Question about Samsung SyncMaster 930B 19" LCD Flat Panel Monitor
Possible power supply burnt out
So my Sansung 930b just gave a blank screen today and the button led blinks very dimly. From what a few others have posted, it seems this is probably a power issue. I opened up my case and found this on the power board:
http://img266.imageshack.us/img266/6135/930b2fr0.jpg
http://img530.imageshack.us/img530/203/930b1pe6.jpg
2nd picture is a closer look at the chip that burnt. On the other side of the board, there's a small brown smudge from the burn and the outside of the chip is fire scarred. I tried reading the number off the other (hopefully) identical 8 pin chip right nearby but from what I can make out:
45020
AASH0
Any of those 4's could be A's, 5's S's and 0 O's (and vice versa).
Yeah I took out the plastic, I still can't see the chip # and trying multiple combinations of the above didn't yield anything. I was able to find 1 person selling the IP-35135b power supply but it's reasonably expensive at $55.
Does anyone know if there's another way for me to find and replace just the chip? If not, judging from the picture and a description of the powered on behavior, does it sound like the power supply is the thing to replace? Thanks for your time.
    Problem Solver:
  • 8 Answers
I've been hacking on a few of these monitors at work... we have a bunch that are dead... I have not seen this particular chip burnt (yet), but have been replacing a lot of the capacitors. To confirm the chip ID numbers you were looking at, I saw 4502C & AA5N0, and yes, they're both the same. If it comes to the caps, they should all have a flat top... if any are domed or black or sooty on the top, that is a good indication it is bad. Hope you had good luck with this. I can/t help with replacing just the chip.
Posted on Oct 14, 2009
I have a Vizio E550i-B2 and the screen went blank, I do still have sound. I did the flashlight test and I can see the screen very dim. Would this be the LED driver board or power supply board?
This model develops bad solder joints on the connector between the power supply and the led driver board and loses backlighting. It's hard to believe, but the whole connection goes bad. All those pins supply only 24v and gnd. Resolder all of the pins on the power supply half of the connector and the tv will work.
It's the connector between that large yellow board (p/s) and the center green board (led driver).
Apr 16, 2017 | Vizio Televison & Video
Samsung 50 Plasma TV- No picture but sound works.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 01, 2016 | Samsung 50 in. Plasma TV
Dim green light on power supply blinking
If the Power supply LED dims and flickers its either your motherboard circuit has been cut or there is a short in the laptop. The AC adapter is not the cause.
Try this:
Remove the battery, then press power button to drain all the current, then re-install battery and plug to adapter.
If that doesn't work, then it's most likely the motherboard.
Mar 19, 2012 | ASUS (X83Vb-X2) PC Notebook
Sony kdf-e50a10 turns on for a few seconds screen staying blank and then shuts off?
Please let us know if any of the leds on the front come on and blink.
This model if the lamp is about to fail will come one with a very dim screen and then shut off.
Mar 15, 2012 | Sony KDF-E50A10 50 in. LCD HDTV
Acer AL1716 Blank screen & blinking green power LED
Hi..there,
You've got a busted backlight inverter... Need to replaced a new one...
Dec 17, 2008 | Acer AL1716Bbd 17" LCD Monitor
Computer dosent turn on..screen is blank with blinking LED
have u tryed
unplug all of your plugs at the back like blow on them like i do to get lil partcals of dust out then plug all back in and mite work or maybee ur power cord is screwed a bit and u mite have to get a new one whats happednd to ur comp happend exactly the same with mine and i screwed with myn for ages and it finaly worked so maybee just try all that n then if that dosent work as drliativ hes a good guy and will help
hes helped me out a few times hes a great guy
Dec 02, 2008 | Smart Modular SV3170A
Blank screen, but has power
It is most likely a backlight that has burnt out or something else of the sort. You will want to call HP Support and explain to them of your troubles.
Aug 17, 2008 | HP L1706 17" LCD Monitor
Power Up Problems
7 blink error is 8.6 volt error on that model. usually tied to y sustain board located on left side of set looking from back. disconnect y main from power supply and power on and if comes on verify power supply primary voltages located on label on pdp itself. if voltages present you would need to replace that board as not designed for component level repair. however if you find failed components like swollen caps or burnt ic's you could replace those. also when replacing the y main board there are two y buffer boards to left of main board that also would be recommended to be replaced at same time as they work as circuit and replacing one board without other could cause failure to other boards still in set
Aug 13, 2008 | Philips 42PF9431D/37 TV
Computer Won't Power Up
If the blinking amber LED is on the computer itself and not the monitor, this is most likely a power supply issue. First thing to try would be replace the power supply. If the blinking led is on the monitor, it probably has bad capacitors and needs to be replaced. (or repaired)
Jul 15, 2008 | Dell Dimension 8400 power supply ** FREE...
Screen became dim over time and then blank. Red LED lights blinks when on and sound is fine. Is this the bulb, unlike the others that went suddenly?
There is more than one flourescent tube in your TV, It could be possible that one after the other has failed, these should usually last a few years depending on usage.
If it is not the tubes then there may be a fault in the backlight inverter although this would more likely show up as a sudden failure.
How old is your TV?
Oct 16, 2007 | Sony KDF-E55A20 55 in. LCD Television
Samsung SyncMaster 930B 19" LCD Flat Panel Monitor Logo
1,565 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
