Question about Hitachi 43FDX01B TV
How do you take the front cover off. There are two screws at the
Getting the front panel off
    Problem Solver:
  • 6 Answers
If you are talking about the front cover that contains the speaker grilles at the bottom of the unit, then there are two screws on each side of the unit. These are both at the rear of the cover on each of the sides. Undo these and remove them.
The cover is then held on by Velcro in the front centre of the panel, so you need to pull it off carefully to break the grip of the Velcro. If the TV is on the Hitachis stand then you will need to push the TV backwards off the stand by about 4 inches to give room for the cover to come off. Be carefull when moving the TV backwards off the stand that it does not topple over backwards.
Posted on Feb 08, 2009
HOW DO I REMOVE THE SCREEN COVER FROM A TOSHIBA TV MODEL TW65H80
some sets have screws in the back all around the front cover and some come off by taking bottom speaker grill off first and you will see screws that holds the cover. And some have a template that pops off and screws are underneath it.
Dec 26, 2010 | Toshiba TW65H80 TV
Tip
Repair job continued
7. Locate the color wheel cover. It’s got a small green circuit board on top of it with a black/blue wires connected to it. Remove that plug. Also, and this is the trickiest part, remove the two cables coming from the color wheel. One is a copper-colored ribbon cable. That will just slide out easily. The other is a cable with two white and one blue wire. This one is tricky to remove, so you’ll need to ease it out. I pried it out with a jeweler’s screwdriver. DO NOT just pull on the wires.
Note: A reader made the following excellent suggestion to avoid breaking the white connector on the end of the blue/white/white wire:
Having replaced quite a few of these colorwheels as a Samsung service tech, I have found that you do not have to remove the blue/white wire from the DMD board (avoiding the risk of damage to the optical engine) There is enough slack in the wire to route it around the cover when removing it. You can then unplug the wire from the old colorwheel and plug it in the new one (the plastic tab will break off the old connector when you go to remove it,but it will still fit snugly on the new colorwheel) Using this method I have had no problems reusing the old connecting cable
Color wheel cover view from top-down. This part has three screws and slides straight up.
color-wheel-wires.jpg 8. Unscrew the color wheel cover. There are three screws holding it in place. One to the rear of the set, and two in front. The one to the rear is tucked way in, so I just unscrewed them and carefully left them in place and pulled them out with the cover. Slide the cover straight up, exposing the color wheel. As you do, note where the color wheel wires go — out the gap in the front.
cover-removal.jpg 9. Remove the bad color wheel. The color wheel is held in place with three screws. Remove the screws and the color wheel. The color wheel may be stuck in place with the foam tape, but that’ll give with a small tug. To remove the wheel cleanly, I lifted the front edge and slid it toward the front.
color-wheel.jpg 10. Insert the new colorwheel. It can be tricky to do this without touching the wheel, or bumping the wheel into the case. (This is where you need the nerves of steel). Once you get the proper angle, it will slide into place. Don’t force it — remember, this thing needs to spin at 9000 RPM, it’s probably pretty sensitive. At first, I tried to put it in place with the screws already in the holes. This didn’t allow me to slide it in properly. Lesson learned: put it in without the screws and then hold the screws in place with tweezers, if necessary.
11. Put the color wheel cover back on with the wires out the space facing the front of the case. Make sure the wires reach their destinations, and screw in the cover. Three screws. Attach the three connectors. The metal contacts on the ribbon cable face the rear.
12. Put all the guts back in place. Slide the center unit back in. Without touching the projector lens, open up the slice in the foam so it wraps around the projector lens, and slide it in the rest of the way. The center unit can only go in on it’s track, so again, don’t force anything. Connect the two wires you removed on the left side. They should only go in one way. Did I mention don’t force anything? Screw the sensor switch onto the bracket on the right.
13. Put the power cable in it’s slot. Just the way you noted on the way out.
14. Slide the left PC board and panel back in place. There are two screws that hold it in place that you screw in now, the rest hold on the access panel.
15. Put the projector lamp back in place and screw it into place. I forgot to do this both times.
16. Put the access panel back on and screw it in (14 screws)
17. Plug in the television, say a prayer, and turn it on.
on Mar 30, 2008 | Samsung DLP HL-P5663W 56" TV
I have a Sony Trinitron WEGA TV 21", Model- KV-HP212M83, brought 4 years back and till now not a single problem. But today morning when I power on TV, it is not getting on. I checked all my power...
