Question about Psi Blue Max 2200 High Pressure Gas Power Washer
Broken part A nut or similar has broken inside the wand. Where do I get the part--or new wand?
  • rayscycle1 May 02, 2009
    mr fix it has a bad attitude there was no solution on the web site
2 Suggested Answers
johnr1959
  • 56 Answers
SOURCE: Need parts for Wand
yes go to Northern Tool supply Lowe's or HomeDepo any of these places should hace what you are looking for
Posted on Feb 03, 2009
The turbo wand and nozzle connection on my Pressure washer Model 580.752070 How to restore seal between Wand and nozzle? Please point me in the right direction to resolve this problem
the seal is normally a "O" ring that is available from a good hardware shop or bearing supply shop
basically the same set up as your garden hose "O" ring but with a pressure wand there is a thread nut to hold the bits together.
If it is not that then the threaded section of the connection in the wand or hose mat be loose or broken at the thread
Jun 12, 2015 | Garden
The Rialto toilet makes it very difficult to replace the seat as you cannot access the wing nuts which in a moment of engineering genius you put inside the bowl I have already purchased a French seat to...
You should be able to remove the tank lid, reach into the cistern and find submerged at the bottom towards the front of the toilet the plastic wing nuts, hold onto these while tightening the plastic bolt from the top.
I have a Kohler toilet with a similar design, not sure if it is this exact model but they look very similar so I hope this works for you.
Apr 18, 2011 | Kohler 3386-6 Rialto Skylight Round Front...
I have a saeco Royal Professional and have noticed that although the steamer appears to have sufficient pressure it is taking longer to heat the milk via the wand and that it appears to be steaming up...
Very good description. The problem is very simple. Inside the machine behind the steam wand the secure nut on the pipe coming to the wand is loose and you can tight it back in place very easy. You will need to remove the top plastic cover to see where the steam is leaking.
There is a chance that the pipe or nut is proken but this is very rair.
Good Luck
Mar 27, 2010 | Saeco Royal Professional Espresso Machine
Ex-Cell VR2500 Builds Pressure but Won't Spray
I have a similar problem and diagnosed it to be a problem with the gun. I spoke to a technician that services this pressure washer and he walked me through all the diagnostic steps. The pump is working because there is pressure being built up and the gun sort of works because you can get water out before the washer is started. The technician said that the mechanism inside the gun is either clogged or broken. I am going to Home Depot or Lowes to purchase a new gun and will try it tonight. Guns are only about $30-40. He said generic is fine as long as the thread matches and PSI is in range. Good luck!
Aug 09, 2009 | Karcher 2500 PSI Pressure Washer
Brass part in wand handle because the brass fitting
Bronze breaks, why it does not have flexibility. it substitutes part for steel inox
Jun 05, 2009 | McCulloch FH180A Electric Pressure Washer
Need parts for Wand
Feb 02, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Hoover Savvy wand holder upper how to replace it
if you look at the bottom of the holder on the inside you will see a tab just take a small pocket screwdriver and pull out on the tab it should come off.the new one will just snap in
Jan 26, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Dyson DC 11 Broken Wand Clip
Contact the manufacturer, thay should be able to assist.
Jan 05, 2009 | Vacuums
Broken wand inside handle
try and bend a small part of the metal wand with a scre driver careful not to break the handle they are $120. then get a pair of needle noise plyers and try and pull it out.
Aug 23, 2008 | Filter Queen Majestic Canister Vacuum
Wand
Do you have a telescopic/height adjustable wand or just two tubes which have to be stuck together? If they are made of plastic well, it may well be broken. If its metal check that the tops aren't corroded or the handle itself isn't broken. If the tubes/wand isn't sliding up and down (i.e. if its height adjustable) then something has got stuck. Sadly for this kind of repair you'd be better off to buy replacement wands or consider something aftermarket on EBAY. Check the diameter of the tubes with a ruler. If it is 3.2cm (32mm) or 3.5cm (35mm) you can buy replacement tubes. If you can't afford that then try furniture polish on a J cloth or similar and with a stick wedge it inside the tube/wand so that it adds a little lubrication or simply a clog - it sounds like there is dirt clogged in the part that slides. Dont forget to rate, thanks.
Jul 26, 2008 | Vacuums
Psi Blue Max 2200 High Pressure Gas Power Washer Logo
103 people viewed this question
Top Psi Garden Experts
John Trevino
fordexpert
Jay Finke
Jay Finke
Are you a Psi Garden Expert? Answer questions, earn points and help others
