Question about HP Pavilion F1703 17" LCD Monitor
Hp vs17e monitor says it's in sleep mode then goes blank
The blue light then turns to yellow and stays that way. I am on my laptop now because the flat screen is blank
    Problem Solver:
  • 3 Answers
Check the board postings for the HP f1903 monitor.I recall seeing a problem of the same there and a solution or fix. As it is only a newer version of the same model, it may be the same fix. Appears HP has a big problem with QA and this particular model. Lots of people have same or similar problems, and all appear to have a similar fix or solution. Tricky part... figuring out how to "Open" the monitor to check it inside!
Good Luck.
PS - if you figure out the opening part, let us all know!
Posted on Feb 12, 2009
My monitor on my hp8300 stays in sleep mode
you need to turn off sleep mode its sounds as if its on a timer setting.
Apr 22, 2014 | Samsung Computers & Internet
Why does my HP vs17 monitor screen keep going to blank black screen like it turned off but did'nt.....blue power button light is still on? Everything is running but no picture.....keeps happening everytime...
this old monitor has 2 issues.
1: it has CCFL tubes that love to burn out (backlamps)
most this old are long go, yell,dim.,blinking or DEAD.
2: push the menu button on front of mon. turn off power saver.
3: if the PC goes to sleep, or hibernete mode (parked)
then that is 100% normal
if you dont like feature then go to windows control panel
click power, ICON and turn off all monitor sleep /hibernate modes.
that assumes windows, no OS stated.
if the lamps are dead,
use flash light pointed to sceen, see data. ? bingo for bad CCFT tubes.
as seen here
http://www.pcdied.com/monitors.html#flashlighttest
Jan 12, 2018 | HP Vs17 17" LCD Flat Panel Monitor
When I start the computer the Windows XP Logos light up on the Monitor (HP w1907) when the computer starts the Logo disappears and the monitor goes to sleep
If this monitor (HP w1907) is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Aug 19, 2010 | HP vs19 (Silver) 19" LCD Monitor
I've got a HP w1907v monitor and latly it has been going into sleep mode without warning while i'm using it. All my power saver settings are set to off.
If this monitor is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Aug 18, 2010 | HP w1907 LCD Monitor
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
If you are running Windows Vista,do the following,
  1. Click start,Control panel,
  2. Double click Power options,
  3. On the left menu bar,Click Change when the computer sleeps,Change "turn off the display" to never,
  4. Go down to the botton and select "Change advance power settings,
  5. Scroll down to Display and click the + symbol,
  6. Click the + symbol beside "Turn off display after" change to never,
  7. Click on the next plug + symbol beside Adaptive display and change to off (You may or may not have the adaptive setting)
  8. Click apply ,click ok,
  9. Restart your computer.
If you are running windows Xp
  1. Right click on an open area on the desktop
  2. Click properties
  3. click the screen saver tab
  4. Click the power button at the bottom
  5. Change the "Turn off monitor settings"To Never
  6. Retart computer
if this doesn't fix your problem,please let me know
Please rate this a fixya
Feb 02, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Monitor in sleep mode
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
my computer is on but screen is black and has power. How can I fix it?
Aug 27, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Goes to sleep
Hi
Pls check the power option settings in control panel.
Also pls check if the power management options for keyboard and mouse in device manager are enabled or not.
Pls try to create a new profile and check if the sleep mode is working in the new profile.
Pls try a System restore if the above steps don't work.
Dec 24, 2007 | HP Vs17 17" LCD Flat Panel Monitor
HP Pavilion F1703 17" LCD Monitor Logo
244 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
