 4 / MP4
8. Choose the name and location you want to save the file.
9. Click on finish, that’s all!
Aug 17, 2009 | Sony Ericsson Walkman® W995 Cell Phone
Does my digital camera shoot video?
yes, and here are your cameras video specs too AVI - 640 x 480 - 6 sec - With 8.3MB built-in memory , AVI - 512 x 384 - 11 sec - With 8.3MB built-in memory , AVI - 320 x 240 - 27 sec - With 8.3MB built-in memory , AVI - 640 x 480 - 600 sec - Max clip duration , AVI - 512 x 384 - 600 sec - Max clip duration , AVI - 320 x 240 - 600 sec - Max clip duration
digital video format =AVI
Jul 22, 2009 | Casio EXILIM ZOOM EX-Z850 Digital Camera
My i9 cect wont play mp4
HI All,
i9 is good fake of iPhone, i9S is newer than i68+, i9+ and i9 3G
use following settings, I use win AVI mp4 converter it works for me, * MP4 container
* Xvid codec
* 176x144 resolution
* 12.5 frames per second
* 9600 kbps video bitrate
* AAC LC audio
* 2 audio channels
* 128 kbps audio bitrate
* 44100 audio samples/second
ENJOY!!!
Harshanaiw
Dec 27, 2008 | Computers & Internet
Mp3 disk no audio when playing
First, make sure the CD is an AUDIO CD, and not a DATA CD
If you have recorded a Picture CD or MP3 CD
yourself, ensure that your disc contains at least 10
pictures or 5 MP3 tracks.
MP3(ISO 9660) 96, 112, 128, 256
kbps & variable
bit rate fs, 32, 44.1,
48 kHz
– MP3 discs, picture (JPEG) files
on CD-R(W).
– JPEG/ISO 9660 format
– Maximum 9 characters display.
– Supported sampling frequencies :
32 kHz, 44.1 kHz, 48 kHz (MPEG-1)
16 kHz, 22.05 kHz, 24 kHz (MPEG-2)
– Supported Bit-rates : 32~256 kbps
(MPEG-1), 8~160 kbps (MPEG-2)
variable bitrates
Oct 02, 2007 | Philips DVD 622 DVD Player
ViewSonic PJ350 Multimedia Projector Logo
200 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
