Question about Durabrand WD268 Cassette Player
Ignition wire not working?
Im a bit new to all this car stuff so bear with me!! lol
i went to Halfords to get my stereo installed (bought the car without one)
the man said the ignition wire wasnt working but the radio one was? he checked my fuses n they were all ok too,
anyone have idea how much and how long it takes to get replaced?
ant comments are welcome!!!
Thanks
  • leigh_x Feb 02, 2009
    btw its not the picture of the stereo above its a
    JVC KD-G331 CD Player
    President:
  • 196 Answers
Put the yellow cable in a b+ directrly fuse, and the red in acc a fuse
Posted on Apr 27, 2010
I replaced my ignition switch in my 98 k2 jetta and after my stereo won't turn on but will eject cds and insert them?
The red wire from the stereo is 12v signal, basically when you turn the key on it send 12v to the red wire to make your stereo come on. Everything else is fine since you can insert and eject cds. You may have pulled the signal wire loose when you changed the ignition switch, check the wires behind the radio and the wires to the ignition switch.
Dec 11, 2013 | Bosch 1998 Volkswagen Jetta K2 2.0L...
Im installing an aftermarket stereo in my 2002 Grand Am.. I bought an expensive harness and its not working.. I have the radio working, but the ignition wire from the radio is hooked up to battery...
This vehicle does not have a switched power suppy in the factory harness. The orange wire in the car harness is a constant 12 volts.
To resolve connect the 12 volt power supply from the head unit to a switched circut at the fuse block and this will resolve your problem.
Sep 08, 2010 | 2002 Pontiac Grand Am
Had a stereo fitted by halfords but when i got home i noticed the central locking was not working properly then the the stereo its self would not remember the setings I put in ( the guy at halfords told me...
The idiots didn't hook up the yellow wire straight to a battery/ignition source.Tell them they hooked the red and yellow wires together and you want it fixed.I guarantee it.I don't care what kind of car you have(kinda)for at least 30 years there has been a wire built in to factory stereo harnesses just for that purpose.They f***ed up.Unless you have about a 1975 car that is.In any American or Japanese or Kia,that's the setup.I would imagine with all the technology these days,practically any car has that setup.What are you in the UK?I just googled them.Good luck! Greg
Aug 30, 2010 | Car Audio & Video
No power coming thru power wire to my stereo decks any ideas?
You have two wire of 12V + going to your stereo, one is hot all the time and one comes from the ignition switch ( which turn on the stereo when you switch on the car), if it's the +12V one which is hot all the time, you can take another wire from your car's cigarette lighter 12V outlet. if it's the ignition +12V one, you can trace back the wire to ignition switch and change the wire if it's broken.
Hope it helps and please rate the answer if it was helpful, thanks!
Mar 08, 2010 | 2003 Kia Rio
Need to know the wires to install a deck for 97
Red is power to from ignition to cd deck
Yellow is direct power from battery to cd deck to hold the memory.
Black is ground
Blue is only needed if you are hooking up an amplifier.
I always suggest buying a wire harness quick connect system for $5, then you won't have to cut origional car wiring. If by chance you are taking the original wire route, then go to installer.com to find which wires on the car are for what.
Sep 02, 2009 | 1995 Toyota Celica
Hello! I'm trying to fit a new stereo to a 307cc (a Pioneer DEH-50UB) using the PC2-86-4 harness adaptor, but I'm a bit confused about the 2 extra red and pink wire's on the adaptor. What wire's do they...
I went to Halfords and asked someone!..
The pink wire has no use and doesn't need connecting to anything.
The red wire need's to connect to a temporary power source (the cigarette lighter) via scotch lock connection. Only problem there was having to take most of the centre console apart which was a bit fiddly but on the whole not to bad.
Start to finish the job took about 40 minutes.
Aug 19, 2009 | Car Audio & Video
Wiring aftermarket stereo
You have all the necessary power wires attached where required?
Sep 08, 2008 | 1989 Dodge Spirit
Radio cassette removal from 1996 toyota corolla
HI
I took my car to halfords to have my stereo fitted (also bought stereo from Halfords). they basically had to taken everything out of the middle bit to get to the stereo (All the air vents and control switches etc). It took about an hour to do, but at least you know there is no quick way to steal the radio once it is in. I think it helped that I managed to get a guy that had once been a macanic so he knew what he was doing.
Hope this helps
Aug 28, 2008 | 1996 Toyota Corolla
Cd player installation
first of all putting in non genuine stereos usually you have wires left check the fuse in back of stereo check all your fuses under your dash and in the bonnet even if wires touched momentarely its enough to blow multiple fuses which may be your problem your wiring may be fine see how you go
May 29, 2008 | 1994 Ford Taurus
Durabrand WD268 Cassette Player Logo
115 people viewed this question
Top Durabrand Car Audio & Video Experts
matt martin
matt martin
Are you a Durabrand Car Audio and Video Expert? Answer questions, earn points and help others
