Question about Kenmore 62602 Electric Dryer
KENMORE DRYER WON'T TURN.
I have a Kenmore dryer, M# 66712694. It won't spin. I have been told that I have to take the "access panel out & there will be a belt on the floor. I have no access panel!! Now what? How do I get to the parts?
  • AMY FULLER
    AMY FULLER Feb 03, 2009
    I also know about the 2 screws in the top under the lint filter. I took it out & took out the screws & the top wouldn't lift off. it seems like it's stuck under the control panel. Do i have to take that off too?
  • AMY FULLER
    AMY FULLER Feb 05, 2009
    I got that far last night. Luckily I worak at an appliance service co. & can get the part from either a scrapped unit we get to recycle or I can get it wholesale. Nice!! I will probably need a little more help with the positioning of the belt when i put it on as I'm not a tech just a glorified secritary! :) Will folloe up when the part is located...
  • Kenmore Master
  • 8,220 Answers
You have to pop the top with a putty knife. That will get you access to the scews holding the front on. from then it is relatively easy.
Posted on Feb 05, 2009
Dryer spins but no heat
Conventional dryers are usually accessed by removing the rear panel. I would think these would be the same. Unplug the dryer and remove wires from heating element. Test for continuity with an ohmmeter. If there is no reading, the heating element is bad. Disconnect wires from the hi temp thermostat and test with an ohmmeter and if no reading it is bad. Sears has these parts available.
Nov 07, 2013 | Kenmore Dryers
How do I open the drum area of Kenmore model #66712694 dryer to clean it?
First you need to determine if your dryers blower housing and other components are located in the rear of the dryer or underneath the dryer. The quickest and most simple way to do this is to look at the front of the dryer and see if it is one complete front or two pieces. There will be a small gap completly across the front about a quarter way up if its two. If its two pieces then your work is going to be up front. You remove the lower kickplate with a flat screw driver and pressing the clips, one on each side in the groove. If its a solid front then you'll need a 1/4 " driver or drill with 1/4" socket, adapter, etc. From the rear of the dryer, there are about nine 1/4 inch screws you take off to access the area your looking for. Hope this helps, good luck. Now to look around the drum area, it also depends on if its one or two pieces. If one, remove the lint trap and take the two phillips head screws then take a flat head and pop the top up. Then inside, top front left and right sides there are two screws, either 5/16" or 1/4" screws you need to remove to pull the front off. If two pieces you'll have to pop the top as earlier, but you'll have to remove the kickplate, then two additional screws at the lower portion of the top piece as well as the top.
Apr 26, 2012 | Kenmore 65924 Electric Dryer
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Dryer wont spin
About 90+% of the time when a dryer won't spin it is a broken/slipped belt.
If the dryer makes some niose when activated, then the motor is turning, which exonerates the
motor, leaving just the belt - the belt may have slipped off a (possibly broken) pulley.
Aug 03, 2011 | Kenmore 98702 Stacked Washer/Dryer
Heat works on dryer but won't spin... the drum
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 28, 2011 | Kenmore Dryers
I have a Kenmore Residential Dryer Model # 97273100 (11097273100?). The dryer starts but does not spin. I assume it is the belt, but how do I access it?
I smell gas and can't find where the door panel is on my Kenmore You : Model:97273100 serial: MB3313988
Jan 16, 2011 | Dryers
Kenmore dryer hums/heats up, but drum does not spin!
Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way. Yank out the tub. Clean the junk out (send me the coinery) oil the wheels and Idler with temp resistant zoomoil from ace hardware. Use this guide to replace dat belt Kimosabe:
BELT CONFIG 101
Apr 08, 2009 | Dryers
Trying to access the blower fan on a Kenmore 80
Remove the rear panel.
Then remove the screws that secure the blower fan vent on the left side to access the blower wheel.
Mar 08, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore Electric Dryer Quit Spinning
Based on the information provided above, I am unable to provide a positive solution to your issue. The model number is incomplete. I have provided some common solutions to help guide you in your search.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information. This link will take you to the belt diagram page.
http://www.repairclinic.com/0079.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 14, 2008 | Kenmore Dryers
Kenmore 62602 Electric Dryer Logo
127 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
