Question about PC Chips (M925G) Motherboard
MOTHERBOARD PROBLEM My motherboard is refusing to load windows XP Professional on my Hard Disk. It can not read the exact size of the Hard Disk.
  • Misterixas May 11, 2010
    Have you checked your hard disk's jumper settings for disk capacity limitation to 32 Gbytes?
  • Peter Steiert
    Peter Steiert May 11, 2010
    What is reporting that it can not read the exact size of the Hard Drive? Your motherboard or the Windows Installer disk?
  • 152 Answers
Run DISKMANAGER programme and fix your harddisk bad partition after that install windows xp
Posted on Feb 02, 2009
Can't install windows XP on new hard drive
That problem is from HDD, It can be bad sector on MBR \ on line for boot record\. Change your hard disk , if it in warranty , will be well.
Nov 24, 2011 | Biostar G41D3C LGA 775 Intel G41 Micro ATX...
I have windows xp professional and when I run my
If you get the error-message when you try to boot your computer, your disk-drive is either:
1. not connected to the motherboard
2. improperly connected to the motherboard
3. dead/dying, so that the Operating System files on the disk-drive *CANNOT* be read.
So, the computer tries to boot from an "alternative" device (either the 3.5-inch device or the CD-ROM device) -- if you don't have any media inserted into either device, you will get the error-message.
Oct 25, 2009 | Microsoft Windows XP Professional SP2 Full...
Can't install windows XP on a new 500GB Hard Disk
go to the manufacturers website and see what bios updates there are ? If any relate to recognizing hard drive capacity then it will be worth while installing the update onto the motherboard.
If not then check your motherboard for enabling LBA and if you read the manual it should explain what each option is for.
Also might be worth while slip streaming your xp installation disc with the sata drivers for your motherboard ( the sata drivers you can get from your motherboard manufacturers website, download and extract them and then use nlite to combine the sata drivers with the xp disc and re burn the xp disc ensuring to make it bootable )
Nlite website
Seeing as you are combining drivers it may be worth while getting all the other drivers ie network card, graphics, audio etc and combing that with your bootable xp disc.
Apr 11, 2009 | Intel Motherboard
I had a bogus "Virus Protection" alert mimicking Windows, then everything started messing up after I foolishly downloaded the recommended software. I have since replaced the hard drive with a SATA. When I...
Check out for a possible solution. Check you motherboard web site for the SATA interface driver. You will need the driver when you press the F6 key during installation of XP.
Feb 19, 2009 | Microsoft Windows XP Professional
Could not detect HDD on my Asus P4B-M Motherboard
try removing with jumper behind the hard disk. and the see the cable or plugged in properly and do automatic detection of Hard drives in Bios
Dec 22, 2008 | ASUS P4B-M (P4BM1400WOLTINY) Motherboard
750 GB Hard Drive support on intel 845 motherboard
Hi prabhatkumar, your Intel motherboard's bios will see the drive. The question is will windows?
Do not use windows to setup the hard disk drive. Download the free bootable software for a floppy disk from the manufacture's web site. Boot the system to the floppy & format the drive. You'll be able to set the cluster size (Like windows would do) but the software from the manufacture is far better than windows. Any version of windows XP will see your total drive size. Just make sure the drive is seen while in the bios. (If it will be the primary drive make sure it is listed in the boot order).
Good day prabhatkumar!
Run into any issues just drop me a note.
Sep 23, 2008 | Intel D845HV (735858149143) Motherboard
Formatting hard disk cannot procced
what is exactly happening? can you pls tell me step by step so that i can think on what to do. and pls sir dont rate my post if youll going to rate it on 1 or 2 bar cause my rating is getting to low. thanks!
Aug 21, 2008 | Sun FIRE 28 (Refurbished) (SUNFIRE280R)...
I need to purchase a jetway motherboard V2DP do you know where I can obtain one please
My old motherboard V2DP is dead, I need the exact same motherboard to replace my old one. If I can get the same motherboard then my main hard drive will think that its the old motherboard and then I can access my data files for MYOB and Windows XP, without reformating the hard drive I have none of the data backed up anywhere and can not locate my original XP Disk.
Jun 23, 2008 | Computers & Internet
Problem with replacing the motherboard and keeping my old hard drive
Windows XP questions and answers CH000635, How to get into Windows XP recovery console without a Windows XP CD. CH000646, NTOSKRNL.EXE is missing or corrupt.
How to create a boot disk. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
How to erase my hard disk drive and start over. If you are running or plan on installing Microsoft Windows XP please see ... First, we recommend that all users wanting to simply install Windows NT use the .
How to use the Windows recovery console. Place the Windows CD in your computer and boot from the CD. ... To repair a Windows XP installation using recovery console, press R.
Good Luck, Please dont for get to Vote/Thank You.
Dec 21, 2007 | ASUS P5RD1-VM Motherboard
Amd ms6378 motherboard / windows xp
This may be a silly question, but have you set your BIOS to boot from CD first?
When you get to the post screen press any key to boot from cd.
The you can folow the prompts to go through the rest of the setup.
If this is what you are doing can you go into more depth of where you get up to?
Dec 06, 2007 | Intel D101GGC Motherboard
PC Chips (M925G) Motherboard Logo
42 people viewed this question
Top PC Chips Computers & Internet Experts
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
