Question about HP LaserJet 3050 All-In-One Printer
My fax machine is showing a line on all my faxes... how do i fix it
  • 2,120 Answers
If when you print....Bad Toner Cartridge
If when you up the document feeder and clean the scanner glass
Posted on Feb 03, 2009
Fax machine shows no dialing tone. what must I do to rectify?
check phone line is connected to fax machine
check phone line works with a phone plugged into the phone line you are using
Oct 19, 2016 | Office Equipment & Supplies
I'm getting an error mesage: ECM error on my Sharp AR-M207 fax machine. How can I fix it?
ECM (Error Correction Mode) is a feature common in most fax machines today. It helps to minimize errors while transmitting faxes over noisy phone lines.
1) Be sure you have the latest version of the drivers installed
2) Turn the fax off, then unplug for 10 minutes, turn on and try again. This should clear up anything in the printer/fax memory
3) Check if your phone line is unsually noisy when you tried to send the fax(es) that gave you the error message. If this is the case, a sucessful fax transmission will be almost impossible. You may have a faulty phone line or an improper installation. Either of these two should be fixed by your phone company. Also, most phoen companies can test your phone line (for fre) remotely to check for abnormally high noise levels.
Please, report back if you need further assistance.
My ID: alexocuello_
Mar 31, 2010 | Office Equipment & Supplies
Fax will not send on HP 5610v All in One
their could be many reasons your fax machine is doing this but I'm going say with the information given that you may have a bad phone cable or no connection at all. also if your fax is not on a dedicated line someone could be using that line or simply picking up a phone on the same line before you fax will cause you your fax to fail. I hope this has been of some help... please don't forget to rate
Jul 23, 2009 | HP Officejet 5610 All-In-One InkJet...
HP LaserJet M1522nf MFP No Fax detected
The book says
No fax detected
The product answered the incoming call but
did not detect that a fax machine was calling.
This could be really tricky. The missed faxes could be just random wrong number or recorded sales calls that are dialing you machine.
If you are sure they are fax machines calling then we get into phone line issues and that sort of thing. If you get static or noise on the line it can affect your machines ability to hear the other machine. I saw somewhere tha replceing the cord form the wall to the fax helped some people with a similar problem.
You can always try turning the machine off and unplugging it for awhile this is a common suggetion from HP for almost any product with a problem.
Hope this helps
Mar 12, 2009 | HP Office Equipment & Supplies
Panasonic Panafax UF-550 not receivng faxes
Check your line for static, should sound a clear tone. 95% of communication problems are related to line quality (phone company fix this). The other 5% is the modem PCB of the fax machine
Feb 12, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
Fax machine stoped receiveing fax
First, check your fax's phone line. Put a regular phone on it and check for dial tone and line noise. If the line is dead or noisy, this will cause a problem.
You can also try dialing your fax number from another phone and see if the fax unit picks up the line and starts initiating communication. (sounds like modem noises)
Jul 30, 2008 | Brother MFC-7820N All-In-One Laser Printer
Fax machine
Ok , I want to clarify. You have a line on all printing? When you receive a fax, when you print and when you copy?
If so, you need to replace the cartridge with the drum.
If It only is when you fax out and make a copy, then open the scanner and clean the strip over the CCD assembly in the scanner.
What happens is that something, Whiteout, ink from a page windes up getting on the scanner glass and as the original passes over it, it scans as a line and shows up on the paper as a line.
Mar 04, 2008 | Office Equipment & Supplies
HISSS on line; no dial-tone; no fax in or out
it sounds like you may not have any dial tone. the hiss [white noise] you are hearing is from the dsl modem.try plugging a regular corded phone into the jack to check for dial tone.if there is none,call your phone company.also try plugging the fax machine into another jack where you know there is dial tone.
good luck
Feb 02, 2008 | Brother FAX-2920 Plain Paper Laser
Incomplete info code 634 how to fix
That codes says:
"Redial count over with no response
or busy tone was not detected.
U.S.A. and Canadian models
will redial only once if a busy
tone is not detected."
The number you're dialing was first busy. When it went to redial, it detected no phone signal on the other end. If it happens to only 1 or 2 customers, then it's something to do with their lines and you can't fix that.
If it happens often, then get your phone lines checked out by your phone company, make sure your fax is not sharing the line with another other device and make sure it is not a digital line.
Other than that, you're looking at having to replace the main board in the fax. Which basically means it's time for a new fax machine.
Jan 02, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
HP LaserJet 3050 All-In-One Printer Logo
Ben Johnson
