Question about GE Zoneline AZ38H12DAD Split System Air Conditioner
Unit making loud squeaky noise
Whien unit turns on it is producing a loud roaring noise accompanied with a squeak
  • Anonymous Apr 07, 2009
    ac is squeaking and is loud, but the ac and heater are both still working it's just real noisy. A friend said it was the bearings on the motor and they will have to be replaced. Just wondering if this sounds like te problem and if not can it still be fixed instead of having to buy a new unit
  • John Tripp
    John Tripp May 11, 2010
    Are you having any failure of cooling or heat function? If you need help let me know. Make sure the mode# and make are the same listed in your request. That helps both ofv us.
  • GE Master
  • 4,638 Answers
Http://www.youtube.com/watch?v=7n5tywSdWKs
This is a cool video with link to applience parts for help and answers
Posted on Feb 02, 2009
My new fireplace insert has white streaks above flame.......on inside of unit when turned on
I take we are talking about the glass on the front ? if so turn fire up to high for 5min letting the glass heat up this should help remove the streaks .
Jan 08, 2017 | Heating & Cooling
How do i deal with the dripping of water from my Mitsubiishi split system from inside unit? Will putting the unit on 19 and then turning it full bore clear over condensing?
NO
the water is condensation from the humidity in the air turning to water on the cold evaporator core
normally it drips into a tray and drains away outside
if it is inside ( running down the walls it indicates
the drain hole and tube is blocked or the evaporator core is covered in gunk and holding the water up and not dripping where it is designed to
Call an accredited ac specialist shop to clean the fins and drain tube
Jan 06, 2017 | Heating & Cooling
Mitsubishi slit air conditioner model MSZ-GA80VA I turn on and turn off cauting out door unit fuse blown I replaced still The fuse is blow is the out door air con unit Note.unit in door stop not inpos
turn off everything electrical in house and retry with good fuse or breaker if still blows unit needs repair possible shorted capacitor? if it runs it may need to be on its own circuit dedicated to it alone
Jan 05, 2017 | Mitsubishi Heating & Cooling
Cooloing is not coming down from room temperature
The unit needs service. Call a technician! You can:
Check your air filters
Clean outdoor coil by turning off all power at breakers and tstat, clean o.d. coil with water hose
Inspect indoor coil (if you can) for build up or debris
Other than that? May be low on freon. A service tech will cost $ BUT not having the unit service will cost more due to electrical consumption and excessive run times shortening the life of the system.
Jun 24, 2015 | Heating & Cooling
How do I fix my electric heater
  • sounds like the sensor or bulb that tells it to start the blower is defective/ im not familiar with your unit but this seems the most logical answer most furnace will not turn the blower on right away usually 90 seconds after the ignition but will also run longer to exhume any dangerous carbon monoxide. Electricic heaters are different. What type of unit do you have
Dec 25, 2014 | Heating & Cooling
Electric Furnace stopped running
You have one of two problems. Either the capacitor for the motor has failed or the motor has failed. I would turn off the power to the unit and see if you can locate the capacitor and remove it. An ac supply or electrical supply house can match up the capacitor. This is relatively inexpensive. Otherwise you will need a new motor.
Nov 11, 2014 | Heating & Cooling
Why can't I lower my honeywell 8500 below 67 on cool?
With a two story house you have to be aware that cold air flows downwards so any cold air coming from an ac unit will flow downstairs( normally down the stairway) so unless you can close off the down stairs then the up stairs unit will be cooling downstairs as well. Ac units have a thermostat located in the air intake and it cools until the cold air has risen to that point. In effect the space above the ac unit will be hotter than the floor. Knowing how they work ,you can see that the upstairs unit will never reach the set temperature because the cold air is continually heating from the house and will never get to the top thermostat.
So your solutions are
1-- fit controls that restrict the cold air from leaving the upper floor (Doors)
2--don't run the upper ac unit unless you are living up there (waste of money
)3 place an ac in each upper room and keep the room door closed
Aug 12, 2014 | Heating & Cooling
GE Zoneline AZ38H12DAD Split System Air Conditioner Logo
790 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Todd B
Tom Chichester
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
