Question about Psi Blue Max 2200 High Pressure Gas Power Washer
Need parts for Wand
Where can I get or order parts for wand? Broken nut, or similar. Are wands or wand parts available?
  • 56 Answers
Yes go to Northern Tool supply Lowe's or HomeDepo any of these places should hace what you are looking for
Posted on Feb 03, 2009
Wand attached to hose - how do you detach? Kenmore central vacuum system model s107 34730
Many central vacuums have similar or the same parts made by a small number of manufacturers. I found the MD Central Vacuum website to be very helpful and I hope it solves your problem. I have attached pictures and descriptions from their website so you can see if this is what your wand looks like. If so, to separate the wand from the floor brush unit there should be a lever or button on the brush housing you can push with your foot to release the wand. If you are asking about where the wand connects to the hose you push that black button that you see at the top of the wand in the picture, the top smaller black part. I hope this helps.
Sep 08, 2017 | Kenmore Vacuums
The turbo wand and nozzle connection on my Pressure washer Model 580.752070 How to restore seal between Wand and nozzle? Please point me in the right direction to resolve this problem
the seal is normally a "O" ring that is available from a good hardware shop or bearing supply shop
basically the same set up as your garden hose "O" ring but with a pressure wand there is a thread nut to hold the bits together.
If it is not that then the threaded section of the connection in the wand or hose mat be loose or broken at the thread
Jun 12, 2015 | Garden
Steam wand on Vienna plus detached from arm
Lets first make sure you have all the parnello wand parts. The nut, hard plastic gasket, soft rubber gasket, the inner wand then the sleeve and the center in the sleeve. When putting it back together find the notch on the metal steam wand and slide the nut onto the wand, then add the rest in the order above.
Jun 02, 2012 | Saeco Vienna Plus Espresso Machine
The wand that connects to the power head at the powerhead connection broke(sheared off) fine crack
Unfortunatley the Wand for your Miele is sold as an entirely assembly only. Miele does not sell pieces of this wand separately. In order to fix your wand you'll need to purchase a new wand assembly complete.
The wand on your Miele is the Miele SET210 Wand. Here's a link if you need to purchase one;
http://www.govacuum.com/miele-172.html
I would probably guess that your wand broke off right at the bottom where it connects into the power nozzle. Unfortunately this is the weakest part of the wand as you can probably see. The wand narrows into a thinner plastic here, and I've seen a few wands crack off right on the bottom part.
Please feel free to request a repair clarification if you have any questions about how to repair your vacuum.
If you found this helpful, please be sure to rate it by clicking the thumbs up icon. I really appreciate that.
Chris J.
Mar 21, 2010 | Miele s558 Silver Moon Vacuum
I need a price for a wand for my electrolux ambassador 2100 vacuum cleaner
This same wand is used on all older canister models since 1974 until about 1995.
Metal wand, about $24.
Upper wand assembly, about $34.
Parts should be available at any Aerus shop.
Of course, you can try to find used ones, often with complete vacuum, at second hand stores, pawn shops, yard sales, estate sales, etc.
Sep 29, 2009 | Electrolux Vacuums
Same issue...need replacement wand for fantom lightning
I have the power head, wand & hose, exrra belt, 4 heps filters ans a spare main vacuum motor for Fantom Lightning. My main motor burned out. Found a used motor on Ebay. Went to change it and part of wiring was burned, so I decided not to rosk reairs with bad wiring. Power head was not attached at the time, so it is fine. I'll sell all together for a decent price, it you're interested
Aug 09, 2009 | Fantom Vacums Lighting Canister Vacuum
Brass part in wand handle because the brass fitting
Bronze breaks, why it does not have flexibility. it substitutes part for steel inox
Jun 05, 2009 | McCulloch FH180A Electric Pressure Washer
Steam wand loose
you can tighten the steam want with a wrench. At the top of the wand just before it enters into the machine you see a "nut" use this to tighten or loosen the wand
Jan 05, 2009 | FrancisFrancis! X1 Espresso Machine
Wand
Do you have a telescopic/height adjustable wand or just two tubes which have to be stuck together? If they are made of plastic well, it may well be broken. If its metal check that the tops aren't corroded or the handle itself isn't broken. If the tubes/wand isn't sliding up and down (i.e. if its height adjustable) then something has got stuck. Sadly for this kind of repair you'd be better off to buy replacement wands or consider something aftermarket on EBAY. Check the diameter of the tubes with a ruler. If it is 3.2cm (32mm) or 3.5cm (35mm) you can buy replacement tubes. If you can't afford that then try furniture polish on a J cloth or similar and with a stick wedge it inside the tube/wand so that it adds a little lubrication or simply a clog - it sounds like there is dirt clogged in the part that slides. Dont forget to rate, thanks.
Jul 26, 2008 | Vacuums
Losing power to stick/floor vacuum
if you have an extension wand, the replacement will cost about $100.00. there is a way to repair both the pwr-cord on the brush assemble and the wand, but it depends on how much damage there is. also you need to check the contacts where the wand connects with the handle,and the prongs on the handle.
let me know if you still need help
Jan 11, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Psi Blue Max 2200 High Pressure Gas Power Washer Logo
355 people viewed this question
Top Psi Garden Experts
John Trevino
fordexpert
Jay Finke
Jay Finke
Are you a Psi Garden Expert? Answer questions, earn points and help others
