Question about Philips GoGear HDD6330 MP3 Player
My volume goes up and down without me touching it
Sometime my device cuts itself off when the volume goes down, my volume goes up and down without me touching the control.
Try upgrading the firmware of ur player
if ur player is touchscreen try turning off the device for some days
Posted on Feb 02, 2009
Volume automatically raises without touching remote goes to full volumn
the "volume +" microswitch on the device is defective, replace!
Oct 09, 2017 | Bose Televison & Video
Tv volume goes down
Try a (hard) factory reset
Dec 13, 2017 | Televison & Video
Magnavox 32MF339B volume level goes up and down on its own.
Its main system memory IC has damaged. It should be replaced.
May 12, 2012 | Magnavox 32MF339B 32 in. TV
I have a lcd 32805hd tv and it is turning itself down without touching the remote
you mean volume etc, Your remote have some moisture problem. Replace the remote or unscrew or open the remote and dry it, with hair dryer or keep below the table lamp for sometime. dont over heat it. remotes will work with these methods. try the luck. best of luck
Jan 27, 2011 | Televison & Video
Why does my 26 insignia do the following without touching the remote: volume up and down, changes channels and menu screen pops up
It could well be your remote control has a problem. Try removing the batteries from the remote control and see if the problem goes away, if it does, try new bateries on the remote controller, if that does not work you may have to get a new remote controller
Mar 24, 2010 | Insignia LCDTV26 26 in. Television
Stereo volume goes up itself
Funny huh? Actually, some aftermarket radios like Pioneer have a setting where it senses cabin volume and ups the radio volume itself to overcome cabin noise. I doubt this is your problem and belive the unit is really "mental" and needs repair/replace...
May 07, 2009 | Car Audio & Video
Amplifier goes from low volume to high volume without touching any controls. I turn it down only to have it mysteriously go up again 5 minutes later. Warranty ran out one week ago...
Let's eliminate ghosts and goblins. I can't identify your unit. Give me a make and model number.
As a test, locate the remote control window on the front of the unit, if it has one. Set it up to watch or listen to something then cover the remote window on the unit with a small piecr of cardboard. If you can't locate its infrared receiver for the remote just cover the entire front of the unit with something sufficiently opaque to block your remote. Try to operate it with th remote to be sure the unit can't see it.
If the expected problem never comes back you have a stray signal from something else in the environment getting interpreted as a 'volume up' command. Then look around for other remotes being used, wireless devices, use your imagination. I used to have a remote-controlled space heater and my TV would sometimes shut off if I used the remote. Does the unit have line-of-sight to a nearby house? Maybe something next door (garage opener?) is interfering.
If it still happens and there are no other infra-red devices nearby you have a ghost.
Apr 27, 2009 | Audio Players & Recorders
Volume on my TV goes down to zero without me touching the remote. JVC- Any suggestions?
There maybe another signal coming from somewhere causing the problem. Try blocking the IR sensor in front of the TV. If that stops it, your next step is finding the source.
If blocking the sensor doesn't work, check out the buttons on the TV itself. It may have a sticky or damaged button.
The volume down button may have went bad.
Feb 18, 2009 | Vizio L32 32 in. LCD HDTV
Philips GoGear HDD6330 MP3 Player Logo
359 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
