System cann't take/set up windows-xp
It take vista but during xp set up after copying system component it displays an error screen i.e. u r system is preventing ..........................................
.............................if it is first time restart ur system,
but after restarting same problem reappears.
  • satyajit kar
    satyajit kar Feb 02, 2009
    i also did this fdisk, u tell plz what is fdisk is it disk checking(hard drive)if it is this then i did this.
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Sir are you trying to install xp over vista?
  • 596 Answers
I would suggest when you start the install of XP, chose to re-format you hard drive for a clean install. The Vista files need to be erased completely before XP will install on the drive. If you can, I would use fdisk first and then install XP. Let us know how it goes from here.
Posted on Feb 02, 2009
  • Nouveau IT, LLC
    Nouveau IT, LLC Feb 02, 2009
    fdisk is a DOS command used to partition hard drive for operating systems. A few more question for you; 1. What size is your hard drive? 2. Is the Vista fully installed? (If you start your pc, will it boot up to Vista?
    After you anwer this for me, I can guide you a little better to a possible solution.
NTLDR is missing is displayed when i turn on the computer
The "NTLDR is missing", error displays very shortly after the computer is first started; after the Power On Self Test (POST) is complete. Windows XP might only initially load when the NTLDR error message appears. Causes of this error message include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Get more help and information for Windows XP hope this helps you.
Mar 01, 2011 | Microsoft Windows XP Professional
While installing xp showing error
Hi Friend
Try this may help you in creating a dual boot.
First find the drivers for your network components, wireless card or nic, and save them to an external device such as a floppy disk or flash drive.
Then you will need to go into the BIOS on your computer startup. Scroll to the System Configuration tab and go down to the SATA Native Support and change its setting to Disabled. Then hit F10 to Save and Exit. (You don't need to change the BIOS if you have an ATA or IDE hard drive.)
Next, insert your Windows XPmag-glass_10x10.gif CD and create the partition you wish to install XP on. After the installation is complete you should boot automatically into XP. (To do this, right click the Computer icon in start, and select manage. Then select Disk Management, and you can do whatever you want with your partition.)
Now you need to move some files. First, make sure you have set your folder options to see hidden files and to show protected operating systemmag-glass_10x10.gif files. Then open Windows Explorer and go to the drive where Vista is installed. Copy the folder Boot, and the files bootmgr, boot.ini, NTDETECT.COM and ntldr and paste them to the root of your XP drive.
Then download Vista Boot Pro and save it to your desktop or somewhere else that you can easily access. Unless you already have .Net Framework (v2.0 at least) it will redirect you to a Microsoft page where you can download this necessary component.
Install and run Vista Boot Pro and open the "Bootloader" tab. Select "Reinstall the Vista bootloader" and press Apply. Then go to the Manage OS Entries tab and select "Add new operating system entry" and make sure you select "Windows Legacy". Give the new entry a name (ie: Windows XP) and select the drive letter you have XP on and then select Apply. You can also choose which entry you would like as the default the system will boot to.
And now you should be able to dual boot between Vista and a previous OS.
I hope this will help you out. Please vote for me.
Oct 06, 2009 | Compaq Presario Notebook
I WANNA INSTALL XP2 BUT MY SYSTEM SHOWS ERROR: C000022UNKNOWN HARD ERRORSYSTEMROOTSYSTEM32NTDLL.DLL
  1. This problem may occur if the file that is described in the error message is corrupted. The following files are checked for integrity when Microsoft Windows XP starts:
  2. All driver files (except those that are loaded by the system loader to start. the computer)
  3. All dynamic-link libraries (DLLs), including User, Graphics Device Interface (GDI), Shell, Kernel, Ntdll, Crtdll, and others.
  4. This problem may occur if you install an inappropriate driver for your hardware. For example, you receive one of the error messages that are described in the "Summary" section if you install a MIPS driver on an X86-based computer.
    This problem may occur if an Iomega Zip drive is on the same integrated device electronics (IDE) cable as the hard disk drive.
  5. To resolve this problem, obtain a new copy of the corrupted file or reinstall Windows XP. If you continue to receive any one of the error messages that are described in the "Summary" section after you reinstall Windows XP, a hardware problem or a network problem may exist.
  6. This error message may be displayed in many different formats, including an error message that is displayed on a blue screen or an error message that is displayed in a dialog box. The type of format that the error message is displayed in depends on how much of the operating system was loaded when the corrupted file was detected.
Apr 11, 2009 | Microsoft Windows Vista Ultimate Edition
Installing XP on HP m8120n
The Blue Screen of Death (also known as a stop error, BSOD, bluescreen, or Blue Screen of Doom) is an error screen displayed by some operating systems, most notably Microsoft Windows, after encountering a critical system error which can cause the system to shut down, to prevent damage.
Bluescreens on NT-based Windows systems can be caused by poorly written device drivers or malfunctioning hardware. In the Win9x era, incompatible DLLs or bugs in the kernel of the operating system could also cause bluescreens.
Bluescreens can also be caused by physical faults such as faulty memory, power supply issues, overheating of components, or hardware running beyond its specification limits. Bluescreens have been present in all Windows-based operating systems since Windows 3.1; earlier, OS/2 and MS-DOS suffered the Black Screen of Death, and early builds of Windows Vista displayed the Red Screen of Death after a boot loader error.
I hope it helps!!!
Dec 04, 2008 | MSI K8MM-V Motherboard
TARGA TRAVELLER 1591 TRYING TO DUAL BOOT ITS GOT VISTA I WANT TO INSTALL XP PRO BUT XP CANNOT SEE THE HD IT NEEDS THE DRIVERS. HOW DO I INSTALL THE DRIVERS FOR A SATA DRIVE INTO MY XP INSTALLATION CD
OK I managed to install XP on Targa Traveller on 1591!
With the CD of window XP it is necessary to make F6 for the starting up of the installation and to use a diskette with the pilots(drivers) SATA of NVidia nforce. Naturally the most practical are of incorporated the pilots(drivers) SATA into the CD Windows but I knew how to make;) link for the pilots(drivers) SATA:
Http://garlon.free.fr/Appli/NVidia /
If after the intallation of the pilots(drivers) at the beginning of the copies of file An error of copy of file (cann' t copy spin NVr dll) make Esc (65 files nvidia not copied) and continue the installation up to the restart.
I put out(switched off) the computer, removed the hard disk to put it in an external box usb on another computer I have to copy files dll to System32 or system32 / drivers, file .inf on file windows/inf and file .sys on system 32 or system32 / drivers
I restarted the computer and finished the installation links Pilots(Drivers) xp (I am not sure for Chipset drivers Chipset...you must verify)
http://fred.garlon.free.fr/Appli/Targa
Good luck
Sep 26, 2008 | NEC PowerMate VL3 (ND361799406) PC Desktop
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
Vista downgrade to xp
no there aren't any drivers, but the problem you will have is that the bios is updated to suit Vista and installing XP will cause problems with components in the notebook.
My advice is to keep Vista if you havent already uninstalled the operating system, but you will notice that your hard disk has two partitions, install XP on the other partition and have a dual boot notebook, if you have uninstalled then lend a friends copy of Vista and use your own instalation product key code on the underside of your notebook and re install.
Nov 06, 2007 | Computers & Internet
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
