mine cam samsung s860 is not turning on and its lens is stuck outside, only the thing happend that after putting batteries inside, camera status lamp is on with green light.
I have this same problem. It has happened a few times within the 8 months that I'v owned the camera. Usually changing the batteries takes care of it, but not this time. Any ideas? I have this same problem. It has happened a few times within the 8 months that I'v owned the camera. Usually changing the batteries takes care of it, but not this time. Any ideas?
i had mine for only 2 weeks, then it did the same. the lense is frozen out, and only the little green light comes on and the screen wont. ive replaced the batteries, still dosent work... i had mine for only 2 weeks, then it did the same. the lense is frozen out, and only the little green light comes on and the screen wont. ive replaced the batteries, still dosent work...
I have the same problem. Lens is stuck in out position. When it's turned on only the green light comes on; display stays blank. None of the buttons work. The camera is only two months old. My other child has the identical camera and it's had no problems, even though it is used much more frequently.I have the same problem. Lens is stuck in out position. When it's turned on only the green light comes on; display stays blank. None of the buttons work. The camera is only two months old. My other child has the identical camera and it's had no problems, even though it is used much more frequently.
AnonymousApr 05, 2009
My camera I replaced the batteries but everytime i turn it on the green light comes on it beeps three times and then it shuts off. The zoom comes out a little way when that happens that goes back in when it shuts off. My camera I replaced the batteries but everytime i turn it on the green light comes on it beeps three times and then it shuts off. The zoom comes out a little way when that happens that goes back in when it shuts off.
the camera's beeping and the lens didnt want to come out so i pulled it out still beeps when turn on lens wobnt go back in all the way???? the camera's beeping and the lens didnt want to come out so i pulled it out still beeps when turn on lens wobnt go back in all the way????
AnonymousMay 17, 2009
the camera that i have just wont turn on at all even changing the batteries
You can't post conmments that contain an email address.
Your batteries have worn out. They don't give enough power for the camera to switch on properly.
Replace the batteries. Use 1000mAh or better batteries.
kodak is known for lense isues. Dirt gets loged in the lense real easily.. just try and get it out. blow in the lense... tap it upside down gently... wiggle it around gently.. it worked for mine. I thought i was going to have to get a new camera but i tried all these things and then it turned on. also.. if it wont turn off remove the battery
Make sure you are using the correct batteries, and that they are installed correctly. Some cameras require more powerful kinds of batteries and will not work with the cheaper kinds. A blinking light can mean something is wrong with the power, not enough or something else. If you have a power adapter or can get one, you may try that, to see if the camera will work without batteries. If it does, then some problem exists in the battery circuit.
You didn't provide a make or model for the camera, but if it's a Kodak, fixing your problem could be as simple as cleaning the battery contacts
in the camera, or the solution could be a lot more complex and
expensive. Here's a link to the Kodak Help Center - it provides a
simple Q&A format to diagnose the problem and propose a solution.
I have the same camera and the same problem, if you use lithium batteries it keeps the charge longer because regular batteries aren't strong enough. Hope that helps you! :)
It''s the battery..you need to buy rechargable batteries or lithium batteries. These batteries are specialied made for digital cameras. The lense is shutting off and or stuck because there isnt enough power/energy from the batteries. This is also a COMMON problem in these specific models! You can buy recharge batteies wityh the chrager and like 4 aa batteries for around $20.00 at wal-mart..Energizer is a nice one that plugs right into your wall outlet to recharge. My camera Samsung diximax D53 Works great now taht O realized it was teh batteries..No vody told em, and it doesnt specify which batterios to use in teh camera manual..at least I dont think..I even thought the camera came with regular alkaline batteries ( the ones taht wont work fior this camera)?
Take the batteries out and leave overnight - put a fresh or fully charged set in
See what jappens
If still no go
Get on to Sony Tech Support.
If still under warranty -send it back
wont turn on
same problem
