Question about Pioneer SD-643HD5 64" Rear Projection Television
Convergence board cracked?
I was going to take the board in to have the Convergence chips put on it? The board itself cracked. Do I need to replace the whole board. It did not crack in half?
  • eavesjacquel Feb 03, 2009
    Thanks. Thats helps a lot
  • 298 Answers
Once the board is cracked it is no longer repairable (even if it's a tiny crack that may not appear to interrupt any connections), and you would have to replace the complete board. Any attempt to repair or continue using a cracked board may cause more damage to the entire unit. You can find a replacement digital convergence board for a model # SD-643HD5 from this major Pioneer parts distributor at the following link:
Pioneer SD-643HD5 Replacement Part Digital Convergence Board
Posted on Feb 02, 2009
Convergence board
Your TV most likely has one or more possible problems. You do not need to replace the whole board. Just the bad components.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo2_bing.gif STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Nov 30, 2009 | Televison & Video
53fdx20b
You can check this link for that convergence that your looking http://www.partstore.com/Search/Model/Hitachi+Ltd/Hitachi.aspx
after you replace thet convergence correctly its should be working fine already..
Good luck.........
Aug 10, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Convergence is off in the lower right and upper left corner
The repair isn't too complicated if you're comfortable working with a soldering iron. Sounds like one of the "guns" is shot. The chips that need replacing are attached to the heatsink on the convergence board. The reason for replacing both chips is if you're going to bother to take the board out and replace one bad chip, that is the best time to replace the other older chip. The link below is to step by step instructions including pictures of the repair. You can check it out to see if you want to try it. If not, the repair is expensive (between 250-400) depending on the repairman. Best of luck with your convergence problem.
Greg
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
May 23, 2009 | Toshiba 50A61 50" Rear Projection...
Convergence problem
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 05, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
My JVC model number AV-56WP30 has a flashing convergence screen
Your TV most likely has a Convergence Chip Failure but I have not seen that symptom before.
  • Screen looks 3D
Feb 28, 2009 | Sony KP-51HW40 51" Rear Projection...
Location of the convergence circuit board inside the KP46WT510
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
>>>Solution<<<<
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Jan 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence Issues
Your TV most likely has one of two possible problems.
  • Screen looks 3D
Jan 17, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
I have a convergence problem. My Sony KP-65WS510 has a picture that looks like 3-D and bows at the bottom and top of the screen. I already replaced both the IC's STK 392-560 (2 qty.) and check all six 3.5a...
Screen looks 3D
>>>Solution<<<<
Dec 09, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Colors separated
You need change STK392-560(can use STK392-570)
I guess it happend when holding bolts weaken to radiator.(Check other STK on next radiator)
You have to change STK on right radiator.
Disconnect small connectors. You can l leave Hi Voltage two lines(RED). unscrew board.
Pool board out.
Unscrew STK. Set board verticaly. Just pool STK bu pincet and heatup solder. One by one...
Clean halles.
Set new STK with thermopasta on board in to hallsradiator. Screw up.
Wet contacts by liquid fluse. And sosler them.
Clean up by alcohol...Check for short by lense...
Apr 28, 2007 | Sony KP-57WS500 57" Rear Projection...
D52W19 convergence problem
Since this is an intermittent problem, I would first check the convergence board for cracked solder connections or other loose connectors (or leaky capacitors and diodes). If you still cannot find the problem, you will most likely have to replace the convergence board assembly p/n 264103. It can be quite difficult to re-converge if you do this unless you swap the two eeprom IC's on the original board to the new board IK210 and IK211 then Go Into The Service Menu Geometry And Set V Slope And H Position, Save, Then Back Out To the Customer Menu And Run AutoConvergence.
Dec 22, 2006 | RCA D52W19 52" Rear Projection Television
Pioneer SD-643HD5 64" Rear Projection Television Logo
162 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
