Question about HP LaserJet 3050 All-In-One Printer
The lens where is the lens in order for me to clean it. i dont have a mannual
    Genius:
  • 2,120 Answers
Open up the document feeder and clean the scanner glass. Does not have a lens
Posted on Feb 03, 2009
I shut my sony trinitron off now it dont go back on the stand by light blinks 6 times i dont have the the remote (kids lost it) cant find users manual what can i do joe r bushkill pa
If stad by light blinks 6 times, it is the "Thermal Fuse", it goes next to the Light Bulb, looks like a tine antena with a plastic tip (like a transistor), follow the wires all the way to the back, unplug it, check the Part # and order on line with Sony.com or by phone. I paid $5.00 for that piece pluw $15 shipping. After that, make sure you clean up very well all the vents and fans, due the obstruction of those areas, inside Tv reaches a temp higher than 110, the Thermal Fuse blow out for protection. A well ventilated TV (clean vents and fan) helps to avoid this proble again. If you do not have your mannual, go to www.Sony.com and look for support, they have all the manuals there available for free online. Check it to make sure the light blinking and the times blinking correspond to that problem. Good Luck!!!
Apr 15, 2011 | Sony Televison & Video
We are getting the message : Could not read the disc. We did what the mannual said to do and cleaned the discs but the same message is coming up for any disc we insert.
It sounds like you have a dirty laser lens that reads the disks. The following link will take you to a writeup on how to clean the lens on a Wii. Good Luck!
http://www.smashboards.com/showthread.php?t=150846
Mar 24, 2011 | Nintendo Wii Console
My panasonic Lumix DMC-ZX1 shows 3 dark spots and 2 hairs on all pictures. When I zoom-in the dirt is more visible and when I zoom-uit I dont see the hairs any more and the dark spots appear wider and...
Yes, you can clean. Not as complex as I originally thought.
1) Remove all of the silver screws
2) Separate the silver case (should split in 2)
3) Remove the 3 black screws in the middle
4) remove the center square cover that is over the lens
5) Use a duster spray to clean the lense and mirror
6) Reassemble in reverse order
Not knowing what I was going to get in, the entire process only took about 7-10 minutes.
Email me at malhokc1@yahoo.com with any questions.
Feb 09, 2011 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
How to remove the lens cover (headlights) in order to clean them
Those assemblies are not meant to come apart. You can purchase a head light resurfacing kit at Auto Zone or any other Auto parts stop. It takes a little time but it works well.
Jul 23, 2010 | 2000 Hyundai Accent
It is lighting up on washing machine saying clean pump dont have instruction mannual dont know where pump is
If it is a front load machine you can normaly access the pump from the front sometimes under the kickpanel, There should be a button trap which you can unscrew and clean out the debris. Hope this Helps Kind Regards.
Jul 09, 2009 | Washing Machines
Trying to save a channel ? How to seach mannually
you cant , the search is automatic , then
you can delet ch that you dont want
Jun 28, 2009 | Grundig 21" TV
How can I replace or clean my headlight globe of a 1998 Galant
Headlight globe, meaning the inside of the headlight? If thats what you mean, only way to do it, is to take the lens off, and in order to do that, you need to take out the headlight, take off the rubber backings and take out the light bulbs. Then preheat your oven to 210 degrees, stick your light in there for 10 minutes, and pry apart the lens, since the glue will melt. Dont forget to undo the clips that also hold the lens to the housing. After you pry off the lens, clean or whatever you need to do. Then reseat the lens and hook the clips, then back in the oven it goes for 10 mins. Then hold pressure on the lens untill glue hardens.
Hope that helps.
They will not have or sell replacement globes, it will come with the whole headlight.
May 29, 2009 | 1998 Mitsubishi Galant
No mannual zanussi turbody 1050 - wds 1183 w
You can download a copy of the user instructions for your washer/dryer by going to the following link.
http://www.serviceforce.co.uk/pdfs/U01301.pdf
Please leave a fixya rating for my solution.
Thanks.
Feb 11, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
West bend homestyle plus bread maker manual
Dear home maker
Dont worry, you just have to spend few minutes on google search by typing in the model name and number to avail the mannual. And i am sure you will get the mannual. Please rate me..!!!
Thankyou
Feb 10, 2008 | Kitchen Appliances - Others
HP LaserJet 3050 All-In-One Printer Logo
66 people viewed this question
Ben Johnson
