Question about Frigidaire GLTF1670A Front Load Washer
LG washer WMo532HW-loud noise & leakage
From last 2 months making noise more in last 3/4 days .Yesterday found leakage at bottom.
What possible cause?
Repaire estimates-----
  • mcthambu Feb 02, 2009
    loud noise & leakage problem, when spinning.
    Sergeant:
    Novelist:
  • 176 Answers
Your bearings and drum shaft seal are leaking. This is a common problem with front loader washers and it is very expensive to have repaired. If you are handy you can repair this yourself for far less. If you think you are but are not handy, do not attempt. Buy only Japanese made bearings and not Chinese because for the small price difference it just is not worth the chance. Do your research!!!!
Posted on Feb 08, 2009
Why does my boot keep tearing, original lasted years, all replacements are months.
had this once before
A wire from an under wire bra found its way in-between the inner and outer drum
every now and again it would find its way to the seal and tear it
then one day the drum started making a loud grinding sound
on further investigation we found the wire
that fixed both problems
Nov 11, 2017 | Bosch Nexxt 500 WFMC3301 Front Load Washer
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Pump makes noise and water runs out of bottom of machine error ob
HI. You may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case, replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
A broken impeller will wobble inside the pump housing, causing loud noises during operation. This is a strong indicator of pump failure. This will, also, cause leakage as well. the integrity of the pump housing will be compromised, leading to this leakage.
Sep 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Just replaced Serptine Belt now car making loud
It's not uncommon for a new belt to require re-tightening soon after it's been replaced. Check the belt for any excessive slack (shouldn't have more than 1/2 -3/4" ). A loose belt would be one possible cause for the loud noise you describe.
Jul 15, 2009 | 2003 Cadillac CTS
Frigidaire tumble action frontload washer loud knocking noises
These are the stabilising blocks. They are there to stop the knocking and noise. You should be able to buy them. Try the manufacturer or go on Yahoo or Google search for wash machine spares. Hope this helps.
May 20, 2009 | Frigidaire 14 Cycle Tumble Action Washer
Did you resolve your dryer / noise?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
7687t
Apr 14, 2009 | LG DLG5932W Gas Dryer
Lg wm1832cw front load washer
One of 2 things may be causing the loud noise.  Either the rear bearing on the drum has failed and will need to be replaced (very expensive) or the drain pump has a bearing problem and is making a very loud noise when it is draining (not too expensive).  Either way, you will need a qualified LG technician to diagnose and repair the problem.
Jun 14, 2008 | LG WM-1832C Front Load Washer
Lg WM1812cw makes alot of noise when in spin cycles.
There are always bearings. This model uses a direct drive brushless DC motor so there are no belts and such. Without actually hearing the noise with no load, it's hard to say what may actually be wrong. Any time a motor makes an abnormal noise, you can expect it won't last too much longer. I have the same model so now I'm worried.
Jan 13, 2008 | LG WM1812C Front Load Washer
LG refrigerator makes loud noise and then stops running.
You are seriously frozen up. Defrost the unit completely. Then, be aware that 'window shopping', leaving uncovered liquids in the box and poor door sealing (too heavy a load on the door ... too much on shelves) can cause condensation. Defrost with hot air or leave unplugged and open for about 2 days. You'll see alot of water come out.
Jan 10, 2008 | LG French Door Cabinet Depth Refrigerator...
Frigidaire GLTF1670A Front Load Washer Logo
430 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
