Question about Woods Industries 59377 Indoor Digital Timer 7-day
Setting woods 1600 timer
I have a Woods 1600 digital indoor timer replacing the switch for my outdoor lights, but have lost the instructions on setting it. I've tried reprogramming it but get no results when putting it on to "Auto". Any ideas?
  • Anonymous Mar 21, 2014
    I would like to set the date time and indoor and outdoor temperatures on my CE TempMinder indoor and outdoor digital thermometer
    Sniper:
  • 54 Answers
You can get your instructions here and print them off.
http://www.woods.com/canada-timer-instructions.asp
There is a complete list just choose the one that you have. Please don't forget to rate me on this.
Thank you
Posted on Feb 02, 2009
Lost instruction for operation of woods indoor digital 24 hour timer (59203)
1) Copy following link for possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
2) Don't forget to reset timer to clear traces of prior programming.
Timer has internal rechargeable battery that eventually gives out, rendering timer useless.
Timer has 1 year limited warranty through Coleman.
3) Suggested replacement timer: Woods 59009, 59008, 59007.
Two prong and 3-prong outlets, rated for CFL LED incandescent etc
http://waterheatertimer.org/Woods-timers-and-manuals.html#50009
4) Or buy timer locally for ez return if timer does not work.
5) Jan 2013: Best brands for warranty support are probably Woods, Intermatic, GE, Tork, Sylvania, Leviton.
Promotional-grade timers from First Alert, Timex, Brinks, Stanley-Westinghouse, Utilitec etc may not have clear on-line warranty support.
Jan 07, 2013 | Woods Indoor 24 Hour Digital Timer (59203)
I lost instructions for setting my 111 Woods timer. It is used indoors. Please send me instructions Thank you and have a merry Christmas
Merry Christmas to you also.
I do not show a Woods 111 timer.
However Woods is sold under many different numbers and a few different brand names.
Link below goes to all Woods timers and manuals:
Step 1) Scroll through page and look carefully at the timers to help identify your timer. Similar timers might set the same way as your timer. Add a comment any time.
Step 2) Add a comment and describe your indoor timer. Is it wired into the wall, or does it plug in. Describe the buttons in detail or the dial, describe override switch if it has one. Give as much information as you can think, and then I will check other resources
Step 3) Check list of other brands because Woods carries over into other brands as well. I am familiar with these timers.
http://waterheatertimer.org/GE-timers-and-manuals.html
http://waterheatertimer.org/UPM-timers-and-manuals.html
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
http://picclick.com/Amazon/Home-Improvement/Electrical/Timers/
Dec 10, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
I lost the instructions for the Woods outdoor timer #49640 E151740 TM305
Woods 49640 is also Woods 59204
http://waterheatertimer.org/pdf/Woods-59204.pdf
If this manual is not correct, add a comment.
To identify your timer, see all Woods timers and manuals at following link:
Dec 07, 2010 | Woods Outdoor Lighting Timer
I HAVE MODEL #83643B POWER STAKE AND 15 FT DIGITAL TIMER AND HAVE LOST THE INSTRUCTIONS ON HOW TO SET THE TIMER CAN YOU PLEASE TELL ME HOW TO SET THE TIMER
That sounds like the Woods 17321 Dusk-to-Dawn yard stake
Product image:
http://www.amazon.com/Woods-17321-Outdoor-3-Outlets-6-Foot/dp/B000BHN4H8
Manual
http://waterheatertimer.org/pdf/Woods-17321.pdf
If this is not your timer, check following page:
Instructions:
Yard stake control outlets, and turns ON automatically at Dusk
Rotate dial to set options:
Rotate to OFF > outlets OFF
Rotate to ON > outlets ON
Rotate to Dusk-dawn > outlets on at dusk and off at dawn
Rotate to 2 4 6 8 > outlets on at dusk and off 2 4 6 8 hours later
Dec 05, 2010 | Woods Outdoor Lighting Timer
Can't get the timer to turn on
Woods timers:
You posted under Woods 59383.
Plug timer into wall after setting timer.
Maximum load 500 watts, used for indoor or outdoor
Set current time, rotate dial until current time lines up with black triangle.
Around outer edge of dial are segments.
Pull up all segments for times you want timer OFF
Leave segments down for times you want timer ON
Locate switch on timer.
Push switch so the V shape is down.
Plug into wall outlet, plug Christmas lights into timer
Drink ale and eat turkey legs.
Add a comment if this is not your timer, or if you need more help.
Nov 23, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
How to install and set timer tm1702
TM1702 is a Woods timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#1702
If link above does not show your timer, then add a comment with description of timer.
I have extensive files on timers and can probably identify the timer.
Instructions according to TM1702 manual are as follows:
Push switch toward the 'V' shape that is pointed down.
(Some timers do not have the switch mentioned above)
Plug timer into wall outlet, plug lights into timer.
Lights must be turned on.
If above instructions are incorrect and you don't want to add a comment or identify timer further, then you can take advantage of fixya phone support.
Fixya expert will walk you through the steps for a price.
May 22, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
Woods Industries 59377 Indoor Digital Timer 7-day Logo
2,452 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
