I need an new button that controls the washing programmes it fell off in transit..i have a service easy logic 1600 how can i order it please
  • Washing Mach... Master
  • 3,463 Answers
Try this company, they do quite a range of servis spares
www.appliancespares2go
please rate my fixya solution.
Thanks
Posted on Feb 02, 2009
Ihave a stability control light which will not go off on my 2009 transit
By jerking the vehicle around... you can exceed the logic's ability to figure out which way to "AUGMENT" suspension & braking...
to keep your vehicle from following it's natural (top-heavy) tendency to ROLL-OVER.
Once those "logic" parameters has been EXCEEDED... the
STABILITY CONTROL simply SHUTS-DOWN and lights that light to alert the DRVER.
Consult your driver's guide (owners manual)... to familiarize yourself with your FINGER-TIP controls.
Push the RIGHT BUTTON and that light will go off...
UNTIL then... drive a lot slower... and more carefully...
Without your STABILITY (roll) CONTROL is it quite easy to put all your wheels WRONG SIDE UP.
2009 Ford Transit Owners Manual PDF
Aug 10, 2016 | 2009 Ford Transit Connect
My lg fuzzy logic 9kg top loader control board got burnt. i need a picture of the control board configuration
The only possible solution is to order for a new board and Replace the entire unit.
please check on this link: LG support.
Dec 31, 2012 | Washing Machines
The washer fill but no program would start
**WARNING!!! Unplug appliances before beginning repairs!!!!
You need a new programmer (Controller). The motor is jammed or not running. Very common. Controllers cost $75 to $300 dollars US. Find out the price before you order it!
Getting the knob off the controller can be hard. I suggest a new knob with the controller if it will not pull off or unscrew backwards. Special tools may be required.
Most controllers are easy to change inside as they plug in.
Mar 20, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing programme keeps stalling
Ok, this is a basic control fault within the logic chip set. you will need to replace this faulty control board/timer in this case.the replacement of the control/timer will fix this issue.
Jun 01, 2009 | Electrolux Washing Machines
Servis Easi LOGIC 1600 Model:M6160S
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 19, 2009 | Washing Machines
I need an instruction manual for an Omega WD 1052 washer, please
I have searched everywhere as well, and no luck. I did find a bit of information on it which I have pasted below -- it might help a bit if you want to play around with it.
I would also suggest reading manuals from other wash/dryer machines to get an idea how they work--then maybe you can figure yours out by just pushing the different buttons and seeing what the display says. (At the end of this post, I have pasted a link to a different Omega washer/dryer -- perhaps you could skim it and see if it is at all similar to yours.)
Information About the Omega WD1052.2 washer dryer
THIRTEEN PROGRAMME:
The WD1052.2 is sequentially segmented into thirteen rotary positions for both easy and logical programme selection and for the quick identification of programme progression.
Choose from one of three wash sequences:
Programmes one through five are for the heavily soiled, more colour fast fabrics and daily wear.
Programmes six through to ten look after the slightly soiled, synthetics and for delicate items.
Woollens are exclusively washed on programmes eleven through to twelve.
CONDENSER DRYING:
The WD1052.2 can automatically dry a half a load of washing at the end of the wash programme provided the half load button is selected and a drying time is set on the centre control dial.
At any time the WD1052.2 can be regarded as an independent dryer, that is, a wash programme does not have to proceed into the drying stage. An example would be drying damp clothing or toweling from the bathroom. Simply choose a STOP position after either 5 or 10 on the programme dial. On the centre dial choose either full heat, the pink zone, or half heat, the green zone.
Another useful variation of the WD1052.2 is the ability to choose final spin only followed automatically by condenser drying. Having completed a hand wash, for instance, simply load the clothing and select final spin, 5 or 10 with the half load button selected and drying time set.
Whenever the WD1052.2 is in the drying mode the load can be easily accessed at any time via the porthole. The drying will automatically resume once the door is reshut.
Specifications:
Freestanding or Built-in
5kg (11lb) dry weight Capacity
2.5kg (5 1/2 lb ) dry weight condenser
13 Programmes
40 minute Fast Wash
Special universal 2B programme
Dedicated woollens cycle
Independent wash temperature control
1000 or 500 r.p.m spin speeds
Half load Economy selections
Drip dry no spin programming
Anti crease hold in final rinse Selection
Extra rinse option
Two drying heat settings
Stainless steel inner and outer wash drums
Two minute delay safety door release
Built-in heating element
Front mounted easy access lint/forgin matter
inspection
Automatic balancing of wash load
LINK TO A DIFFERENT MODEL:
http://www.omegaappliances.com.au/Documents/Document_205.pdf
Good Luck--I hope you get it working!
P.S. If you find this information useful, please remember to rate me! Thanks!
Mar 18, 2009 | Washing Machines
Brand new washing machine wandering on spin cycle
It sounds like the transit bolts or some of the packing is still in place. Running the machine with these in place can do serious damage.
Thankyou for using Fixya.
Feb 14, 2009 | Washing Machines
Servis easy logic 1600 wont spin
servis easy logic 1600 wont spin just moves the drum half a turn and stops but repeats all the time
Aug 17, 2008 | Washing Machines
Servis easi logic 1600 washing machine not working
my servis eai logic 1300 will not rotate half way through the wash but will still spin and dry etc please advise.
May 09, 2008 | Washing Machines
Washing Machines Logo
120 people viewed this question
Top Washing Machines Experts
