Question about Coleman Powermate Premium Plus 6250W Portable Generator
Misplaced User Manual for Coleman Powermate 6250
Briggs & Stratton Engine
two years old
never used/just cranked occasionally
NEED REPLACEMENT MANUAL
    Problem Solver:
  • 10 Answers
I would run a search on line for your model number. I will look and let you know.
Posted on Feb 03, 2009
I cannot locate the owners manual for my Coleman PowerMate 6250 generator 10 hp? Any place I can find this online quickly thank you
Most PowerMate manuals are available here: http://www.powermate.com/productmanuals.php?cat_id=3 . However, describing it as the PowerMate 6250 10 HP generator is insufficient to find the correct manual. The Coleman PowerMate line has several models with 10 HP engines and a 6250 Starting Watt (5000 W running) capacity.
These include the Powermate PM0435005; the direct link for this manual is http://www.powermate.com/pdfs/2011/12/29/pm0435005.02.pdf .
Please add a comment with the actual model number of your generator if you need further assistance with finding the correct manual for your generator.
I hope this helps.
Sep 05, 2017 | Coleman Electrical Supplies
Looking for a carb for a Coleman Powermate 500/6250 generator with a 10hp Briggs and Sratton engine...any suggestions?
As it is a Briggs Engine most quality Briggs dealers can get the carb. It isn't special to Coleman I don't believe.
Oct 08, 2013 | Coleman Powermate Premium Plus 6250W...
I have a 3 year old Coleman Powermate 6250
Try this! To excite it. Shut off the generator! Unplug everything,Then use the 12 volt battery to excite it per manual. Make sure the engine is NOT running and the breaker switch is in the on position. Now with the battery 12V removed restart the generator! This should fix it if the problem is that it lost its magnetism.
Jun 08, 2009 | Coleman Powermate Premium Plus 6250W...
Oil for Coleman Powermate 5000 PM0545305.03
Yes, SAE5W30 is just the right oil for this machine,it will take about a quart to fill it up to the bottom of the threads in the oil fill hole.
The engine of this generator is essentially just like a lawn mower with a fixed throttle setting. You should expect all of the same issues as any small engine that's been sitting for a while. Check the fuel tank for water/debris, check the carb for fouling, check the spark plug, etc.
If the generator has been sitting for 3+ years without running you may need to flash it to get any voltage out of it. If you get the engine running and it won't make any electricity ask me directly and I'll talk you thru the procedure.
I looked on www.powermate.com for an owners manual but they only seem to have the parts list, rats.
Regards,
Carl
Dec 13, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate 6250 generator
My answer:
You will need to contact Powermate directly (see below), and give themthe CORRECT model # info that you have there on that Genset.
Unfortunately what you posted above doesn't help out at all as there isNO model # for reference. Certain models are no longer available asthey have been discontinued and only by contacting Powermate directlywill you get the proper Operators Manual.
There should be no charge for this and most likely it will be a PDF download sent by their service dept.
The model # should be found either on the engine decal plate or else on the generator head assy or it's power panel.
Please post me a reply as to finding this solution being the bestresolve to your missing Operators Manual problem by following thecompany references & links below. Also please rate mytroubleshooting fix as well.
Keep me posted and I'll follow up as well.
Best regards,
Frank
Customer Service: US: 1-800-445-1805 Mexico: 011-52-5553-660800 Canada: 1-877-501-0090 Technical Service: 1-800-445-1805 or Email: At productservice@powermate.com and a service representative will personally respond to your inquiry Service Centers: Click here to find your nearest service center in the US or Canada FAQs: Click here to find answers to our Frequently Asked Questions Product Manuals and Parts Diagrams: Click here to find your product manual or parts diagram Register your product: Click here to register your product.
Sep 04, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
821 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
