Question about Toshiba Satellite A65-S126 Notebook
NO START toshiba a65-s126 will not boot / start up. Does the this model store the bios on the hard drive?
  • 1 more comment
  • rebelcwgrl Feb 22, 2009
    the laptop was working fine the night before. I went in the next day to bring the laptop out of hibernation. Everything came up fine, then it just froze. when I tried control/alt/delete....it would not work, so I was forced to use the power button. when it came back on it opened with a screen wanting me to tell it which mode to start it in. The only problem was the computer froze again in less than 3 seconds. Now nothing shows up when I try to start it. No BIOS page to direct it to a mode, no windows, not even the Toshiba startup, (the first frame you are supposed to see when you power up) is not showing up. It is like the fan and hard drive seem to be running, but nothing is happening. I use this laptop to do my college papers on. I can not afford for it to break now. HELP !!!
  • carl884 Feb 23, 2009
    I foud a solution to my issue. I removed the battery, removed the HD, then reinstalled the HD and battery, the laptop powered up, I found an bios upgrade on Toshiba.com flashed the bios in windows since the old one was Version 1.4 and the new one was Version 1.9, after all that the laptop is faster than before and has much better response.
    Carl
  • rebelcwgrl May 11, 2010
    What I want to know is how to get the laptop to boot and get a visable screen. Is my BIOS chip damaged or quit working or what ?
    President:
  • 2,110 Answers
No bios is stored in CMOS chip on the motherboard...
Posted on Feb 04, 2009
My laptop Toshiba Satellite model: PSA 60U-02K015. The problem is the system keeps going in a loop in safe mode. It will not go to any windows program. How and what is the problem. How to download any pach...
During start up does it give you any options to start it normally?
Try hitting F8 during start up to see if your able to get it to boot normally.
Not sure what "pach" you are talking about.
BIOS shouldn't be the problem.
Sounds like you have a virus of some sort.
Nov 02, 2010 | Toshiba Satellite A65-S126 Notebook
How to clear cmos?
There is no need to reset the BIOS if the Toshiba boots up normally.
The BIOS/CMOS configures the various devices in the laptop so it function correctly.
Oct 12, 2009 | Toshiba Satellite A65-S126 Notebook
How do i open the bios?
When you start you computer, you'll need to fit a key F1-F12 depending on your motherboard's model and you can access the bios. This F1-F12 number is usually displayed quickly before the motherboard boots off of the boot device, and it can likely be found in a reference manual
Jul 16, 2009 | Toshiba Satellite A65-S126 Notebook
Satelite will not boot
You remove the newly install RAM,then compare it with older one is both of same frquency.
it might be different one.
if same then insert ram properly..............there is no need to reset BIOS.
Apr 05, 2009 | Toshiba Satellite A65-S126 Notebook
Laptop won't boot up.
http://www.cgsecurity.org/wiki/CmosPwd I have used this program at school to bypass bios passwords and i find it to work well.
You may also try to type Toshiba where it asks for the password.
Mar 10, 2009 | Toshiba Satellite A65-S126 Notebook
Driver for video & modem of toshiba satellite a65-s126
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
go to website click download in 1st box select portables 2nd box satellite 3rd box your model number hope it helps
Dec 24, 2008 | Toshiba Satellite A65-S126 Notebook
Bios display
If you have Toshiba Console installed, you can set your BIOS to the defaults.
If not, go to:
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp?moid=713852&rpn=PSA60U&ct=DL&BV_SessionID=@@@@0874164868.1224211563@@@@&BV_EngineID=ccciadefhdhmidjcgfkceghdgngdgmn.0
and download it there.
Good luck
Oct 16, 2008 | Toshiba Satellite A65-S126 Notebook
Memory for toshiba A65-S126
Its in the middle of the laptop at the back side..you have to go through the manual for changing the ram.. there will be 2 locks ,you just have to press and pull it up.
Jul 21, 2008 | Toshiba Satellite A65-S126 Notebook
Failure to load windows
If you can try a different hard drive. And make sure the format of the hard drive that's installed doesn't freeze or doesn't complete.
Those are just the first things that popped into my mind,
I'm sure other's will have more suggestions.
Good luck.
Feb 26, 2008 | Toshiba Satellite A65-S126 Notebook
Toshiba Satellite A65-S126 Notebook Logo
212 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
