Question about Kenmore 98702 Stacked Washer/Dryer
Heating coils are not broken and will not turn of
Magtag lde710 when i plug in dryer with the doar open the heating coils come on, coils are not broken drum does not turn with doar open or closed.
  • Kenmore Master
  • 1,525 Answers
Check the capacitor next to the motor it will have 2 wires coming off it this can stop the drum turning
shaun
Posted on Feb 06, 2009
Dbsr463eg7ww no heat
First check to see that the exhaust venting line is clear (not full of lint) as well as the path in the dryer to the line. This is the most common cause of no heat.
Second set the knob to heat turn on dryer with the lights off and the door open but the "open door" switch so that it still rotates with the door open. Look at the back of the rotating drum for a orange/red glow behind the drum (the heater coils). If there is no glow the heater coils are probably broken.
As the dryers age, the amount of thermal cycles the heater elements go through until the point when the coil wire breaks. There usually two heater coils behind the rotating drum (one hotter than the other and when combined the hottest heat temperature setting. You will need to pop open the top where you see the belt that turns the drum. The belt is removed from the spring loaded tensioner pulley at the base of the dryer. Then you can lift the drum out to get to the heater coils. Since no heat, both should be broken and will require replacement.
Nov 05, 2013 | GE DWSR463EG Electric Dryer
Dcvh660ghbb dryer wont heat
Sep 05, 2013 | GE Dryers
No high heat in dryer
This type of dryer has 2 rows of elements. If one is out then you will not have high heat.
Basically to get into ge dryers your start by popping the top then removing the front. Then the drum comes out.
Dec 05, 2012 | GE Dryers
Dryer does not heat
Might be a limit or a the heater element.MY REPAIR PAGE
Aug 15, 2012 | GE Dryers
Not generating heat and dosnt stop automatically
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101 ,..,
Apr 03, 2011 | GE Dryers
Dryer blowing cold air . No heat!
Check the "Bias thermostat" for continuity with a multimeter. IF it is bad, replace with this part.
Nov 29, 2010 | GE DBXR463EDWW Electric Dryer
How can i repair the dryer when it wont heat. It heats only in the beggining then it does heat anymore more after 10 minutes, how can I fix it?
I was dealing with this exact issue for the past few days! I have a model # MDG5500AWQ. Starting to hang dry clothes and all. I read through these blogs and found that it was a GAS VALVE SOLENOID COIL that I needed to be REPLACED. I was told by a Magtag dealer that when the gas flame cut out like this the issue was 99% of the time the gas valve solenoid coil kit. I was even trying to call around to try and get a tech out today but none were available and they wanted $65.00 just to come out and look at it. So I went to the Magtag website and found a dealer in my area and asked them for the part. If you open the front part of the dryer and push the button to make the dryer turn on without the door closing it in a few seconds the flame starts on and about 1 minute later the flame totally cuts out. My husband just got through changing out these coils which were smaller than the picture, only $35.00 with tax front the dealer, and located in the very front of the dryer,. towards the bottom, when you open the dryer front. He replaced them and I'm drying a load of laundry right now, thank God!
Apr 05, 2010 | Roper REX4634KQ Electric Dryer
Dryer does not get hot
There are a number of things that can go wrong on an electric dryer that will make it not heat...
Check out this tip that I wrote about that problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Mar 31, 2010 | GE DBSR453EBWW Electric Dryer
Kenmore 80 series gas dryer has not heat
most of these dryers have a little plastic plug on the front, left side. pop that plug out and look inside after turning it on. you should see a red glow. if not, then your ignitor has broken. if you see a glow, then the problem is probably one of the two little coils on the gas valve. these coils will sense if there is something to light the gas [the red glow] and open the valve - if the coils are bad, they won't open the valve
Aug 17, 2009 | Kenmore Dryers
My magtag dryer mde9520 won't heat. How do I tell
You need a multimeter to test the voltage and continuity
Jun 30, 2009 | Maytag Dryers
Kenmore 98702 Stacked Washer/Dryer Logo
26 people viewed this question
Sal De
fordexpert
Robert Rankin
