Question about Acer X193W LCD Monitor
My PC has no volume, I've tried everything I can but still no volume. Now wondering if it might be the monitor (x193W) but can't find where to adjust volume on monitor - Can you advsie please?
  • dianne_augus Feb 02, 2009
    Thanks for that but PC volume control is on and no mute buttons are checked. Is there a volume control on the monitor?
The full specs on the product note that there is no audio output. I just purchased the same model and am returning it because while it has power, VGA and DVI connections it does not have audio connections, which means no audio output on this unit.
Posted on Mar 08, 2009
I don't think the Acer x193W has built-in speakers, and therefore won't have a volume control. You do have separate speakers plugged in, right?
Posted on Feb 03, 2009
Go to the task bar and right click on the speaker icon, this will open up your audio settings, check too see if the master volume is all of the way up and also make sure the box next to mute is not checked. If it is uncheck it.
Posted on Feb 02, 2009
  • epj51 Feb 03, 2009
    Are you sure that your computer has an audio driver installed? The simplest way to check is to turn your computer off and restart, do you here the typical windows start chimes? If not go to the start menu, click on "My Computer" when the next screen opens, highlite "Local Drive (C:)" , in the column to the left click on "System Information", the next screen that opens will be "System Properties", click on "hardware" this open up another screen. From this screen click on "Device Manager" once this opens scroll down until you find "Sound, Video and game controller" *note: some just say sound. Click on the + to open up thie list of sound drivers. Find the "audio Driver" and right click on it, select "Update Driver" to see if it updates, also if it is not installed it will not be listed. You can also click on properties from the same screen and troubleshoot the driver. Hopefully this works.
    Good Luck!
Hi, I have an Acer X193W monitor that recently got an update that I guess was from 2008. When I restarted the computer suddenly everything was brighter colorwise. As in Red looked like pink and everything...
you should be able to uses "system restore" to remove the update or to take the computer back to the time before the update. here is a link for a article that will explain it all. if that doesnt work then you can search acers web site for drivers that are compatible with vista. i think you just have a driver issue. in fact, search for the drivers first then use restore if you have to. here is the article.
http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/
i just did a quick Google on Acer x193w vista drivers, and found several spots for drivers, here is 1.
Acer-X193W.html">http://www.bravofiles.com/driver-Acer-X193W.html
Apr 23, 2011 | Computers & Internet
When i connect the monitor to my pc and turn it on it starts to display the desktop and cuts out monitor stays on but the screen goes black
try to adjust resolution to 1440 x 900 / 75.0 Hz or less , are you try to re-install windows if no like to try
if you see that is helpful please don't forget to vote me
best regards
Apr 23, 2011 | Acer X193W LCD Monitor
No sound from this monitor. I have everything plugged in , volume icon is turned all the way, mute is off, adjusted speaker levels, etc on my desktop.
Firstly,
You need to check if the green cable from the computer tower is blugged into the back of the monitor (The cable looks the same at both the ends) this is for the output to come through the monitor.
If that is plugged in and if not working, Try a headphone on the tower and check if the sound is coming from the headphone, If yes, You will have to adjust the volume on the monitor or the speaker of the monitor might have gone bad. If there is no sound coming in, Then the problem is with the tower and not the monitor.
Dec 02, 2010 | Acer X193W LCD Monitor
Monitor screen won't stay up. Monitor is connected to Gateway PC which is running Windows 2000.
http://www.retrevo.com/support/Acer-X193W-Monitors-manual/id/7197ag005/t/2/
You have to prove if it's the monitor or the PC, you must swap out, for Known Good, units. Check your monitor on another PC, try another Monitor on your PC. This will soon zero you in on the faulty item, be it, the monitor, or the Video card/PC
May 11, 2010 | Acer X193W LCD Monitor
Low volume in acer x193w
install the audio drives again then it will worl fine
Jun 25, 2009 | Acer Aspire 5100 Notebook
Acer x193w LCD Monitor repeatedly auto configures.
Here is a link to get the manual:
http://www.acerpanam.com/synapse/data/7117/documents/X193W%20(Qisda)%20user's%20manual.pdf
Starting on page 15 are the directions for the monitor controls. Page 17 indicates a "RESET" feture to Clear the Old-Statuses of "Auto-Configuration". There are quite a number of setting for this monitor.
Jun 11, 2009 | Acer X193W LCD Monitor
Just bought a acer x193w lcd monitor no sound
I assume the monitor has speakers built in . Have you plugged the sound card in to the monitor?
Jun 03, 2009 | Acer X193W LCD Monitor
Acer monitor x193w, no sound.
Please try to check the sound device status if its working properly thru right click My Computer icon > Properties > Hardware tab > Device Manager > (double click) Sound, Video & Game Controller OR System Device > System Speaker. also, take note of the Troubleshoot tab. If still it doesn't work, I think you have to reinstall the sound driver (from its motherboard software CD if it's built-in type). best regards
May 11, 2009 | Acer X193WBD Monitor
How to adjust intensity of Acer X193W LCD monitor manually
if you go into the screens menu, there will be a button for contrast and brightness.  When you have the one you want selected, press munu again and that will bring up the dialog to change the percentages.
Mar 06, 2009 | Acer X193W LCD Monitor
Acer's x193w killing my eyes..please help
First off, LCD monitors have what is called a 'native resolution' and that is why it is recommended to be at 1440 x 900. That is the resolution they work best at. My first suggestion is to try to move the monitor closer to you. If that is not possible, try right-clicking on your desktop, click on the Properties tab (That is where you change the resolution. I am doing this for a Windows XP machine - if you are running Vista please let me know and I will try to walk you through it there). Click on the "Advanced" button and in the "General" tab, there should be a "DPI Setting" drop down box. There is usually 96 DPI and 120 DPI. Try 120 DPI and see if that helps.
Second, try using your monitor's menu settings to help the color settings. On your monitor there is a "Menu" button of some sort. Press that and select "Acer eColor Management" and try "Text Mode" to see if that is easier on your eyes. You can also manually adjust the screen and lower the strength of the red color by picking "User" instead of "Acer eColor Management" and selecting the icon that looks like a pyramid of 3 dots. Try adjusting the Red slider and see if that helps.
Jan 02, 2009 | Acer X193W LCD Monitor
Acer X193W LCD Monitor Logo
251 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
