Question about NetGear WGR614 Wireless Router
Can't access shared printer
My son recently installed a netgear wgr614 v7 on my 2 machine wired home network. Since then, while both machines have internet access through the router the second machine can no longer access the shared printer attached to the 'host' computer and none of the shared files and folders on either machine can be accessed by the other.
Both machines are running XP
Can you help me?
  • 1 more comment
  • mathman64 Feb 12, 2009
    I followed the directions in the first solution. Actually I had all ready installed the router. It didn't help. Computer 2 can't access computer 1 at all. Computer 1 can access the shared files on computer 2 but none of computer 2's shared assets show up in My Network Places 1. I have to do a search for them to gain access to them.
    I have the windows firewall turned off and am using Norton Internet Security's personal firewall. Do I turn it off? Then I will have no firewall active. Will the router act as a firewall for my system then?
    I turned off the Norton firewall. That gave me complete access. I turned the Norton firewall back on and I still have access. I just had to turn it off and turn it back on again. Does that make sense?
    Thank you for the help and guidance. Greatly appreciated.
  • 19,396 Answers
Nice to know that you solved the problem, thanks for using Fixya.
Posted on Feb 12, 2009
    President:
  • 2,559 Answers
Open internet explorer,type 192.168.1.1 hit enter
you will see a pop up like this.
Can't access shared printer - 799ef92.jpg If no password has been setup yet,just leave the user name blank.
and type Admin for the password.(if the password has been changed you will need to enter the new password)
This will open your router setup page.
Go into the settings and and allow uPnP.
This should take care of it.
  • Randy Hough
    Randy Hough Feb 12, 2009
    You can also go into you firewall program and allow the sharing.(you would need to do this to all the computers)
  • 10,515 Answers
The answer
Using this happens when you have Norton Antivirus installed.....uninstall and you would be able to connect.....
Make sure that your firewall is turned off :)
Take Care.
    Genius:
  • 2,920 Answers
You may want to unistall the printer from both machines and re install it on both of them to see if that wont allow you to access the printer that way.
  • 139 Answers
Hi
The reason why you can't access your drivers and printer can be many.. But I will try and give you few steps to solve ur problem..
On one of the systems where the router is directly connected make sure you don't have a firewall installed which is blocking your sharing mode.
2. Open my computer go to tools ->folder options -> view->IN the last option you will find system file sharing recommended uncheck the following option and apply ok.
3. On your storage drive .i.e. your D drive or E drive go to properties and then you get a new tab i.e. security tab.
4. Now share your drive on one system and then click on permission then check all three boxes.
5. Click on apply and ok .
6. On your Local area network go to properties (i.e.) your wireless connection -> go to advance and click on settings turn off firewall for few min go to exception and turn on file and printer sharing. apply and ok.
7. Now on your system which has printer directly connected and drivers properly installed, right click on the printer and set as default printer.
8. Again right click on the printer and go to sharing and share the printer. to used on your wireless network.
9. On the 2nd laptop click on start go to printer and faxes and then click on add printer select the option browse printer and it will show you the shared printer.
10 . INstall the drivers and set as default printer.
Your printer is shared on the network.
( Note - In case you still find a problem restart your modem router and both machines together)
Please rate this fixya..
Posted on Feb 11, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Two ideas you may want to try:
  • right click on "My Computer" of both machines, click on "Properties";
  • click on "Computer Name" tab;
  • ensure that both share/use the same 'Workgroup', otherwise click on the Change button to modify;
  • additionally, use static IP address on the 'host' computer where the printer is connected/physically installed.
and
  • delete the icon of the printer inside the Printers & Faxes on the 2nd computer;
  • verify that the printer is shared in the 'host' computer;
  • click on 'Add Printer' inside Printer & Faxes of the 2nd PC;
  • click on Next, tick on 'A network printer....';
  • click on Next, tick 'Browse for a printer', click on Next;
  • follow on screen instructions.
Good luck and thank you for using FixYa.
    President:
  • 2,110 Answers
You have to turn off the firewall in the control panel...
    Sergeant:
  • 250 Answers
Instructions Things You’ll Need:
  • Wired or wireless router
  • Cat5 cable
  • Ethernet network interface card or wireless card
  • Step 1:Can't access shared printer - 59101_65x95_aspect.jpgTurn off both computers you want to connect through a router. Open your computers' chassis and install the ethernet network cards if your motherboards don’t have them built in. You can also install your wireless ethernet cards this way. Close the chassis when installation is complete.
  • Step 2:Boot up your computer systems. Install the software for your ethernet cards in both computers following manufacturers' instructions. Newer computers will install this software (driver) automatically.
  • Step 3:59103_65x95_aspect.jpgPlug one end of the Cat5 cable into the ethernet network card you just installed in your computer. Plug the other end into an open Internet slot on the back of your router. These slots are numbered. Perform this step on both computers.
  • Step 4:Plug one end of another Cat5 cable into the slot on the back of your router labeled ethernet. Plug the other end of the cat5 cable into the back of the Internet modem provided by your service provider. Perform this step only if you want to share Internet access between both computers.
  • Step 5:Plug your router power supply into a power source. Turn on your computers. Install the software. Turn on your router when prompted.
  • Step 6:Your computers are now connected or networked through your router.