If your plug points are getting power, then follow as listed below.
Open the back cover carefully. identify the screws with a torch light, remove them.
You may have to remove two screws holding the audio video socket panel. This
is in the back panel. TV weight is on the front side. Hence guard it. By chance
by applying pressure on the screw driver it may fall off!!
Follow the power wire and check the fuse. It may have a small cover where the
fuse is secured. Remove the cover and take the fuse out.
Just view fuse in light. If the wires are parted apart, replace it. same type and rating.
Oct 08, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Mitsubishi WS-55807, screen removal / cleaning
Hi, thank you for visit fixya.
Pull out the speaker cover ( slow toward your self).
You will see screws in the middle , take it out ( maybe is 4 o 6 screws), be careful with any wires connect to panel control. Disconnect any connector to panel control. Pull toward your self , slow and slide up . Use a fine brush for best result, use glass cleaner liquid.
Any question, I will be here.
If you need additional help, please send me a picture front tv and I will show the right process.
Thank you
Dec 05, 2009 | Mitsubishi WS-55807 TV
How do u change the bulb ??cant get it out sony kdf e5oa12u
on back of tv there are 2 screws--bottom left and rite--remove them-front of tv will now pry off--take out screw of lamp cover-remove cover-take screw out of lamp--remove lamp---you can also go to sonys web site--it should be there
Sep 18, 2009 | Televison & Video
How do I change the color wheel on my samsung HL-P5663W. I have already removed the lamp and loosened screws for the lamp housing. Doesn't seem to want to come apart. Am I on the right track?
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
Jul 10, 2009 | Samsung DLP HL-P5663W 56" TV
Picture won't come on
1. See the ugly red color bands on the television set? These can also occur in blue and green. We're going to fix these!
2. Front shot of the television. Their are two screw holes on the front of the unit near the edge of each side right next to the speaker grille.
3. Close up shot of the screw hold. It is covered by a plastic cover that has two tabs holding it in. Carefully pry them out with your flat head screwdriver. Do not apply too much pressure or you can break the tabs off. Once the covers are removed, unscrew the two screws with a Philips screwdriver.
4. To remove the cover, pull from the bottom of the front case and rotate towards you. Once you rotate it out, the top will disconnect and come loose. Do not pull it off, as there are cords attached. (see picture) Loosen the cables attached with the twist ties and set the front cover to the left side.
5. With the speaker grille and cover removed, you now need to remove the wood panel to expose the inner electronics on your Sony HD TV. To do this, remove the four Philips head screws from the panel. Then, pulling from the right, rotate the panel off and the electronics will be exposed.
6. This is a picture of the inner electronics of your Sony Rear-Projection High Definition television. The little black box towards the front of the unit is where we will concentrate our time as it is the control for the voltage & convergence adjustment.
7. When focused in on the controls, you want to concentrate on the bottom row for the voltage / ray gun projection adjustment. The colors are labeled below and from left to right are blue, green, and red. Choose the one that needs to be adjusted and turn ever so slightly with your Philips screwdriver to remove the lines. In my case, the red just needed to be turned 1/8 of a rotation to be back in adjustment. Do not turn to quickly or abruptly or you could possibly damage your TV by varying the voltage too quickly.
Mar 24, 2009 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
Front cover removal on Panasonic CT-36HL42C
You have to remove the entire rear case to access the video input(s) panel. There are quite a few screws. Be careful when removing the case because there is an internal wire connected from the inside back of enclosure to the main power board.
Jan 07, 2009 | Panasonic CT-36HL42 36" TV
Removing playing cards from inside of a TV
Hi there!
You can certainly do this yourself. However take care not to break the tube neck when doing so and unplug from mains before you start. All TV'S can be opened by unscrewing the screws around the edge of the frame first. Then on the back panel you should find more screws that holds the AV sockets panel onto the cover. Once all screws had been removed, carefully pull the cover backwards making sure that you don't drop it before the tube neck is completely clear from the cover. Remove the playing cards and reassemble the same way, making sure that all sides are firmly slotted before replacing the screws again. You are correct in quoting "Fire Hazard". It is indeed. Regards and good luck, JUS004
Mar 30, 2008 | Quasar SP-3233 TV
Mitsubishi wd62327
where is the lamp housing located?
Nov 09, 2007 | Mitsubishi WD62327 TV
Hitachi 43FDX01B TV Logo
90 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
