Question about Canon PIXMA MP150 All-In-One InkJet Printer
Canon service error 6000,, how can i solve this problem?
  • 4,041 Answers
Hi there it is ink error.
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 26, 2010
5 Suggested Answers
SOURCE: Canon MP830 Service Error 6000
I have same problem affter update internet explorer version 7 from 5.6 message in screen error servive 6000
Posted on Apr 17, 2008
  • 135 Answers
SOURCE: Service error 6000
I can't tell you specifically what you should do to try and repair your printer, but I do have one suggestion, a link to a Service Manual and a probable reason why a service tech wants to charge you so much for a repair. If you look in the service manual, here is what it says regarding error 6000: ------------------------ Line feed error [6000] Solution (Replacement of listed parts, which are likely to be faulty) - Timing sensor unit (QM2-2683) - Timing slit disk film (QC1-6229) - Feed roller ass'y (QL2-0925) - Platen unit (QM2-2202) - Logic board ass'y (QM2-2670)*1 - PAPER FEED MOTOR (QK1-1502) ------------------------ In other words, somebody looked in the book and quoted you a price to replace all these parts. One very common problem for printers is that the paper feed rollers develop a slick surface and don't grip the way they are supposed to. If you're experiencing a paper-feed problem, you can try buffing the rubber feed rollers lightly with fine sandpaper to help them grip once again like they should. (I've repaired many printers doing nothing more than this.) Below is a link to the Service Manual for your printer. Hope this helps.
Posted on Aug 04, 2007
SOURCE: canon pixma ip 1500
anon PIXMA iP1000
Waste Ink Counter Reset.
Step 1: Manual for Service mode
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
step 2 : Software for Permanant
1. Reconnect the printer cable.
2.Open General Tools software and select (USB PORT)
3 .Choose (SET DESTINATION 1) And it should be reset.
Remark "After service mode Pls use software for permanent reset"
Posted on Jan 18, 2008
  • 34 Answers
SOURCE: what is service error 6000?
You have a paper jam somewhere. Cannon printers are very sensitive to any small pieces of paper trapped in the rollers.
Posted on Apr 29, 2009
What is service code 6000?
Hello Richard Miller
The error that you have, it means that your printer has a paper jam, this is the error appears in you computer, may be in the printer have the next error number. P3 followed E3
If you are writing this review, it is because they believe you have a paper jam, if they have seen and removed yourself.
Principally printers and Canon, in many cases the system detects a paper jam, but is not exactly a paper is causing the problem, in many cases can be any object that has entered and is obstructing the passage of the pages.
My first recommendation is to look carefully where they enter the pages on your printer, if necessary use some lighting for better viewing, you might find something there.
If after all get nothing related, follow the steps below to solve your problem.
Even then, you can not solve the problem, I recommend the following way, which is to eliminate jam Canon inbox.
service-code-6000-xnnjabddbe1z3hwtjta3ekn0-4-2.jpg Remove error 6000 printer Canon PIXMA MG2410 en Rellenado
To be honest most of the time are other elements that influence paper jams, which can not be determined on the Canon printers.
Nov 20, 2015 | Canon PIXMA Office Equipment & Supplies
Error e350 canon ir 6000
pls help canon ir6000 error E350-3000 solved the problems
Jun 27, 2012 | Canon Service Manual For Ir 6000
My canon ir 6000 is showing an error codes E000001-0000 How it will solve?
Your error code is for the fixing unit solve by checking the follwoing:-
1. Fixing lamp.
2. thermistor
3. Fixing assembly if receiving PD
5. if no Potential difference received they the power supply is not okey.
Jul 13, 2011 | Canon imageRUNNER 6000 Copier
Printer says paper jam error 6000 - how do I clear
Hello thanks for using fixya
Error 6000 actually a line feed error, with the problem originating from the timing disk film or the printer's logic board.
To solve this problem:
Check the timing disk film or Check the feed roller if is there any foreign body, remove it softly
Timing disk film is located at the left side of the printer, look at the picture given below to identify it.
If you didn't get it and have confusion to solve it yourself then go to Canon authorized service facility for repair.
Canon Support by phone, at 1-800-OK-CANON (1-800-652-2666)
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Feb 24, 2011 | Canon PIXMA iP1500 InkJet Photo Printer
Problem with Code 6000
Hello, according to another expert at fixya:
"Error 6000 is a service call error, meaning that the printer needs to be taken into a canon authorized service facility for repair.
This is a line feed error, with the problem originating from the timing **** disk film or the printer's logic board. "
Jul 29, 2009 | Canon MX310 Office All-In-One Printer
What is service error 6000 for Canon PIXMA iP1800?
Error 6000 means - The specified file could not be encrypted.
Solution: reinstall the printer driver.... it's better to install a upgraded version of driver...
Feb 26, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error 6000 is shown!!!!!!!
whenever it try to copy scan or print by canon pixmamp150 printer it shows error 5?please give me a solution to solve this problem.pleeeeeeeeeez
ayman refaie
Feb 19, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP830 all-in-one Inkjet Printer
Error code 5C10 on computor screen and on the printer it says 6A00
Jan 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
1,504 people viewed this question
old marine
old marine
