Question about Frigidaire FGF378AC Gas Kitchen Range
F 31 error code on gas range
When I turn on the oven it shows f 31 code
    Problem Solver:
  • 12 Answers
Try to unplug the range and let it be off for a few minutes. Then go ahead and plug it back in.
Posted on May 01, 2009
Getting an F15 error code when trying to start Oven.
Error code f15 'Frigidaire FEB30T7FC Stainless Steel ...
www.faqqq.com/.../error-code-f15-frigidaire-feb30t7fc-stainless-steel-ele...
Error code f15 'Frigidaire FEB30T7FC Stainless Steel Electric Double Oven ... I'mtrying to open up a Unity3D game.exe that is on a remote computer through my main desktop. ... How 2016 will be the start of your virtual reality future - CNET.
Kenmore range shows f15 error code - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Range, Oven & Cooktop Repair
Oct 31, 2010 - 10 posts - ‎5 authors
Kenmore range suddenly started flashing f15 error code. With Thanksgiving just around the corner, i need help with this repair. Thanks.
Dec 30, 2015 | KitchenAid Kitchen Ranges
What dose F3 code mean
Amana Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Amana-Appliance-Fault-Codes.aspx
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
Amana Gas oven Fault Code F3 - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges-cooktops/143114-amana-g...
Nov 17, 2010 - 2 posts - ‎1 author
Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
Mar 15, 2011
Range keeps giving error codes E0/F3 and E4/F3 and the ...
Nov 22, 2010
Replaced Sensor Still Getting F3 Error
Sep 20, 2008
F3 Error code on whirlpool Range
Sep 10, 2007
More results from forum.appliancepartspros.com
Amana Fault Codes - Appliance Help O
Dec 25, 2015 | Amana Kitchen Ranges
F7 error code on GE gas oven model # JGBP90MEA2BC
On this model, code F7 means there is a keypad malfunction, and therefore the range's "computer" isn't getting a valid signal from the keypad. It may be a stuck "touch-key", a bad connection between keypad membrane and the range/computer connector, or more probably a faulty keypad membrane.
In some cases it can be a defective computer module. You can test whether the problem is the keypad or computer unit by disconnecting the keypad entirely. If an error code F7 still shows, then the computer is faulty.
If this was helpful, please rate via the helpful button.
Nov 04, 2014 | Kitchen Ranges
F3 E2 Error Code, but then oven won't turn off
The oven controller may be failed (stuck relay) or the oven temp probe may be failed but this would normally cause both elements to be on at least some of the time.
Nov 17, 2013 | Kenmore 79383 Dual Fuel (Electric and Gas)...
FRIGIDAIRE OVEN BEEPING ERROR F 31 MESSAGE
Hello parmantal - Typically error code F31 indicates that the unit has a shorted probe connection problem. Try resetting the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and this will usually clear most false codes. If it proves to be ineffective, contact a professional to move forward accurately. The technician will need to check the resistance and/or harness between the EOC and probe connector. Depending on the diagnoses part(s) will need replacing.
Dec 18, 2012 | Frigidaire FEF352 Electric Kitchen Range
It show F11 Error code
Good Afternoon Friend,
I see that you are having trouble with your Frigidaire freestanding gas range showing an F11 error code. F11 means your appliance has detected a Shorted Key, which could also be a key that has been detected as pressed for a long period of time. This will terminate all oven activity. What you can do is to press the "Clear" key and if that does not work you will want to give your range a hard reset. You can do this by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Turn the oven on and if you are still receiving the F11 error code, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Feb 07, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Oven does not start and gives code 31
Check this link:
http://www.applianceblog.com/mainforums/showthread.php?t=11880
It sounds like your oven probe is failing or has failed. The control board could possiblly be bad too
Apr 18, 2009 | Kitchen Ranges
F 31 Frigidaire gas range
if it cooler that the temp set its the theromstat f31 sorry don.t know
Dec 20, 2008 | Frigidaire FGF326AS Gas Kitchen Range
ON my Gas range there is and F3 error code comes up when I turn on the oven? please help!!
hi thanks for the question f 3 fault code shows a open oven sensor replace this part its located in oven left top corner looks like a small pencil remove from back and replace thanks please accept and a positive feed back thanks the appliance doc
Sep 23, 2008 | Frigidaire Kitchen Ranges
F3 error code
f3 is the code to replace your oven sensor most you replace by pulling the back panel and removing the scerws
Feb 17, 2008 | Maytag MGR5750 Gas Kitchen Range
Frigidaire FGF378AC Gas Kitchen Range Logo
216 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
