Question about Acer Aspire 5100 Notebook
Can get the aspire to boot to windows
I have no recovery disk and when I press alt F10 it doesnt go into recovery, not sure how to go into safe mode any suggestion?
    Scholar:
  • 50 Answers
Try F8, that's usually safe mode. press it like once a second as it's booting.
what's your specific problem-- cant boot windows?
can you try putting a windows install disk in and choosing "repair" when it boots? (you want to make sure you dont format your drive though, repair wont do that usually if youre careful)
Posted on Feb 02, 2009
Windows cant open bootmgr is missing, press ctrl+alt+del but not working how to fix it aspire one D257
Have you tried a System Restore/Recovery? Can you boot to safe mode? Try the restore/Recovery procedure: Shut down, unplug, remove battery, plug in, push the on button and When Acer splash is on screen hold Alt and keep pressing F10...
Apr 14, 2013 | Acer Aspire One D257 Netbook
Factory reset for Aspire one without disk and alt + F10 doesnt work
The disk-to-disk recovery may be disabled preventing the Alt + F10 key sequence running eRecovery. To enable disk-to-disk recovery, you must do the following... (do not have an external monitor attached)
1. activate the BIOS utility by pressing F2 during Power On System Test (while Acer logo displayed)
2. select Main from the categories listed at the top of the screen
3. find D2D Recovery at the bottom of the screen and use F5 and F6 keys to set this value to Enabled
4. exit the BIOS utility and save changes.
The system will reboot.
5. while the Acer logo is showing, press the Alt key and the F10 key at the same time repeatedly
6. wait as Acer eRecovery starts up then follow onscreen instructions to perform system recovery.
Alternatively to the above, if Windows can be accessed, the recovery can be done by launching Acer eRecovery Management by running the program from the Acer Empowering Technology program group in the Start menu.
Mar 22, 2011 | Acer Aspire One PC Notebook
I have installed Windows 7 to my Acer Aspire One AOD255 but i want to revert it back to Windows XP and I no longer have the Windows.old folder. How can i downgrade it back?
If it originally came with Windows XP and it has the recovery partition still untouched (assuming the disk hadn't been formated to only one partition), you might recover the system from the hidden recovery partition.
To initiate this process, switch on the laptop and press F10 when the ACER logo appears (some computers need you to press ALT and F10 together, instead of the F10 only. If the Acer Recovery Management starts, you just have to follow the instructions to recover your system.
If nothing happens after pressing F10 or ALT and F10, you will need to get a Windows XP installation CD and a external CD drive to reinstall the whole system.
In this case, first you have to enter setup by pressing F2 at boot time, as soon as the ACER logo appears in the screen. Then, you will need to switch the SATA Mode to IDE from AHCI.
Select: Main -> SATA Mode -> IDE
This is done to allow Window XP to see your SATA.as an IDE disk and install the system.
When you get the external USB CD/DVD driver to use with a Windows XP installer CD, connect it to you laptop, switch it on and press F2 again to enter Setup.
This time, scroll over to the BOOT menu and press Enter. Scroll down to the last option USB CD- Rom and then use the F5 key to move it to the top of the boot list order. Then press Escape and then F10 and finally Enter. The computer will restart and load the CD and you can start the installation of Windows XP.
Hope this info may help you!
Mar 13, 2011 | Acer Aspire One D255-1549 Atom N550...
While trying to fix a friend's acer aspire one, i ran a defrag check. after rebooting once the check was complete, the computer will not boot up and sits on a black screen. all F8 screen options freeze...
The windows has to be reinstalled ( Formatting the Hard Disk with DATA LOSS ) Select models have the ability to have the operating system reinstalled from a hidden drive built into the computer.
To start the system recovery:
  1. Restart the netbook.
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery program has loaded, follow the prompts to reinstall the Operating System.
  5. Select ' completely restore to factory defaults
If this is not working, then get the Factory Recovery CD's to reinstall windows.
Oct 25, 2010 | Acer Aspire One PC Notebook
I did a windows update and now my aspire 5920 wont start. have tried in safe mode with and without internet but still nothing happens. i don't have a recovery disc can anybody help?
Turn on your laptop n try pressing Alt-F10....n try restart it....generally acer laptops work properly after pressing Alt F10.....
Also if u r able to turn on ur laptopn in safe mode then try deactivate windows update...and restart ur laptop in normal mode.....
Mar 13, 2010 | Acer Aspire 5920-6727 Notebook
My laptop will not start up or reboot properly, it has power failure when entering the windows xp start up screen when i do it normally or in safe mode...what do you suggest
press f2 during start up to enter bios,make sure disk-to-disk recovery is enabled ,save changes and exit then on restart press alt+f10 at the same time to enter system recovery then follow the on screen instructions
Nov 02, 2009 | Acer Aspire 3000 Notebook
Acer Aspire 5920 Wont Boot
Try clicking the Alt button and the F10 button at the same time right after you turn the laptop on, and see if it will go into the System Recovery mode. If it will, just follow the instructions for a partial or complete system recovery.
Mar 16, 2009 | Acer Aspire 5920-6727 Notebook
Acer aspire one not booting
your laptop has been turned off without shutting down. all your laptops registries are probably messed up. the easiest way to do is to reformat your computer or restore it to factory settings. unless you have some important files that you cant afford to lose.
Feb 07, 2009 | Acer Aspire One A150-1006 Notebook
Laptop system
Hi
Well this is a problem if you didn't make a factory disk nor backed up the system configurations then only thing that will work is to reinstall the operating system. Here is a trick that Acer will never tell you
press the on button and imedetly press ALT + F10 in this order ALT + F10 - ALT + F10 until it goes into recovery mode all the Acers that has 2 partitions have the recovery mode then click on recover to factory defult this will load the factory operating system + driversand applications
kind regards  Mervinh
Sep 22, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 5100 Notebook Logo
75 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
