Question about Acer (91.48T37.003) CD-RW/DVD-ROM (Combo) Burner
Dvd driver Hi, My laptop cannot read a DVD. I think my DVD drive has been deleted, although I cannot remember deleting it.Please advise.
  • FLCHUCK Feb 11, 2009
    MY DRIVE JUST QUITE WORKING, SHOWS AN ERROR IN DIVICE DRIVERS. NO MATTER WHAT I DO I CAN'T SEEM TO GET IT TO WORK, WER CAN I BUY A GOOD REPLACEMENT
  • Acer Master
  • 2,404 Answers
Go into My computer and make sure its recognizing your dvd drive. If its not then you'll need to turn off your laptop and reseat the drive could be that its not making a good connection. If it is being shown in my computer and it can't read any dvd's then the drive is bad and would need to be replaced.
Posted on Feb 05, 2009
I think my DVD row driver has been crupted due to which it is not visible in mycmputer kindly send me the driver so that i can resolve this issue
Hi bhardwaj_sun,
If you are not seeing the drive for your CD/DVD in My Computer it doesn't mean that it is corrupted. There are just some settings inside the Registry that needs to be changed. Deleting the upper and lower filters is an effective and tested way to resolve this concern. Please follow the step by step procedure below:
Reminder: Please be careful to follow the procedure for this might cause for your system to be messed up if not properly followed.
  • Click on Start, then click Run. Type in regedit and then hit on enter.
  • Expand the following HKEY_LOCAL_MACHINE > SYSTEM > Current Control Set > Control > Class >then select, {4D36E965-E325-11CE-BFC1-08002BE10318}
  • On the right pane, look for the following: Upper Filters and/or Lower Filters.
  • If there's any of the two, right click on them and then choose delete.
  • After deleting, you may close the Registry Editor window.
  • Restart your computer.
When you restarted your PC you can now check on My Computer and you'll notice that the drive for your CD/DVD is back. Now, you can start using your DVD Drive once again. This should resolve your concern.
Hope this help you.
Thank you for using Fixya.
Nov 04, 2010 | Lenovo 3000 Y410 Laptop
Dvd drive problem
You can try to delete upper and lower filters for your system. go to start>run>type in regedit click ok> start looking for this parth HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318},when click on the folder look on the right column and look for upper/lower filters and delete it. restart system. Try updating the firmware of the optical drive depending on the model.
caution:be careful with deleting registry for your system this might affect your operating system functionality.
Jul 12, 2010 | Gateway (5500652) (  5500652)...
DVD Drive Can't Detect Any DVD or CD
hi there, this could be windows system glitch. please follow troubleshooting steps below
  1. Click Start , and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  5. In the right pane, click UpperFilters.
  6. On the Edit menu, click Delete.
  7. When you are prompted to confirm the deletion, click Yes.
  8. In the right pane, click LowerFilters.
  9. On the Edit menu, click Delete.
  10. When you are prompted to confirm the deletion, click Yes.
  11. Exit Registry Editor.
  12. Restart the computer.
Let me know if you need more help. Thanks!
Apr 08, 2010 | LG GSA-H42N 18x DVD RW DL IDE Drive...
Tsstcorp cddvdw ts-h653f ata device doesn't read the cd/dvds. It says no cd is detected insert and try again although the cd/dvd is already in
No solution yet? I think I have the same problem. Dell Inpiron 530 with same drive. I think my problem is hardware failure as Microsoft disk application can't fix, Dell diagnostics suggests hardware problem. Still I tried deleting drivers so windows would reinstall. Even tried going into regedit to no effect. Just can't read what is in drive. CD/DVD does not make the usual disc spinning sound.
I think I'm screwed. Warrenty ran out November 2010. Was having problems before that, but I failed to act on it. From searching internet, this drive may be a dud. Mine failed in less than a year.
Jan 02, 2010 | Computers & Internet
Computer does not recognize DVD drive
i had this problem on my computers search the internet and there is a step by step which will solve it. worked on my pc and laptop
Many third-party programs that control CD or DVD burning (as well as some player applications) install CD- or DVD-ROM filter device drivers into Windows. These filter drivers are meant to allow for low-level hooks into the hardware, to allow for functions such as packet writing (where a CD-R/W or DVD-/+RW can be written incrementally, like a hard disk).
These filter drivers sometimes have problems that can cause the CD or DVD drive to stop working correctly. The device entry for the CD or DVD drive in the Device Manager may show up with an error descriptor that reads "The device could not start." Additionally, there may be an error message that reads "One of the filter drivers for this device is invalid." The devices themselves do not show up in Explorer. Error codes for the device include code 31, code 32, code 19 or code 39, and sometimes the even more ominous warning "Your registry might be corrupted" appears.
Fixing the problem simply involves deleting the filter entries for the third-party device drivers. These entries can sometimes become damaged (which is what produces the "corrupt registry" warning).
To delete the offending keys, open the Registry and navigate to HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***\{4D36E965-E325-11CE-BFC1-08002BE10318}. . Delete the keys named UpperFilters and LowerFilters and reboot.
Several of the products made by Roxio are infamous for causing this problem, although in fairness to the company the most recent versions of their Roxio CD/DVD writing software (6.2 and higher) do not have these problems. Users of 5.0 or 6.0 editions of the Easy CD & DVD Creator product, which has been bundled with many new PCs in the past, should upgrade to 6.2 or better. Other programs can also cause this problem, with the same solution.
Note that after you do this, you may lose functionality in the program that uses the filter drivers, which may need to be reinstalled.
Dec 16, 2009 | HP Pavilion dv9000z Notebook
Dvd drive is not reading and also ejecting out !
Hi
I would simply recommend replacing the drive as it sounds like the optical lens is shot in it.
Taz
Oct 30, 2009 | Dell (0F146) Internal DVD Drive
My matshita dvd-ram uj880es driver has a code 39 ,
Start>run>type in "regedit"
go to:
HKEY_LOCAL_MACHINE>SYSTEM>>current cotrol set>control>class>{4d36E965-E325-11CE-BFC1-08002BE10319}
go ahead and delete the following,
upperFilters
LowerFileters
UpperFilters.bak
LowerFilters.bak
delete them, exit registry, restart and see if that fixes it.
(Remember to always back up your registry, and files when ever messing with the registry).
Aug 17, 2009 | Toshiba Satellite L305-S5907 Laptop
My DVD RRW is unable to read cds
is it listed under mycomputer? can you see any yellow mark for your dvd drive under device manager? (go to control panel, click system, hardware, device manager, click plus sign before optical drive) check if the drive will explore hwats on your disk on SAFE MODE, if it doesnt, replac dvd drive,if its does, delete upper and lower filter by following this steps : click start, click run, type regedit, the registry editor will come up, follow tihis path :
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} --- on the right side you will see upper or lower filter, delete both of which one can found on screen. restart the computer. you might also want to update firmware of your dvd drive.
Mar 10, 2009 | Computers & Internet
CD/DVD drivers deleted from registry?
it's windows issue, you just need to edit windows registry.
Follow this step from microsoft:
http://support.microsoft.com/kb/314060
Jul 01, 2008 | Computers & Internet
Toshiba satellite notebook dvd/cd player
Try to get an Windows XP or Vista CD.
Boot the computer with the cd on drive.
Be sure to select to boot from CD in setup(F2 key I think) or boot menu (F9 key I think)
If the computer boot from CD, probably you have a software problem, else your drive is damaged.
Good luck.
Dec 19, 2007 | Toshiba Satellite M45-S265 Notebook
Acer (91.48T37.003) CD-RW/DVD-ROM (Combo) Burner Logo
111 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
