Question about Philips 34PW9817 34" TV
My 36" Flat-screen CRT Philips TV turns itself off
Whenever I change the "source" input to AV1 or AV2, the TV turns itself off. It was working just fine at first, but now it just switches off every time that I try to change over to the DVD player. When it shuts off, the light blinks red twice. Any thoughts?
I'm getting the exact same thing with a 26" model. First I found AV2 started carrying AV1's input so we put a switch in. Then it starts to shut off with the twice blinking light after viewing the scart input for a while. I'm currently trying feeding it scart set to composite rather than RGB to see if it'll stay on. One other thing - I just got a oneforall remote. I don't suppose you did - in case that is triggering something?
People are reporting a fault with the "painter" chip which is terminal usually. But that seems to manifest as the tv switching to scart input spontaneously. I haven't seen that.
Hope you get somewhere - I'll let you know if I find anything.
Posted on Feb 07, 2010
What does AV1 mean on a SAM*TRON TV mean? How do I get rid of it?
av 1 is the source input for the tv
there should be av 2, 3 4 etc and each one isa for a different input item
for example av1 is for the tv -aerial , av2 may be dvd input , av3 may be x box, av4 home theater
how to get rid of it . click on exit or ok
Sep 30, 2016 | Televison & Video
How do I get the TV to show some sign that it is on
could you possibly maybe changed the input(source) selection to that of an unused device , If so most modern tvs will turn themselves off after a few minutes of receiving no input from a disconnected input , some common source selections that come to mind are ( AV1,AV2 , Hdmi1, hdmi2, DvD , and antenna) your tv might have different names but im sure it's got a source selection
May 07, 2015 | Televison & Video
How do I get sky tv through my philips mx5100vr home theatre
External Input Mode (for VCR features) To receive the signal from an external input (decoder, satellite receiver, video camera, another VCR etc.), connect to the AV2 (DECODER) socket, and enter "002" with numerical key pads to appear "AV2" on the TV screen.If you use the AV1 (TV) socket, enter "001" with numerical key pads to appear "AV1" on the TV screen. If you use the front AUDIO/VIDEO input jacks, enter "003" with numerical key pads to appear "AV3" on the TV screen.
Apr 25, 2015 | Philips MX5100VR System
How do i get my nintendo wii console to appear on the tv screen ive tried every channel and hdmi and such and nothing i know its on and working cause i feel the wii remote vibrate just nothing shows o
Kate what did you plug the cables into I suspect it was a grey cable with a red , white and yellow plugs. If I am correct this cable should be plugged into the AV1 or AV2 input port of your television. Try changing the input source to AV1 or AV2 Check it is plugged to AV1 on the Television and not into Conponent input !
Jan 02, 2015 | Sceptre X32BV-Naga 32 in. LCD TV
Sanyo tv change to av1 av2
Whenever your change from one video source to another, your tv automatically switches input modes (i.e. av1 to av2) to faciliate the source coming into your tv.
Aug 10, 2014 | Sanyo DS32920 32" TV
How do i get a pictue on my samsung tv?
The input is selected as AV1. Change it to input which you want to see. AV2, HDMI, TV etc:
Jul 27, 2014 | Samsung Televison & Video
Can get tv to change to av1
The Input button on the original remote is needed to switch to the AV1 or AV2 connections. Unfortunately, I do not believe that the Sanyo DS27930 has an equivalent Input button on the TV. A replacement remote is available here: http://www.emtcompany.com/sanyo-ds27930-remote/rc64.html . Other universal remotes may be able to transmit the Input signal. You will need a remote that was programmed over 6 months after the TV was released with an Input or Source button. Then try all Sanyo codes until you find one that controls all of the features.
I hope this helps.
Mar 04, 2013 | Sanyo DS27930 27" TV
How do i change from av1 to av2 . . .av3 ? have remote . .
I think you can do channel down, or up, 'til you go below channel 2, or above channel 125. Then it toggles through external inputs.
Apr 18, 2010 | Philips 27PT6441 27" TV
When trying to switch from AV1 to AV2 with the
The Red, White & Yellow connectors are your composite inputs usually classed as AV3 or component. The AV1 input is a Scart connection, if you have a scart cable, connect this as your AV source & the TV will switch from AV to component.
Oct 24, 2009 | LG Televison & Video
Blue screen
At least a couple of possibilities, check the yellow video cable that runs from the VCR to the TV, is it plugged into the side of the combo unit that says vcr?
Is your TV on the right source? You could have plugged the audio into say AV2 and the video into AV1, causing a mismatch. Make sure the yellow, red, and white are all plugged into one input section on the TV (AV1, AV2, Video 1, Video 2, etc).
Dec 09, 2008 | Philips MRV700VR DVD Recorder/VCR
Philips 34PW9817 34" TV Logo
574 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
