Question about Brother HL-2040 Laser Printer
Paper light will not go off
I have filled the paper tray, but the paper light continues flashing
  • 3 more comments
  • michellesher Feb 10, 2009
    paper light will not go off.
  • kane_locke Feb 10, 2009
    I have cleared all possible jams; there is nothing inside the printer. However, the printer continues to insist it is jammed, and will not reset no matter what I do. The Paper light continues to flash.
  • Anonymous Feb 15, 2009
    not only will the light not go off, the printer won't work. i've uninstalled and reinstalled printer, turned the printer on and off several times, and the paper light is still on - while the tray is full.
  • gfgflower Feb 17, 2009
    I have sam problem - paper light won't go off - there is no paper jam - I have removed toner cartridge and paper tray over and over and still no luck. Any more suggestions?
  • Anonymous Feb 18, 2009
    Same problem here, if i open up the printer and fiddle around will that void the warrenty? I need a screwdriver.
    Scholar:
  • 50 Answers
You may have a small jam or a piece of paper that is still inside the printer.  You may have to look for a smaller piece of paper.  I have had this happen to my laser printers before and it was because there was a plastic arm that is inside the printer that came loose during a paper jam and it wouldn't accept paper until I reattached the arm and then the printer would accept the paper.
Posted on Feb 03, 2009
    Problem Solver:
  • 9 Answers
I saw this solution elsewhere on this site -
take out the toner cartridge; paper can jam under there and you can't see it.
Posted on Feb 15, 2009
Sharp AL-1631: Flashing H-4. Paper tray light is
H4 indicates that you have no power for your heater lamp. Either the thermostat or the lamp is open. For the thermostat, you can reset it if you know how to remove the fuser section and its cover so you can see the thermostat and reset from there. For the heater lamp, check its continuity using a tester.
Jul 21, 2009 | Sharp Office Equipment & Supplies
Printer Fault
this is sound like paper size proplem.it can be adjusted .but before you adjustment.check your paper tray guides.and look behide the tray for any paper .
power machine off and open the trays that indicate exclamation mark and than power the machine on
if that works than your tray are the problem.
hope that help
Jan 09, 2009 | Office Equipment & Supplies
Paper feeder
One of two things, There is a black plastic actuator that may have fallen off. It hangs down into the paper tray and is pushed up when the paper tray is pushed in. Remove the paper tray and see if you can locate the actuator.
The more likely problem is the sensor in the paper feeder, I don't believe that sensor is a spared item, I have always replaced the paper feeder to resolve that problem.
Nov 06, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
May 28, 2008 | HP LaserJet 1012 Printer
Printer purchased 15/5/08 on trying to set up red light continues to flash so unable to print and proceed the screen only shows the language selected and fails to move on
Usually printers like to flash red under the following conditions:
1. Paper jam. So be absolutely sure there is no paper stuck in there, or that a piece of paper is not partially fed too far for the printer to pick it up as a new piece.
2. Out of paper, speaks for itself.
3. Wrong paper tray selected. i.e. you install the printer using default settings, but somehow, the printer is expecting to 'see' paper via an alternate input / tray. Check the printer settings to see if the paper tray matches the tray you are feeding paper too.
This one has caught me out many times.
Hope that helps.
May 16, 2008 | HP Office Equipment & Supplies
Printer Error
there is button or clip backside of the printer.......u just press it and open the tray..........it is also possible that u don't attch ur usb wire to the cpu u just check it .........may be it will be good........
Apr 19, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Brother HL-2040 Flashing Paper LED
Try send one paper manually, then it will pick up paper from the try automatically.
Feb 06, 2008 | Brother HL-2040 Laser Printer
Not printing
There is probably a paper jam in the tray feed path. The other situation is that the tray paper pick up roller has become hardened/polished, or the paper tray paper is greasy. First step, take the paper from the tray, and fan it out, so each sheet is separated from the next. try it with jut a dozen or so sheets, change the paper.
Thoroughly check the paper feed path.
If not working, then check/clean the rollers.
Jan 20, 2008 | Kyocera FS-720 Laser Printer
Error
1. Verify the following: * There is sufficient paper in the paper tray (at least ten sheets). * The paper tray is not overly full. * The paper stack is touching the back of the paper tray. 2. Slide the paper guides so they fit firmly against the edges of the paper. 3. Press the Resume button to continue printing. good luck :-)
Jan 11, 2006 | HP DeskJet 5652 InkJet Printer
Brother HL-2040 Laser Printer Logo
62 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
