Question about Home
Whirlpool dishmachine drain problem
My Whirlpool dishmachine has over a gallon of water remaining at the end of the wash/rinse/drain cycle. A small amount of water is normal. Is a gallon + normal. If not what should be done to drain the excess.
    Problem Solver:
  • 19 Answers
You first need to check the drain hose .The hose needs to form a loop higher than the drain pipe that it is attached to.If their is no loop than the water can come back into the dishwasher
Posted on Feb 03, 2009
Kenmore HE2 flashing lights
did the technician point out wat needs to be repaired
Aug 24, 2008 | Kenmore 46462 Front Load Washer
Whirlpool Duet washer does not indicate end of cycle and unlock door
Most times this problem can be caused by a blocked tube to the pressure switch,..
Mar 03, 2014 | Whirlpool Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
At the end of the rinse cycle, water and suds will
Does water empty on spin? if not to check for blockage remove waste pipe from drain, place as low as possible into bowl, if water flows then fault likely to be on pump, if no water flows then pipes blocked and need to be removed to clear them. Good luck
Feb 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer won't drain after rinse cycle
If you lay the drain hose down into a bucket does water come out fairly quickly?
If so then it is not a blockage
You may have a coin or other small object in the pump which stops the impeller turning so no pumping action
Only solution is to check if the pump is free to turn either via the filter opening or taking the back panel off (Remove power before doing so ) and turning the pump by hand (there will be a fan blade on the end which is connected directly to the impeller.
If that will not turn very easily then you need to take off the hoses and check what is happening with the pump unit
Apr 13, 2009 | Whirlpool LSR5132PQ Top Load Washer
Won't drain
check the water pump filter. located at the front of the water pump assembly. it could be clogged with dirt and small clothes such as socks and lint.
tnx 4 using fixya,
drcool
Oct 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Ultima Wash II Intermittent Rinse/Spin
Hi, the water not drain , the drain pump was stuck , causes are the small linen and other foriegn materials are bind the pump infeller , pump connot completely turn . so drain stuck need to clean , also the drain hose have sedimentation of soap and dust.
Feb 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer does not drain water
You have a sock in the pump. If no noise in spin you have a bad lid switch.
Mar 27, 2007 | Whirlpool LTE5243D Top Load Stacked...
Water flowing back into washer after wash
There is a back flow valve attached to the outlet port of the drain pump. It is just a small rubber flap. This sometimes comes loose or remains open due to debris and allows the water in the drain hose to flow back into the machine after the drain pump shuts off. It can be checked by removing the drain hose from the pump inside of the machine. You will lose all of the water in your machine (about 1/2 gallon)when you do this so be prepared with a bunch of towels.
Feb 14, 2007 | Whirlpool GHW9100L Front Load Washer
Home Logo
74 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
