Question about Kenwood KM400 / KM410 Chef Classic Stand Mixer
Kenwood Chef - slowest speed
I recall adjusting the speed controller to reduce the minimum speed - but cannot remember how (my neighbour at the time was a Kenwood engineer!)
Model A701A - bought early-mid 1970s
If you have max speed you have to replace the .1uf capacitor the 2 spring loaded screws serve far fine adjustment
Posted on Feb 05, 2009
Kenwood km020 variable speed on full all the time.
Had the same problem. The module registering the speed setting was broken. Easiest way to fix it is to order part nr KW710359. You can find various shops selling it on google. Bought mine for 35EUR.
Jul 30, 2013 | Kenwood Chef-major White Control Knob...
How can I service an A901 kenwood mixer, need to get top plate off.
the speed control on my kenwood chef A901 is not working
how do i fix this.
Oct 16, 2012 | Kenwood Chef Major A701 A901 Cm170 Km201...
Electrical Chart Needed
Hi, send me your email and I will send you a wiring diagram, also I can tell you where to get a cheap good quality repair kit
May 27, 2012 | Kenwood Food Mixers
Kenwood Chef KM400 motor speed is too slow
A failed SCR or triac will not always show visually any sign of failure. Chances are good that is all that is wrong. If mixer had been plugged in when it got wet, that is all it takes. Also check the transient voltage supressors if the chef has them. They would be identified on the circuit board. as TVS or MOV along with a number. Only number to use is the one on the component.
If you can find ratings for the old devices, just matching the basic ratings should do. Just guessing, but the SCRs should be 20 amp and 400 volt, If the old ones are a lower rating than my guess, there is no problem with using the higher ratings, if my guess is low, go with the original's ratings. Manufacturer of device does not matter as long as ratings are at least comparable.
Jan 19, 2012 | Kenwood KM400 / KM410 Chef Classic Stand...
Speed control not working
What model is your Kenwood ? to Kamalsalman
A901 models change triac and capacitor .. or centrifugal broken
also check if another's components is faulty.
Kenwood Chef Restore
Dec 22, 2008 | Kenwood KM800 Major Classic Stand Mixer
Difference Kenwood Chef A701 and Kenwood A901
Hello.
the difference between A701A and A901 is :
high speed outlet
slow speed outlet
planetary hub is similar . A701A, A901 and KM series
A701 Different planetary hub and fit different tools.
is not same A720 and A920 A7 = A701/A
A9 = A901 and KM
In our web site Kenwood Chef Restore in Downloads section.
you can download the compatibility of the models A700, A701 , A900 and KM series .
Regards
Oct 02, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
There was a smell of burning, i.e. very hot wiring insulatiuon (?) on old Kenwood Chef Model 901. Could it be the motor or some other component, and can I repair it? If it is due to overloading due to...
Hi sometimes, its not the motor, maybe its the speed control, in this model same A701 its centrifugal system, if the capacitor or resistor not working fine, give this smell . you must give your Kenwood for repair or check
kenwoodchefrestore.co.uk
Aug 16, 2008 | Kenwood KM300 Chef Stand Mixer
Kenwood Chef A701 Variable speed controller malfunction. Appliance only operates on maximum speed.
the solution its change the capacitor or triac, normaly problems in models A701 or A901 old motors
regards
Aug 07, 2008 | Kenwood KM300 Chef Stand Mixer
Kenwood KM400 / KM410 Chef Classic Stand Mixer Logo
579 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
jason
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