Tips & Warnings
  • If you choose to connect both computers wirelessly, the process is the same, except you will need to use wireless cards instead of cat5 wires.
  • Different manufacturers make different routers and network interface cards.
  • Connecting or networking your computers using wires is safer and faster than using wireless access cards.
  • Networking your computers using routers allows you to share printers and other resources but can be dangerous if not secured properly. Use strong encryption technology to secure your data during and after transfers.
Posted on Feb 02, 2009
  • 679 Answers
Please tell me in what format u use another computer HDD. (as NTFS or FAT),
and also tell me what operating system u use for your computers.
Thanks
  • 1 more comment
  • rockfixya
    rockfixya Feb 02, 2009
    on the pc with the printer attached, right click on the printer, click sharing, check "share this printer. The icon should now have a hand under it(indicating it is shared.
    If you still can't find it, make certain that you've either configured or disabled any firewalls or other blocking apps.
  • rockfixya
    did you "browse" for the printer from the second system to add it, or did you just try to enter its location? You should try to browse for it. This will show the workgroup and all comps, doubleclick the one with the printer attached and the printer will show, doubleclick the printer and it will install drivers over the network. If any of that fails to happen, check your firewall settings, make sure both comps are in the same workgroup and there are no permissions that might be preventing the setup.
  • rockfixya
    go to the link for more information>>
    http://www.zeropaid.com/bbs/archive/inde...
    Sergeant:
  • 326 Answers
How should i define a printer in a wired intenet home?
Well, if the printer is network capable, it can be connected to the network router either wirelessly or wired, whichever the printer has and you wish to use. Once you have made the connection (you need to set it up with one of the computers for network use), then you can go to each of the other machines and and "add printer", looking for the network device. Each machine will detect the printer, and then load drivers to support the use. If your printer is NOT network capable, it gets slightly more complicated. You would have to install the printer on one machine, then ensure that the "share printer" option is selected. Other machines can use that printer on the network so long as the machine that the printer is attached to is powered on and on the network. They would do a search for the printer the same as before.
Nov 03, 2015 | Routers
Does a laptop work outside my home without a router
Sir
Yes it can work outside of your home,
Process:
1. Click on the WiFi icon on the lower-right-corner of your screen.
2. A list of available wireless networks will appear on the right. Simply select the wireless network you wish to connect to and click the Connectbutton.
3. If the network that you have selected is secured (password protected) you need to type in the security phrase (Passphrase/Network key) and click the Next button.
4. You will be asked if you would like to enable sharing between PCs and connect to devices within the network. Selecting Yes will turn on sharing and No will leave it off (for more information about file/media sharing, visit http://windows.microsoft.com/en-US/windows/support). After selecting your sharing preference, the next screen will show you if you have successfully connected to the wireless network or not.
I Hope By Now your Netgear Router issue Resolve,
In case you still having Netgear Wifi Problem Contact Us On for :
Netgear Support
Apr 02, 2014 | NetGear WGR614 Wireless Router
Im trying to use my mobile phone through wifi on my home broad band but says i need a pre shared key number how do i find that number
The pre-shared key is nothing but the password you use to connect to your home network. Just type in the password and connect
Jun 14, 2011 | NetGear WGR614 Wireless Router
Have a wireless network through netgear WGR614 v6 working fine with 2 old ibm/toshiba laptops with vista and an acer on ethernet recently bought a new hp laptop with windows 7. This laptop gets very...
check if the laptop has wireless utility other than the built in windows wireless. (example intel proset wireless). if yes, uninstall the wireless utility and Update the wireless driver of your laptop by downloading the latest driver from ho web site.
Jun 10, 2010 | NetGear WGR614 Router
How do I know what my SSID is for my NetGear router Can I hard wire a printer and also send jobs by wireless to same printer? Do I have to download the software in order to print wireless from a different...
Go into the router configure to view the wireless settings, it contains the SSID and encryption etc.
Open IE browser and enter the Netgear URL configuration IP address (http://192.168.0.1)
A network printer must have a built-in print server or be attached to a print server device on the network then all the computers on the network can access this printer.
For a run of the mill printer to work as a network printer it needs to be attached to a computer which is on your network and the printer needs to be setup as a shared printer. This printer and computer must always be switched on for the other computers on the network to access and print to this printer. This method does not require any additional software.
Nov 18, 2009 | NetGear WGR614 Wireless Router
File sharing problem after installing Netgear DG834G ADSL/Wireles
- Run the Windows Network Wizard in each computer on the network.
Mar 10, 2009 | NetGear DG834G Router
Internet connnection
Access your wireless router by typing it's ip address in your browser. Log in and change your netkey password.
May 23, 2008 | NetGear WGR614 Wireless Router
Home network with 2700hg-b and netgear wireless issues
You didn't say what operating system you have but check your Network and Sharing Center in Control panel and turn on the file and printer sharing feature in Windows.
Using Vista, click on Control Panel- Click on Network and Sharing Center-configure settings.
Hope this helps.
Mar 24, 2008 | 2wire 2700HG-B Router (2700HGB)
NetGear WGR614 Wireless Router Logo
32 people viewed this question
Top NetGear Routers Experts
Barry37
Level 1 Expert
MrNutsy
Level 1 Expert
Phillip Whisenant
Phillip Whisenant
Are you a NetGear Router Expert? Answer questions, earn points and help others
