Question about Durabrand Car CD Player and AM/FM Receiver, DB1200
No antenna connection
My son and I helped one of his buddies install a Nesa aftermarket stereo in his car. All went smoothly but, the OEM antenna connector is smaller than the female fitting on the new radio and won't stay securley connected, there's no am/fm reception whatsoever and their obviously different sizes. Never heard of such a thing - thought they were all a standard size.
Any ideas or adapters that you know of?
Thanks
Bill
    Problem Solver:
  • 13 Answers
Most antenna connections are standard, but as you know there is the occasional odd-ball. without knowing the make/model/year of the car i can't recommend a product, but you should be able to find the adapter you need on crutchfield.com.
just put the car info in and they should be able to show you which products work with your vehicle.
Posted on Feb 02, 2009
Get sound on radio install.
Your 2004 Vibe may have been equipped with a radio or a radio and separate amplifier. The BLU/WHT wire supplies +12 V to the radio. The radio ground wire is BRN. A GRY wire powers dial illumination. The BLK/WHT wire you mention is either the antenna input or a sensitivity control input to the amplifier. There also may have been a WHT mute control wire connected to the amplifier. The Vibe has an antenna amplifier which needs +12 v. The aftermarket radio should have separate LF, RF, LR, and RR outputs to connect to the corresponding speakers or amplifier inputs.
Sep 13, 2016 | Cars & Trucks
How do I fix the clock display on my 1999 Pontiac Sunfire?
It appears to be that the radio clock display has malfunctioned, and is due for a replacement radio, which could be an aftermarket or oem radio, maybe found at a junk yard.
Tools required for oem replacement radio, torx keys set.
Before working on the radio or other electronics, disconnect the battery cables with 8mm wrench.
Replacing the oem radio is much easier, if you obtain oem radio, compared to aftermarket radio, due to being direct fit.
The radio is same for 1995 to 1999 Pontiac Sunfire and the Chevy Cavalier, regardless of sub models, such as SE,GT, VL,VLX,Z24. etc.
Parts needed for the the aftermarket radio install :Stereo assembly, stereo wiring harness adapter, radio antenna adapter, and dash install kit.wiring diagram for the wire colors / functions, along with tools, such as torx key set, screwdrivers,wire crimper, wire stripper, double ended wiring connectors, hair dryer.
The oem stereo removal video is for the 2000 to 2005 Sunfire / Cavalier, but are the same or very similar procedures.
Link to oem stereo removal procedures.
Pontiac Sunfire Radio Repair and Removal 2000 2005
Link to aftermarket stereo install / connect procedures. ( Sunfire Video )
HOW TO INSTALL AFTERMARKET STEREO PONTIAC SUNFIRE
Link to aftermarket stereo install / connect procedures. ( General Video )
How To Install Car Stereo Single Double DIN Car Audio 101
Have a nice day.
May 12, 2015 | 1999 Pontiac Sunfire
F5TF-19B132-BA Ford Radio Pin out
The stereo pin layout can be obtained from the car dealership, also a repair manual should have the stereo wiring harness layout in it , the stereo harness adapter for installing non oem stereo, found at the local auto parts store will come with the wiring layout, wires are color coded too, sometimes the stereo harness or stereo harness adapter will have small writing on the wires itself, showing you what that wire is for, and where it should connect.
Basically it comes down to, obtaining the stereo wiring layout, read the description on the wires, and properly connect them together, then solder the wires or crimp them, I like to solder mine with soldering wire for electronics, and put shrink tubes to protect the wires, put the shrink tubes on the wires before soldering together, and ensure the shrink tube is the proper size awg wire gauge.
You will also need, aftermarket face adapter kit and antenna adapter, if installing aftermarket stereo.
Hope this helps and enjoy the stereo :)
Apr 11, 2015 | 1999 Ford Taurus
I installed an aftermarket stereo on my 2006 Kia Sedona and now the FM reception is terrible
the cable that plugs in for the aerial could be a extension piece and puilling the old radio out could have unplugged this extension?
Dec 20, 2012 | 2006 Kia Sedona
I need the radio operating manual for a Jeep Patriot 2009 model. Where can I down load it from as the local dealer cannot seem to find a hard copy for me.
following is the procedure. u can also check ehow for more details.
  • Twist the negative cable off the terminal on the vehicle battery, using an adjustable wrench.
  • Remove the factory issue stereo. Pry off the radio trim bezel with a flat head screwdriver. Remove the four bolts on each corner of the radio. Pull the radio out the dashboard. Unplug the thick black radio antenna cable. Disconnect the wire harnesses from the rear of the stereo. Place the old stereo to one side.
  • Prepare the dashboard for the new stereo. Fit the radio installation sleeve provided with the aftermarket stereo to the radio installation kit. Feed the sleeve through the portal of the radio installation kit and bend the tabs on the sides of the sleeve to secure it in place. Feed the audio wiring of the Jeep and the radio antenna cable through the portal of the assembly and slide the assembly into the dashboard. Secure it in place with the bolts removed earlier.
  • Wire the new stereo. Connect the wiring of the stereo to the audio wiring of the Patriot, using a custom wire harness adapter. Push the connections together until they snap into place and test the connection by tugging gently on either end.
  • Plug the radio antenna cable into the alloted port on the rear of the aftermarket head unit.
  • Slide the connected aftermarket stereo into the prepared housing in the Patriot's dashboard. Click it into place in the radio installation sleeve, taking care not to trap any wiring.
  • Jan 03, 2011 | 2009 Jeep Patriot
    Hooking up amplifier to stock radio in Lexus ls400 1991
    Hi Robin, I think I may be able to help. The instructions are referring to an aftermarket stereo and not the factory one. Most aftermarket stereos have a blue wire that runs either the power antenna or an accessory that turns on with the radio(amp, eq, power crossover,ect.) As far as the RCA cables, once again, most aftermarket stereos have RCA outputs for an amplifier. Factory ones don't.You can go to Wal-Mart or ABC warehouse and buy a wire harness just for this particular application and then all you do is plug the harness into the factory harness, everything is all pre-wired so there is no guesswork involved and no mistakes.
    Aug 23, 2009 | Pioneer GM5400T 2-Channel Bridgeable...
    How to connect kenwood radio to Toyota antenna relay
    Most aftermarket car stereos have a blue wire for power antenna control. Connect the blue wire to your car's power antenna control wire. Also, Crutchfield has nocut connector kits to install most car stereos in most cars, with instructions. You can either buy these kits or Crutchfield gives them to you, free, when you buy a stereo from them.
    Jul 16, 2008 | Toyota Supra Cars & Trucks
    Radio connection
    if he had an aftermarket stereo in the vehical then he had to cut the origional harness out of the way. the only solution for this would be to replace with another aftermarket stereo. I know this becaus ei had a ***** of a time trying to install my aftermarket.
    Jun 24, 2008 | 1990 Pontiac Sunbird
    Car Audio & Video Logo
    109 people viewed this question
    Top Durabrand Car Audio & Video Experts
    matt martin
    matt martin
    Are you a Durabrand Car Audio and Video Expert? Answer questions, earn points and help others
