Question about HP Compaq nx6310 Notebook
Nx6310 wont stay on
The computer was working fine ....next day went to start up pc green power light was on but computer was off no power cord was attached removed battery light went out but when i attached battery again green light instantly came on when i press power button screen comes on white for about 5 sec and then pc shuts off again.im thinking that its not charging also......what could be causing this issue......
    Scholar:
  • 152 Answers
HP is notorious for this problem. The problem is that the power jack that is connected to the motherboard has come loose. This is an easy fix is you are comfortable taking apart your notebook and are able to solder the jack back to the motherboard. I have 2 HPs and my friend has 2 and we have done this with ours as well as others. This is the link to the HP website that has your manual for disassembly .http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=1839143 When you get to the page, download the Maintenance and Service Guide. (It is all the way at the bottom!) You will need Adobe Acroabt to read it. PRINT the instructions. They will do you no good if they are on the laptop that you are trying to disassemble!
While it may seem daunting, it is really not hard to do. Just be careful to follow all of the disassembly and reassembly instructions and you will have no problems. I promise!
Please remember to rate my solution! Thanks
Posted on Feb 05, 2009
I HAVE A TOSHIBA SATALITE A135-S4427 TURNED IT OFF ONE NIGHT WORKING FINE, THE NEXT DAY IT WONT TURN ON. I HAVE POWER THRU THE CORD AT ABOUT 18+ VOLTS BUT NO INDICATOR LIGHTS OR POWER TO COMPUTER. HELP?
Try removing the battery and power supply, hold the power button for about 10 seconds then just plug the power supply back in (not the battery) and see if it turns on.
Holding the power button with no power supply can discharge any stored power in capacitors.
Oct 24, 2013 | Toshiba Satellite A135-S4427 Notebook
Samsung R480 Will not charge or turn on but indicator lights flash or stay on.
Swap out the ram one at a time testing to see if you can power up, making sure there is one in the memory slot at all times, if this works the piece in your hand is defective, no difference! the motherboard has major issues.
Jul 10, 2012 | Samsung R480 Notebook
My acer aspire 7736G was working fine, it's about 2.5 years old, and is used mainly with the power cord plugged in. When using it the other day the computer just went dead on me. I took the batter
You have reached the end life of the battery pack. The battery must have some minimum charge to have computer function even with the AC power pack connected. So I suggest you replace the battery pack as a solution. Any local Radio Shack store can test this battery I am told free of charge.
Jun 20, 2012 | Computers & Internet
I have a dell 1720 that was working great. I went to plug in the power cord and the green light went out on the power box and nothing happened when I pushed the power switch on the computer. The power...
the charging port and or motherboard is grounding out
that is to say positive and negitive coming together
wont damage the charger
once you plug the charger out of thhe laptop and outlet then plug back to outlet the light will return
has to be look at by a technician
Jun 02, 2011 | Dell Inspiron 1720 PC Notebook
I was using my dell latitude d510 just fine the other day the only thing that was wrong is the battery wont charge so it always had to be plugged in. well from using the charger so much it finally stop...
The problem could be with the port the cord connects too. It could also be with the battery. If you take the battery out, and you still can't run on AC power, you need to replace the port. Take it to a computer/hardware shop and have it done.
Feb 24, 2011 | Dell Latitude D510 Notebook
Bought 3 Eee PC 900/XPs. Bought recommended Crucial 2GB SODIMMS to upgrade memory for all three machines. After upgrade and just after Windows XP loads the screen goes crazy. Crucial suggested...
pop battery out ...... re-start with cord power , then shut down completely. pop battery back in after 5 minutes .....and try that ......you may also want to check your power settings .
Jul 13, 2009 | ASUS Eee PC 900 PC Notebook
The bios update failed on my 4g asus eeepc
What you need to do is to get the manual for the motherboard os you can reset the BIOS. On the other hand, you may not be able to preform that. This model is like a netbook and try this, remove the battery and the power cord. give it 15min. put the battery back in and reboot the system and than the power cord. that should help. if not, than a tech person is your next step.
Mar 27, 2009 | ASUS Eee 4G Notebook
HP Laptop Seem to Charge but Wont Turn On
When you plugged the power cord back in did the green light on the power cord battery light up. How long have you had the cord. Make sure the power cord is working properly.
Jan 03, 2009 | HP Compaq Presario C304NR Notebook
HP Compaq nx6310 Notebook Logo
427 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
