Question about Watches
NEED MANUAL FOR RJ Rayalty Chronograph
I would like to get copy of a Rayalty Chronograph Watch.
  • 3 Answers
SOURCE: setting a cartier chronograph watch
  1. click the top button to stop the second hand
  2. click the bottom button to reset the timer
  3. pull the crown out all the way
  4. twist the crown forward hard and fast for a few seconds. The minute hand will start advancing very quickly.
  5. when the desired date and time is reached, push the crown back in place. If you missed the time, pull the crown back out and twist backwards. The minute hand will move slowly in reverse. If you twist hard and fast, the minute hand will start spinning in reverse again.
Posted on Mar 11, 2010
indays
  • 111 Answers
SOURCE: Aqualite Alarm Chronograph 4 button watch
good after noon ! press the adjust button hold it up to 3 second when the digit is blinking thats time to set press the mode to select the digit that you want to change after that press the stert or reset button to change no digit ! thank you ! god bless !
Posted on Aug 29, 2008
escapement
  • 2334 Answers
SOURCE: New Watch No Manual
No downloads available on the net, so, I suggest that you have to go back to the store and ask for users manual. Every watch sold must have one.
Posted on Dec 22, 2008
gemineye61
  • 831 Answers
SOURCE: need a user manual for the time magazine free
I have NO ideal what kind of watch it is so I am giving general chronograph instructions. You will have to use as it applies to the watch you were given.
These instructions are provided for users who are not familiar with using a mechanical/analog chronograph. The instructions may be applied to any chronograph that has a seconds counter, 30 minute counter, and hour counter.
Please refer to the instructions of the appropriate model to determine the location of each counter on the dial. Note: some of the features described here may not be available on your particular model. Again, refer to the specifications to see if they apply to your model.
Using the chronographe functions:
How to read the chronographe:
For a chronographe that has a center seconds register, a 30 minute register and an hour register. Example 1: If the hour register is between the 1 and 2, but closer to the 1, and the minute register is at 20, and the seconds register is at 35, then the elapsed time is 1 hour 20 minutes and 35 seconds. Example 2: If the hour register is between the 1 and 2, but closer to the 2, and the minute register is at 20, and the seconds register is at 35, then the elapsed time is 1 hour 50 minutes and 35 seconds.
How to read the tachymetre:
If you are driving and want to determine the speed of the car using your tachymetre, start your chronograph when you pass a mile marker, stop your chronographe when you pass the next mile marker. Look at the center seconds hand and read the number on the Tachymetre scale, this number will indicate the miles per hour that the vehicle is travelling.
How to read the pulsometer:
Some watches have a pulsometer instead of a tachymetre. Use it as follows: Start the chronographe and begin counting the pulse. When you have counted 30 beats, stop the chronographe. The number on the pulsometer scale will indicate the pulse rate per minute.
How to read the telemeter:
Some watches have a telemeter instead of a tachymetre or pulsometer. Here is an example of one use for a telemeter: Start the chronographe when you see lighting. Stop the chronographe when you hear the thunder. Read the center seconds hand on the Telemetric scale and the number will indicate the distance separating the observer from the place where the lighting struck. This can give you a good indication of how far off a storm might be.
The many uses of a chronographe:
A chronograph has many practical uses, from timing a plane flight, a car ride, or simply being curious. There are also some uses for the chronographe that may not be so obvious. For example, you can use the chronographe on your watch as a dual timezone indicator. This is done as follows: If it is currently 6 A.M. in your home location and it is 12 noon in London, start your chronograph at exactly 6 o'clock. The number of hours displayed on your chronographe hour register will then show you the current time in London. Of course, these are just some uses of a chronographe. There are hundreds of uses for chronographes.
Instructions: Astronic Chronograph Chronograph Chronometer Power Reserve Chronometer Astronic Chronometer World Time Chronometer Retro Alarm General Chronograph Common Q & A's
Posted on Aug 12, 2010
  • 2501 Answers
SOURCE: I need a Manual for
Their web site is not too helpful, as you may have already discovered!
Try going to http://www.ellessetime.com/ sellect the appropriate region and contact their customer service. They should be able to help.
Posted on Sep 04, 2010
Is there an online instruction manual for Kenneth Cole Model KS3025?
i don't know about on line instruction.
but i could help you ....
there is two position for crown 1 and 2.
bring crown on position 2 and turn crown clockwise to change TIME, DAY & DATE.
bring crown position 1, and turn crown counterclockwise to change DATE.
your watch has Chronograph / Stop watch.
use that please press right TOP button chronograph will START, press again Chronograph will STOP.
Press bottom button to RESET Chronograph.
hope it will help 9k=
Jun 06, 2014 | Kenneth Cole Watches
How to use Chronometer watch
Go to http://www.tagheuer.com/the-collection/aquaracer/man/calibre-s-chronograph/index.lbl?w=CAF7110.BA0803 and you will see your watch? and on the right is a menu with "user manual" in it. Down load the manual.
Aug 18, 2010 | Tag Heuer 2000 Aquaracer Chronograph...
Need owners manual for Seiko Quartz Chronograph Sports 150
I feel sure that Seiko will have a copy of the instructions in their archive, so if you contact them they should be able to send you a copy.
(Either that or advise you which watch has similar instructions).
May 31, 2010 | Watches
Did not receive owners manual when i purchased the watch trying to figure out the 4 buttons to set the time etc.
Copy the following into your search engine and it should take you to the watch you have and on the right is a menu which includes "user manual" which will give you all the information you need.
www.tagheuer.com/the-collection/carrera/men/automatic-chronograph-tachymetre/index.lbl?w=CV2013.FC6206
Mar 11, 2010 | Carrera Chronograph Red LCD Watch for Men
I need to know how to use my cl1112 Tag Heuer
Copy "ww2.tagheuer.com/_documents/manuals/EI2246_en.pdf"" into your search engine and it will take you to a generic instruction manual for TAG watches.
This manual includes instructions for operation of your watch.
Mar 01, 2010 | Watches
My alarm does not sound on my Tag Heuer Kirium F1?
Have you a copy of the manual?
If you have, then you will see that it can be turned off (last page), is this likely to be the case?
If you need a copy, go to their web site "tagheuer.com", select "watches", then "tag heuer formula 1", then "man", followed by "Tag Heuer F1 chronometer" and finally you will see on the right a menu, select "user manual".
This seems to be a generic manual that cover both the chronometer and alarm version of the watch.
If these are not the correct instructions for your watch, opposite the "user manual" menu is a search box, put your watch model in this and there should be a user manual with it.
If not look at a similar watch for a generic manual.
Jan 27, 2010 | Tag Heuer Kirium Formula 1 Chronograph...
Cannot set chronograph part of watch
I assume that you have not got the manual for your watch.
If this is correct, then you can go to "casio.com", select
"manuals"
Select "watches" and follow instructions to obtain a copy of your manual.
Jan 01, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
Watches Logo
100 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
