Question about Sony CCP 1310F Single Dual Cassette Deck
When i am recopying on used tapes i have some tapes that comes out with two voices
  • 104 Answers
The erase head is not erasing. This could be from a bad electrical circuit or more likely it may just need cleaning. The erase head is the leftmost head and likely has only 2 wires connected to it. if it's not dirty, try to watch that the tape is making good contact with it as the tape passes over the head.
Posted on Feb 11, 2009
CR8003 TAPE RECORDER
Hello may be you try to say what type of tapes used your unit, if yes it is a micro cassette size see link for some available for your unit. http://www.tvps.com/Departments/Dictation-Accessories/Cassette-Tapes/Micro.aspx
May 02, 2014 | Craig Electronics Craig Micro Cassette...
I have a Philips pocket memo 381 that lets out a loud bleep when trying to record on it. Batteries have been changed twice this makes no difference.
This is the end-of-tape signal. Try turning the cassette over. If this does'nt work then there is no tape drive due to the belt coming loose or breaking.
May 05, 2010 | Philips Pocket Memo 381 Handheld Cassette...
Red record button will not depress to start recording
Check that you have not knocked the record tab out of the tape you are using.  Try a new tape.
May 28, 2009 | Panasonic RN-405 Handheld Cassette Voice...
How do I erase a tape that has already been used?
Try press Rewind & Record and if does not erase I recommend to get a tape eraser from tvps
Mar 31, 2009 | Sony Pressman TCM-929 Desktop Cassette...
Taped sounds are deteriorating and disappearing.
If the tapes you are using are indeed brand new, then I would assume that the heads on the tape recorder are either very dirty or damaged. Try using a q-tip dipped in alcohol to clean the heads of the recorder. Clean the rollers too and pins that guide the tape. If that doesn't work it may be a component problem. And may be cheaper to replace than repair.
Feb 10, 2009 | Dictaphone 1243 Handheld Cassette Voice...
How to erase previous recordings..
Hold in the RECORD button and pull 4-way slider switch all the way down into REWIND position until tape is fully rewound.
Jul 02, 2008 | Philips Pocket Memo 381 Handheld Cassette...
Transfer recording from tape recorder to computer
Use a cable running from the headphone jack on the recorder into your PC microphone jack. Then you can capture the audio using Windows MovieMaker software that comes with Windows XP. I have done this and it worked perfectly.
Nov 28, 2007 | Sony ICD-B200 Digital Voice Recorder
There is no voice when I replayed the camcorders
What happens to the audio when you play the tape in another machine? Does it still drop out? Check the tape visually when it has no sound and see if the edge of the tape is creased. Also is the picture OK when the sound goes off. Does it jump around ans lose sync. If it does it means that the tape is mistracking. It's possible for the tape guides to go out of alignment but usually this is accompanied by picture breakup too. If you've never done it before don't attempt to realign the guides youself, you can really put it out of alighnment and it will damage the tape. Is the microphone built in or removeable? if it's the latter then check the connections and make sure nothing's broken. If there's a switch to go from internal mic to external mic see if it's switched to the proper position, it could be half way between internal and external. I'm opting for a tape problem, Either way a trip to a repair shop may be the best bet. BMW
Jun 02, 2006 | Sony Handycam DCR-TRV22 Mini DV Digital...
Sony CCP 1310F Single Dual Cassette Deck Logo
65 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
