SOURCE: Find a rebuild kit for 2000 Yamaha YZF R6
your best bet it to order back threw the dealer, but they should offer some kits for the bike threw after-market company's like partsunlimited, lp "lockhart Phillips", and maybe tucker rocky street, at a better price but you may have to buy some parts extra it may not come in a complete kit like the factory offers.
SOURCE: 2008 Yamaha YZF-R6 turn signal wiring harnes
sorry.. i don't know off the top of my head but super simple way to check.. get an electrical tester that pierces the wire and turns on a light.. ($5 at walmart--seriously) turn on left signal, check the wires.. the one that is flashing is your left signal... so on and so forth..
(this tool will be super handy in the future also)
SOURCE: How can i get de diagram of the CDI for yamaha yzf
There are a few manuals at this site (freebies) , you should find what you want:
http://www.carlsalter.com/motorcycle-manuals.asp
SOURCE: 1999 YZF-R6: Yamaha YZF-R6 1999 Clutch feels very stiff. Does t...
THE OPERATION OF THE CLUTH ON HIS MODEL IS OF CABLE TYPE, IF THE CLUTCH IS OPPERATING CORRECTLY THE 1ST THING TO CHECK WOULD BE THE CABLE, REMOVE THE CABLE YOU SHOULD BE ABLE TO PULL THE INNER WIRE SMOOTHLY TO AND FRO, IF YOU NEED TO USE ALOT OF EFORT TO DO THIS THEN YOU WILL NEED TO REPLACE THE CABLE,MAKING SURE YOU HAVE ADEQUIT FREE PLAY AT THE LEVER WHEN RE FITTED. OBSERVE THE ROUTE THE CABLE TAKES BEFORE REMOVAL AND REPLACE IN THE SAME WAY, YOU MAY ALSO TRY TO GET SOME LITE OIL DOWN THE CABLE, THOUGH I SUSPECT THIS WILL BE ALMOST INPOSSIBLE IF IT IS THIS TIGHT TO OPPERATE
SOURCE: where do we get a diagram of the wiring for a 2007
From the repair manual which you can download for free from here
http://www.r6messagenet.com/forums/pdf/2007_R6_Service.pdf
